; Source created with Parsic Version 3.x
; at              : 2009.04.04. 21:56:14
; Project File    : C:\DOCUME~1\Martin\Asztal\eredm.PIC
; Project Version : 1.0.5
; Created         : 2001.07.24. 15:00:00
; Last change     : 2009.04.04. 21:56:06
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_ON & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
S1	= 32	; located in Bank 0
TR1	= 33	; located in Bank 0
TR1_HI	= 34	; located in Bank 0
S3	= 35	; located in Bank 0
S0	= 36	; located in Bank 0
S2	= 37	; located in Bank 0
OS1_FD	= 38	; located in Bank 0
OS2_FD	= 39	; located in Bank 0
OS3_FD	= 40	; located in Bank 0
ZV1	= 41	; located in Bank 0
ZV1_FD	= 42	; located in Bank 0
ZV2	= 43	; located in Bank 0
ZV2_FD	= 44	; located in Bank 0
ZV3	= 45	; located in Bank 0
ZV3_FD	= 46	; located in Bank 0
ZV4	= 47	; located in Bank 0
ZV4_FD	= 48	; located in Bank 0
ZV5	= 49	; located in Bank 0
ZV5_FD	= 50	; located in Bank 0
S4	= 51	; located in Bank 0
OS4_FD	= 52	; located in Bank 0
OS5_FD	= 53	; located in Bank 0
OS6_FD	= 54	; located in Bank 0
RAM	= 55	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 113	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 115	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
EXITINT
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'01111111'
	MOVWF PORTB
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'10000111'
	MOVWF TRISA
	MOVLW B'10000000'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
	CLRWDT
; Call subroutine BIN_TO_7SEG
	MOVLW LOW BIN_TO_7SEG
	MOVWF SYS_TMP1
	MOVLW HIGH BIN_TO_7SEG
	MOVWF SYS_TMP2
	MOVFW S0
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S1
	BSF INTCON,GIE
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 8
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 8
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S3,0
	GOTO LABEL_TR1_CLR
	BSF S3,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S3,0
LABEL_TR1_ENDE
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW ZV1
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW ZV2
	MOVWF S0
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW ZV1
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW ZV3
	MOVWF S0
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW ZV1
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL3
	MOVFW ZV4
	MOVWF S0
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW ZV1
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL4
	MOVFW ZV5
	MOVWF S0
	GOTO LABEL_MX1_END
LABEL_MX1_END
; UND - Gatter -> UG12
LABEL_UG12_1
	BTFSC S2,0
	GOTO LABEL_UG12_FALSE
LABEL_UG12_2
	BTFSC S2,1
LABEL_UG12_3
	BTFSS S2,4
LABEL_UG12_TRUE
	BSF PORTA,3
	GOTO LABEL_UG12_ENDE
LABEL_UG12_FALSE
	BCF PORTA,3
LABEL_UG12_ENDE
; UND - Gatter -> UG13
LABEL_UG13_1
	BTFSS S2,0
	GOTO LABEL_UG13_FALSE
LABEL_UG13_2
	BTFSC S2,1
LABEL_UG13_3
	BTFSS S2,4
LABEL_UG13_TRUE
	BSF PORTA,4
	GOTO LABEL_UG13_ENDE
LABEL_UG13_FALSE
	BCF PORTA,4
LABEL_UG13_ENDE
; UND - Gatter -> UG14
LABEL_UG14_1
	BTFSC S2,0
	GOTO LABEL_UG14_FALSE
LABEL_UG14_2
	BTFSS S2,1
LABEL_UG14_3
	BTFSS S2,4
LABEL_UG14_TRUE
	BSF PORTA,5
	GOTO LABEL_UG14_ENDE
LABEL_UG14_FALSE
	BCF PORTA,5
LABEL_UG14_ENDE
; One Shot -> OS1
	BTFSS S3,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S2,5
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S2,5
	BTFSC S3,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; One Shot -> OS2
	BTFSC S2,5
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S2,6
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S2,6
	BTFSS S2,5
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; One Shot -> OS3
	BTFSC S2,6
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S2,7
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S2,7
	BTFSS S2,6
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; RS-FLIP-FLOP -> RS1
	BTFSC S2,5
	GOTO LABEL_RS1_RESET
	BTFSS S2,7
	GOTO LABEL_RS1_ENDE
	BSF S2,4	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S2,4	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; UND - Gatter -> UG15
LABEL_UG15_1
	BTFSS S2,0
	GOTO LABEL_UG15_FALSE
LABEL_UG15_2
	BTFSS S2,1
LABEL_UG15_3
	BTFSS S2,4
LABEL_UG15_TRUE
	BSF PORTA,6
	GOTO LABEL_UG15_ENDE
LABEL_UG15_FALSE
	BCF PORTA,6
LABEL_UG15_ENDE
; Zähler -> ZV1
	BTFSS S2,2	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf negative Flanke
	BTFSC S2,5
	GOTO LABEL_ZV1_SETFD
	BTFSS ZV1_FD,0
	BCF ZV1_FD,0
	BTFSC S2,3	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
; Output Q0
	BTFSS ZV1,0
	GOTO LABEL_ZV1_SETOUT0
	BSF S2,0
	GOTO LABEL_ZV1_SETOUT0_END
LABEL_ZV1_SETOUT0
	BCF S2,0
; Output Q1
	BTFSS ZV1,1
	GOTO LABEL_ZV1_SETOUT1
	BSF S2,1
	GOTO LABEL_ZV1_SETOUT1_END
LABEL_ZV1_SETOUT1
	BCF S2,1
; Output Q2
	BTFSS ZV1,2
	GOTO LABEL_ZV1_SETOUT2
	BSF S2,2
	GOTO LABEL_ZV1_SETOUT2_END
LABEL_ZV1_SETOUT2
	BCF S2,2
LABEL_ZV1_SETFD
; Test auf positive Flanke
	BTFSS S2,5
	GOTO LABEL_ZV1_EXIT
	BSF ZV1_FD,0
LABEL_ZV1_EXIT
; Verteiler -> BV1
	BTFSC S1,0
	GOTO LABEL_BV1_0
	BSF PORTB,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BCF PORTB,0
LABEL_BV1_0_END
	BTFSC S1,1
	GOTO LABEL_BV1_1
	BSF PORTB,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BCF PORTB,1
LABEL_BV1_1_END
	BTFSC S1,2
	GOTO LABEL_BV1_2
	BSF PORTB,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BCF PORTB,2
LABEL_BV1_2_END
	BTFSC S1,3
	GOTO LABEL_BV1_3
	BSF PORTB,3
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BCF PORTB,3
LABEL_BV1_3_END
	BTFSC S1,4
	GOTO LABEL_BV1_4
	BSF PORTB,4
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BCF PORTB,4
LABEL_BV1_4_END
	BTFSC S1,5
	GOTO LABEL_BV1_5
	BSF PORTB,5
	GOTO LABEL_BV1_5_END
LABEL_BV1_5
	BCF PORTB,5
LABEL_BV1_5_END
	BTFSC S1,6
	GOTO LABEL_BV1_6
	BSF PORTB,6
	GOTO LABEL_BV1_6_END
LABEL_BV1_6
	BCF PORTB,6
LABEL_BV1_6_END
; GND
	BCF S2,3	; immer Low
; Zähler -> ZV2
	BTFSS S3,3	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S3,5
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	BTFSC S4,4	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S3,5
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Zähler -> ZV3
	BTFSS S3,1	; Reset ?
	GOTO LABEL_ZV3_COUNT
	CLRF ZV3
	GOTO LABEL_ZV3_SETOUT
LABEL_ZV3_COUNT
	BTFSS S3,3
	GOTO LABEL_ZV3_SETFD
	BTFSC ZV3_FD,0
	BSF ZV3_FD,0
	GOTO LABEL_ZV3_BACKWARD
	INCF ZV3,F
LABEL_ZV3_BACKWARD
	DECF ZV3,F
LABEL_ZV3_SETOUT
LABEL_ZV3_SETFD
	BTFSC S3,3
	GOTO LABEL_ZV3_EXIT
	BCF ZV3_FD,0
LABEL_ZV3_EXIT
; Zähler -> ZV4
	BTFSS S4,1	; Reset ?
	GOTO LABEL_ZV4_COUNT
	CLRF ZV4
	GOTO LABEL_ZV4_SETOUT
LABEL_ZV4_COUNT
	BTFSS S4,3
	GOTO LABEL_ZV4_SETFD
	BTFSC ZV4_FD,0
	BSF ZV4_FD,0
	GOTO LABEL_ZV4_BACKWARD
	INCF ZV4,F
LABEL_ZV4_BACKWARD
	DECF ZV4,F
LABEL_ZV4_SETOUT
LABEL_ZV4_SETFD
	BTFSC S4,3
	GOTO LABEL_ZV4_EXIT
	BCF ZV4_FD,0
LABEL_ZV4_EXIT
; Zähler -> ZV5
	BTFSS S3,7	; Reset ?
	GOTO LABEL_ZV5_COUNT
	CLRF ZV5
	GOTO LABEL_ZV5_SETOUT
LABEL_ZV5_COUNT
	BTFSS S4,1
	GOTO LABEL_ZV5_SETFD
	BTFSC ZV5_FD,0
	BSF ZV5_FD,0
	GOTO LABEL_ZV5_BACKWARD
	INCF ZV5,F
LABEL_ZV5_BACKWARD
	DECF ZV5,F
LABEL_ZV5_SETOUT
LABEL_ZV5_SETFD
	BTFSC S4,1
	GOTO LABEL_ZV5_EXIT
	BCF ZV5_FD,0
LABEL_ZV5_EXIT
; Vergleich -> IF1
	MOVLW 10
	SUBWF ZV2,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S3,4
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S3,4
LABEL_IF1_EXIT
; Vergleich -> IF2
	MOVLW 10
	SUBWF ZV3,W	; F - W -> W
LABEL_IF2_CHECK
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S3,2
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S3,2
LABEL_IF2_EXIT
; Vergleich -> IF3
	MOVLW 9
	SUBWF ZV4,W	; F - W -> W
LABEL_IF3_CHECK
	GOTO LABEL_IF3_FALSE
LABEL_IF3_TRUE
	BSF S4,2
	GOTO LABEL_IF3_EXIT
LABEL_IF3_FALSE
	BCF S4,2
LABEL_IF3_EXIT
; Vergleich -> IF4
	MOVLW 10
	SUBWF ZV5,W	; F - W -> W
LABEL_IF4_CHECK
	GOTO LABEL_IF4_FALSE
LABEL_IF4_TRUE
	BSF S4,0
	GOTO LABEL_IF4_EXIT
LABEL_IF4_FALSE
	BCF S4,0
LABEL_IF4_EXIT
; ODER - Gatter -> LG5
LABEL_LG5_1
	BTFSC S3,2
	GOTO LABEL_LG5_TRUE
LABEL_LG5_2
	BTFSC S3,4
	GOTO LABEL_LG5_TRUE
LABEL_LG5_3
	BTFSC S3,6
	GOTO LABEL_LG5_TRUE
LABEL_LG5_FALSE
	BCF S3,3
	GOTO LABEL_LG5_ENDE
LABEL_LG5_TRUE
	BSF S3,3
LABEL_LG5_ENDE
; ODER - Gatter -> LG6
LABEL_LG6_1
	BTFSC S4,2
	GOTO LABEL_LG6_TRUE
LABEL_LG6_2
	BTFSC S3,7
	GOTO LABEL_LG6_TRUE
LABEL_LG6_3
	BTFSC S3,6
	GOTO LABEL_LG6_TRUE
LABEL_LG6_FALSE
	BCF S4,1
	GOTO LABEL_LG6_ENDE
LABEL_LG6_TRUE
	BSF S4,1
LABEL_LG6_ENDE
; ODER - Gatter -> LG7
LABEL_LG7_1
	BTFSC S3,2
	GOTO LABEL_LG7_TRUE
LABEL_LG7_2
	BTFSC S3,6
	GOTO LABEL_LG7_TRUE
LABEL_LG7_FALSE
	BCF S3,1
	GOTO LABEL_LG7_ENDE
LABEL_LG7_TRUE
	BSF S3,1
LABEL_LG7_ENDE
; ODER - Gatter -> LG8
LABEL_LG8_1
	BTFSC S3,6
	GOTO LABEL_LG8_TRUE
LABEL_LG8_2
	BTFSC S4,0
	GOTO LABEL_LG8_TRUE
LABEL_LG8_FALSE
	BCF S3,7
	GOTO LABEL_LG8_ENDE
LABEL_LG8_TRUE
	BSF S3,7
LABEL_LG8_ENDE
; GND
	BCF S4,4	; immer Low
; One Shot -> OS4
	BTFSC PORTA,0
	GOTO LABEL_OS4_1
	BTFSC OS4_FD,0
	GOTO LABEL_OS4_1
	BSF OS4_FD,0
	BSF S3,5
	GOTO LABEL_OS4_2
LABEL_OS4_1
	BCF S3,5
	BTFSS PORTA,0
	GOTO LABEL_OS4_2
	BCF OS4_FD,0
LABEL_OS4_2
; One Shot -> OS5
	BTFSC PORTA,1
	GOTO LABEL_OS5_1
	BTFSC OS5_FD,0
	GOTO LABEL_OS5_1
	BSF OS5_FD,0
	BSF S3,6
	GOTO LABEL_OS5_2
LABEL_OS5_1
	BCF S3,6
	BTFSS PORTA,1
	GOTO LABEL_OS5_2
	BCF OS5_FD,0
LABEL_OS5_2
; One Shot -> OS6
	BTFSC PORTA,2
	GOTO LABEL_OS6_1
	BTFSC OS6_FD,0
	GOTO LABEL_OS6_1
	BSF OS6_FD,0
	BSF S4,3
	GOTO LABEL_OS6_2
LABEL_OS6_1
	BCF S4,3
	BTFSS PORTA,2
	GOTO LABEL_OS6_2
	BCF OS6_FD,0
LABEL_OS6_2
	GOTO MAIN
; Table -> BIN_TO_7SEG
BIN_TO_7SEG
	RETLW 63	; // INDEX 0
	RETLW 6	; // INDEX 1
	RETLW 91	; // INDEX 2
	RETLW 79	; // INDEX 3
	RETLW 102	; // INDEX 4
	RETLW 109	; // INDEX 5
	RETLW 125	; // INDEX 6
	RETLW 7	; // INDEX 7
	RETLW 127	; // INDEX 8
	RETLW 111	; // INDEX 9
	RETLW 63	; // INDEX 10
	END
