;	Inductance & Capacitance Meter
; LC002	- THIS ONE WORKS FINE WITH A WELL BEHAVED DISPLAY
;	Deleted  CpyBin subroutine and one call to it
;	Modified B2_BCD to take its input directly from <AARGB0,1,2>
;	Modified "oscillator test" so it copies F3   to <AARGB0,1,2>
;	Fixed Get_Lcal so it gets the correct number
;	Minor adjustment to MS100 timing to correct frequency display
;	Check for oscillator too slow when measuring L or C.
; LC003	- Optimised / Modified to handle "bad" displays
;	Removed duplicated code in DATS subroutine
;	Added code to fix crook display (select by jumper on B4 - 10)
;	Optimised L & C formatting code
;	Optimised "Display" subroutine
;	Cleaned up LCDINIT
; LC004 - Deleted timer Interrupt Service Routine
;	Modified way oscillator "out of range" condition is detected
; LC628 - LC004 code ported to 16F628 by Egbert Jarings PA0EJH.
;  Mem starts now at 0x20
;  InitIO modified , 628 PortA start's up in Analog Mode 
;  So changed to Digital Mode (CMCON)
;  Display's "Calibrating" to fill up dead Display time
;  when first Powerd Up.
;  Changed pmsg Routine, EEADR  trick  wont work with 628,
;  PCL was always 0x00 so restart occurs. EEADR is now EAD.
;  Also changed EEADR in FP routine to EAD 
;  Bad Display isn't bad at all, its a Hitachi HD44780, as
;  80% of all Display's are. Adress as 2 Lines x 8 Char.
;  So LCDINIT modified for 2 x 8 Display's. (0x28 added)
;	CPU configuration
;	It was a 16F84, HS?? oscillator, 
;	watchdog timer off, power-up timer on
	processor	16f628
	include		<p16f628.inc>
;	__config	_HS_OSC & _PWRTE_ON & _WDT_OFF	; 16f84
__CONFIG        _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC & _BODEN_ON & _LVP_OFF
;       GENERAL MATH LIBRARY DEFINITIONS
;	define assembler constants
B0		equ	0
B1		equ	1
B2		equ	2
B3		equ	3
B4		equ	4
B5		equ	5
B6		equ	6
B7		equ	7
MSB		equ	7
LSB		equ	0
;     STATUS bit definitions
#define	_C	STATUS,0
#define	_Z	STATUS,2
;       FIXED POINT SPECIFIC DEFINITIONS
;       remainder storage
REMB3           equ     0x20
REMB2           equ     0x21
REMB1           equ     0x22
REMB0           equ     0x23    ; most significant byte of remainder
;       general register variables
SIGN            equ     0x29    ; save location for sign in MSB
TEMPB3          equ     0x30
TEMPB2          equ     0x31
TEMPB1          equ     0x32
TEMPB0          equ     0x33
TEMP            equ     0x33    ; temporary storage
LOOPCOUNT       equ     0x34    ; loop counter
;       binary operation arguments & rest of FP stack
AARGB4          equ     0x23
AARGB3          equ     0x24
AARGB2          equ     0x25
AARGB1          equ     0x26
AARGB0          equ     0x27
AARG            equ     0x27    ; most significant byte of argument A
AEXP            equ     0x28    ; 8 bit biased exponent for argument A
BARGB2          equ     0x2c
BARGB1          equ     0x2d
BARGB0          equ     0x2e
BARG            equ     0x2e    ; most significant byte of argument B
BEXP            equ     0x2f    ; 8 bit biased exponent for argument B
CARGB1			equ		0x35
CARGB0			equ		0x36
CARG			equ		0x37	; most significant byte of argument C
CEXP			equ		0x38	; 8 bit biased exponent for argument C
;       FLOATING POINT SPECIFIC DEFINITIONS
;       literal constants
EXPBIAS         equ     D'127'
;       floating point library exception flags
FPFLAGS         equ     0x2a    ; floating point library exception flags
IOV             equ     0       ; bit0 = integer overflow flag
FOV             equ     1       ; bit1 = floating point overflow flag
FUN             equ     2       ; bit2 = floating point underflow flag
FDZ             equ     3       ; bit3 = floating point divide by zero flag
NAN		equ	4	; bit4 = not-a-number exception flag
DOM		equ	5	; bit5 = domain error exception flag
RND             equ     6       ; bit6 = floating point rounding flag, 0 = truncation
                                ; 1 = unbiased rounding to nearest LSB
SAT             equ     7       ; bit7 = floating point saturate flag, 0 = terminate on
                                ; exception without saturation, 1 = terminate on
                                ; exception with saturation to appropriate value
#define	ENA	PORTA,0x02	; Display "E"
#define	RS	PORTA,0x03	; Display "RS"
#define relay	PORTA,0x01	; 0 = energise relay
#define FIXIT	PORTB,0x04	; Pin 10,  0 = "fix bad display"
				; Floating 1 = "good display"
#define setup	PORTB,0x06	; Pin 12, 0 = "Setup"
#define	functn	PORTB,0x07	; Pin 13, 0 = "Inductor"
;#define	OvrRng	FLAGS,0x04	; Now unused
#define BANKSEL	STATUS,RP0
#define	beq	bz		; Motorola syntax branches
#define	BEQ	bz
#define	BNE	bnz
#define	bne	bnz
#define	BCC	bnc
#define	bcc	bnc
#define	BCS	bc
#define	bcs	bc
#define	BRA	goto
#define	bra	goto
;	file register declarations: use only registers in bank0
;	bank 0 file registers begin at 0x0c in the 16F84
; FP uses memory 0x20 to 0x38 inclusive
	cblock 0x3a
	COUNT			; Bin to BCD convert (bit count)
	cnt			;                    (BCD BYTES)
	COUNT1			; Used by delay routines
				; and "prescaler flush"
	COUNT2			; Timing (100ms)
	CHR 
	F1:2
	F2:2
	F3:2
	bcd:4			; BCD, MSD first 
	FLAGS
	TabStop			; Used to fix bad? displays.
	TabTemp
	EAD				; Used to overcome EEADR error
	endc
;	Begin Executable Stuff(tm)
	org	0
GO	clrwdt				; 0 << Reset
	call	InitIO		; 1 INITIALISE PORTS
	clrf	PORTA		; 2
	goto	START		; 3
;	Text Strings (stored in RETLWs)
ovr		dt	"   Over Range   ",0
Unit1	dt	" nF",0
Unit2	dt	" pF",0
Unit3	dt	" mH",0
Unit4	dt	" uH",0
Cintro	dt	" C = ",0
Lintro	dt	" L = ",0
Calibr  dt	" Calibrating ",0
;	Main Program
START	bsf	relay		; de-energise relay
	CLRF	PORTB
	CALL	LCDINIT	 	; INITIALIZE LCD MODULE	
cmdloop	call	HOME
	btfsc	setup		; Doing initial oscillator test?
	goto	Chk4Z
;	Measure & display osc freq for initial setup
	call	Measure		; Measure Local Osc Freq.
	btfss	INTCON,T0IF	; Set = Counter overflow?
	goto	Do_Disp
	MOVLW	ovr		; Over-range message
	call	pmsg
	goto	cmdloop
Do_Disp	clrf	AARGB0		; Copy to 24 bit number
	movf	F3,W		; in AARGB0, 1, 2
	movwf	AARGB1		; for display
	movf	F3+1,W
	movwf	AARGB2
	call	Display
	goto	cmdloop
;	"Zero" the meter.
Chk4Z	call	Measure		; Dummy Run
	MOVLW   Calibr		; Display's " Calibrating "
	call	pmsg		
	call	MS300
	call	Measure		; Get freq in F3
	movf	F3,W		; Copy to F1
	movwf	F1
	movf	F3+1,W
	movwf	F1+1
	bcf	relay		; Add standard capacitor *************
	call	MS200
	call	Measure
	movf	F3,W		; Copy to F2
	movwf	F2
	movf	F3+1,W
	movwf	F2+1
	bsf	relay		; Remove standard capacitor
	call	MS200
;	Now we resume our regular pogrom
M_F3	call	HOME
	call	Measure		; Measure F3 & leave it there
	movf	F3,w		; test for "too low" frequency
	beq	OORange
	btfss	INTCON,T0IF	; test for "too high" frequency
	goto	OK2GO
OORange	MOVLW	ovr		; Over/Under range message
	call	pmsg
	goto	M_F3
;	Precompute major bracketed terms cos
;	we need 'em both for all calculations
OK2GO	call	F1_F2
	call	F1_F3
;	See what mode we are in
	btfss	functn		; 0=Inductor
	goto	Do_Ind
;	OK, we've been told it's a capacitor
Do_Cap	movlw	Cintro		; C =
	call	pmsg
	call	C_calc
	call	C_disp
	goto	M_F3
;	Now, they reckon it's a @#$*! inductor
Do_Ind	movlw	Lintro		; L =
	call	pmsg
	call	L_calc
	call	L_disp
	goto	M_F3
;	Print String addressed by W
;	Note: Strings are in program space
pmsg	movwf	EAD	;EEADR		; Temp for pointer
pm1	movf	EAD,W		; Get current pointer
	call	pmsub
	andlw	0xff		; Test returned value
	beq	pm_end		; NULL = All done
	call	DATS
	incf	EAD,F
	goto	pm1
pmsub	movwf	PCL		; Goto W
	nop			; Just in case
pm_end	return
;	Delay for 2ms (untrimmed)
MS2	MOVLW	0xFD		; DELAY 2ms
	MOVWF	COUNT1
	MOVLW	0x66
	MOVWF	COUNT2
	goto	L3		
;	Delay for about 200ms or 300ms (untrimmed)
MS300	call	MS100
MS200	call	MS100
;	Delay for about 100ms
MS100	MOVLW	0x7e		; Count up
	MOVWF	COUNT1		; to roll-over
	MOVLW	0x20		; was 0x19, then 0x25, then 1f
	MOVWF	COUNT2			
L3	INCFSZ	COUNT2,F
	GOTO	L3
	INCFSZ	COUNT1,F
	GOTO	L3
	RETLW	0
;	Put a BCD nybble to display
PutNyb	ANDLW	0x0F		; MASK OFF OTHER PACKED BCD DIGIT
	ADDLW	0x30		; Convert BIN to ASCII
;	Put a byte to display
DATS	decf	TabStop,F	; Used for display of 9th Char
	bne	DAT1			; Not yet
	movwf	TabTemp		; Save character
	btfss	FIXIT		; Check if we got a 2x8 on 1 line.
	CALL	LINE2		; Skip this if 1x16
	movf	TabTemp,W	; Restore character
DAT1	BSF	RS			; SELECT DATA REGISTER
CM	MOVWF	CHR			; STORE CHAR TO DISPLAY
	SWAPF	CHR,W		; SWAP UPPER AND LOWER NIBBLES (4 BIT MODE)
	call	PB_dly
	MOVF	CHR,W		; GET CHAR AGAIN 
;	Put 4 bits to LCD & wait (untrimmed)
PB_dly	ANDLW	0x0F		; MASK OFF UPPER 4 BITS
	MOVWF	PORTB		; SEND DATA TO DISPLAY		
	BSF	ENA		; ENA HIGH
	NOP			
	BCF	ENA		; ENA LOW 
;	goto	D200us		; Fall into DELAY subroutine
;	Delay for 200us (untrimmed)
D200us	MOVLW	0x42		; DELAY  200us
	MOVWF	COUNT1	
NXT5	DECFSZ	COUNT1,F
	GOTO	NXT5	
	RETLW	0
;	Convert 24-bit binary number at <AARGB0,1,2> into a bcd number
;	at <bcd>. Uses Mike Keitz's procedure for handling bcd 
;	adjust; Modified Microchip AN526 for 24-bits.
B2_BCD
b2bcd   movlw   .24		; 24-bits
        movwf   COUNT		; make cycle counter
        clrf    bcd+0		; clear result area
        clrf    bcd+1
        clrf    bcd+2
        clrf    bcd+3
b2bcd2  movlw   bcd 		; make pointer
        movwf   FSR
        movlw   .4
        movwf   cnt
; Mike's routine:
b2bcd3  movlw   0x33            
        addwf   INDF,f          ; add to both nybbles
        btfsc   INDF,3          ; test if low result > 7
        andlw   0xf0            ; low result >7 so take the 3 out
        btfsc   INDF,7          ; test if high result > 7
        andlw   0x0f            ; high result > 7 so ok
        subwf   INDF,f          ; any results <= 7, subtract back
        incf    FSR,f           ; point to next
        decfsz  cnt,f
        goto    b2bcd3
        rlf     AARGB2,f	; get another bit
        rlf     AARGB1,f
        rlf     AARGB0,f
        rlf     bcd+3,f         ; put it into bcd
        rlf     bcd+2,f
        rlf     bcd+1,f
        rlf     bcd+0,f
        decfsz  COUNT,f         ; all done?
        goto    b2bcd2          ; no, loop
        return                  ; yes
;*********** INITIALISE LCD MODULE 4 BIT MODE ***********************
LCDINIT CALL	MS100		; WAIT FOR LCD MODULE HARDWARE RESET
	BCF	RS		; REGISTER SELECT LOW
	BCF	ENA		; ENABLE LINE LOW
	MOVLW	0x03		; 1
	call	PB_dly
	CALL	MS100		; WAIT FOR DISPLAY TO CATCH UP
	MOVLW	0x03		; 2
	call	PB_dly
	MOVLW	0x03		; 3
	call	PB_dly
	MOVLW	0x02		; Fn set 4 bits
	call	PB_dly
	MOVLW	0x28		; DISPLAY 2 Line , 5x7 Dot's
	CALL	ST200us		; New in LC005 version
	MOVLW	0x0C		; 0x0C DISPLAY ON
	CALL	ST200us
	MOVLW	0x06		; 0x06 ENTRY MODE SET
	CALL	ST200us
	MOVLW	0x01		; 0x01 CLEAR DISPLAY
	CALL	Home2
;	RETLW	0
;	goto	CLEAR		; Fall into CLEAR
;************ CLEAR DISPLAY ***************************
CLEAR	MOVLW	0x01		; CLEAR DISPLAY
	goto	Home2		; LONGER DELAY NEEDED WHEN CLEARING DISPLAY
;*********** MOVE TO HOME *****************************
HOME	movlw	0x09		; Count characters
	movwf	TabStop		; before tickling display.
	MOVLW	0x02		; HOME DISPLAY
Home2	CALL	STROBE
	goto	MS2
;	SENDS DATA TO LCD DISPLAY MODULE (4 BIT MODE)	
STROBE	BCF	RS		; SELECT COMMAND REGISTER
	GOTO	CM
;************ MOVE TO START OF LINE 2 *****************
LINE2	MOVLW	0xC0		; ADDRESS FOR SECOND LINE OF DISPLAY
							; was 0xC0
ST200us	CALL	STROBE
	goto	D200us
;       Initialise Input & Output devices
InitIO	BSF CMCON, CM0	   	;
    	BSF CMCON, CM1 	   	; Set Comp to digital I/O
    	BSF CMCON, CM2 	   	; 
	bsf	BANKSEL		; Select Bank1
	movlw	0x37		; Option register
	movwf	OPTION_REG	; Port B weak pull-up enabled
				; INTDEG Don't care
				; Count RA4/T0CKI
				; Count on falling edge
				; Prescale Timer/counter
				; divide Timer/counter by 256
				; PORTA:-
	movlw	0x10		; initialise data direction
				; 1 = input
				; 0 = output
				; PORTA has 5 pins     4 3 2 1 0
				; 0x10       =   0 0 0 1 0 0 0 0
	movwf	TRISA		; PORTA<0>   = CLAMP count input
				; PORTA<1>   = Relay. 0 = energise
				; PORTA<2>   = LCD "E"
				; PORTA<3>   = LCD "RS"
				; PORTA<4>   = Count Input
				; PORTA<5:7> = not implemented in 16F84
;	clrf 	TRISB		; PORTB:-
;	bcf     BANKSEL		; initialise data direction
;	clrf    PORTB		; PORTB has 8 pins
;	bsf	BANKSEL		; port pin       7 6 5 4 3 2 1 0
	movlw	0xf0		; 0xf0       =   1 1 1 1 0 0 0 0
	movwf	TRISB		; PORTB<0>   = LCD "DB4"
				; PORTB<1>   =     "DB5"
				; PORTB<2>   =     "DB6"
				; PORTB<3>   =     "DB7"
				; PORTB<4>   = Input
				; PORTB<5>   = Input
				; PORTB<6>   = Input
				; PORTB<7>   = Input
	bcf	BANKSEL		; Re-select Bank0
	return	
;	Measure Frequency. Stash in "F3 and F3+1"
Measure	bcf	INTCON,T0IF	; Declare "Not yet Over-range"
	CLRF	TMR0		; RESET INTERNAL COUNT (INCLUDING PRESCALER)
				; See page 27 Section 6.0
	bsf	PORTA,0		; Part of Osc gating
	CLRF	F3		; Ready to receive 16 bit number
	CLRF	F3+1
				; OPEN GATE
				; PORTA:-
	movlw	0x11		; initialise data direction
				; 1 = input
				; 0 = output
				; 0x10       =   0 0 0 1 0 0 0 1
				; PORTA<1>   = 
				; PORTA<4>   = Input
;	bcf	BANKSEL		; Re-select Bank0
	CALL	MS100		; 100MS DELAY
				; CLOSE GATE (COUNT COMPLETE)
;	bsf	BANKSEL		; Select Bank1
				; PORTA:-
				; 1 = input
				; 0 = output
				; PORTA<1>   = 
				; PORTA<4>   = Input
	MOVF	TMR0,W		; GET HIGH BYTE		
	MOVWF	F3		; Copy to Big end of 16 bit result
; The 311 "outputting" a 1 'cos we've forced it high
; so T0CKI=1.
PSC1	bsf	BANKSEL		; Select Bank1
	bsf	OPTION_REG,T0SE	; Clock the prescaler
	nop
	bcf	OPTION_REG,T0SE
	DECF	F3+1,F		; Decrement the counter
	movf	TMR0,W		; Has TMR0 changed?
	xorwf	F3,W		; if unchanged, XOR -> 0
	beq	PSC1
	return			; F3 : F3+1 now holds 16 bit result
;	Display contents of AARGB0,1,2 on LCD
;	First convert to BCD, Then ASCII (nybble at a time)
Display	CALL	B2_BCD		; CONVERT COUNT TO BCD		
	call	Swap0		; GET NEXT DIGIT
	call	Move0		; GET OTHER BCD DIGIT
	call	Swap1
	call	Move1
	call	Swap2
	call	Move2
	call	Swap3
	goto	Move3		; includes return
;	Formatted display of BCD work area for Capacitor
C_disp
F_C1	MOVF	bcd+0,W
	ANDLW	0x0F
	beq	F_C2
	CALL	PutNyb
	call	Swap1
	call	Move1
	CALL	DoDP		; Print DP
	call	Swap2
	goto	F_C3U
F_C2	swapf	bcd+1,W
	ANDLW	0x0F
	beq	F_C3
	CALL	PutNyb
	call	Move1
	call	Swap2
	call	Move2
	goto	F_C3U		; print nF. includes RETURN
F_C3	MOVF	bcd+1,W
	ANDLW	0x0F
	beq	F_C4
	CALL	PutNyb
	call	Swap2
	call	Move2
	call	Swap3
F_C3U	movlw	Unit1		; nF
	goto	pmsg		; includes RETURN
F_C4	SWAPF	bcd+2,W		; Digit1 == 0 ?
	ANDLW	0x0F
	bne	NoB1_C
	MOVLW	0x20		; YES PRINT A SPACE
	call	DATS
	MOVF	bcd+2,W		; Digit2 == 0 ?
	ANDLW	0x0F
	bne	NoB2_C
	call	DATS
	bra	NoB3_C
NoB1_C	call	Swap2		; 1
NoB2_C	call	Move2		; 2
NoB3_C	call	Swap3		; 3
	call	Move3		; 4
	movlw	Unit2		; pF
;	Formatted display of BCD work area for Inductor
L_disp
F_L1	MOVF	bcd+0,W
	ANDLW	0x0F
	beq	F_L2
	CALL	PutNyb
	call	Swap1
	call	Move1
	call	Swap2
	goto	F_L2U		; Print mH. includes RETURN
F_L2	swapf	bcd+1,W
	ANDLW	0x0F
	beq	F_L3
	CALL	PutNyb
	call	Move1
	call	Swap2
	call	Move2
F_L2U	movlw	Unit3		; mH
F_L3	MOVF	bcd+1,W
	ANDLW	0x0F
	beq	F_L4
	CALL	PutNyb
	call	Swap2
	call	Move2
	call	Swap3
	goto	F_L4U		; Print uH. includes RETURN
F_L4	SWAPF	bcd+2,W		; Digit1 == 0 ?
	ANDLW	0x0F
	bne	NoB1_L
	call	DATS
	goto	NoB2_L
NoB1_L	call	Swap2		; 1
NoB2_L	call	Move2		; 2
	call	Swap3		; 3
	call	Move3		; 4
F_L4U	movlw	Unit4		; uH
;	Common subroutine for formatted output
DoDP	MOVLW	'.'		; Print DP
	goto	DATS		; Return from DATS
Swap0	SWAPF	bcd+0,W		; GET NEXT DIGIT
	goto	PutNyb		; DISPLAY IT
Move0	MOVF	bcd+0,W		; GET OTHER BCD DIGIT
	goto	PutNyb
Swap1	SWAPF	bcd+1,W
	goto	PutNyb
Move1	MOVF	bcd+1,W
	goto	PutNyb
Swap2	SWAPF	bcd+2,W
	goto	PutNyb
Move2	MOVF	bcd+2,W
	goto	PutNyb
Swap3	SWAPF	bcd+3,W
	goto	PutNyb
Move3	MOVF	bcd+3,W
	goto	PutNyb
;	Stack operations
;add		call	FPA24
;		goto	S_fix
subtract	call	FPS24
		goto	S_fix
divide		call	FPD24
		goto	S_fix
multiply	call	FPM24
;		goto	S_fix
;	Fix stack after add, subtract, divide & multiply
S_fix	MOVF	CARGB1,W	; C -> B
	MOVWF	BARGB1
	MOVF	CARGB0,W
	MOVWF	BARGB0
	MOVF	CEXP,W
	MOVWF	BEXP
	return
;	Push stack (duplicates TOS)
S_push	MOVF	BARGB1,W	; B -> C
	MOVWF	CARGB1
	MOVF	BARGB0,W
	MOVWF	CARGB0
	MOVF	BEXP,W
	MOVWF	CEXP
	MOVF	AARGB1,W	; A -> B
	MOVWF	BARGB1
	MOVF	AARGB0,W
	MOVWF	BARGB0
	MOVF	AEXP,W
	MOVWF	BEXP
	return
;	Swap A and B
S_swap	MOVF	AARGB1,W	; A -> EEADR (temp)
	MOVWF	EAD
	MOVF	BARGB1,W	; B -> A
	MOVWF	AARGB1
	MOVF	EAD,W		; EEADR (temp) -> B
	MOVWF	BARGB1
	MOVF	AARGB0,W	; A -> EEADR (temp)
	MOVWF	EAD
	MOVF	BARGB0,W	; B -> A
	MOVWF	AARGB0
	MOVWF	BARGB0
	MOVF	AEXP,W		; A -> EEADR (temp)
	MOVWF	EAD
	MOVF	BEXP,W		; B -> A
	MOVWF	AEXP
	MOVWF	BEXP
	return
;	Calculate Unknown Capacitance OR inductance
;       Output: 24 bit positive integer (scaled)
;	right justified in AARGB0, AARGB1, AARGB2
;	also as BCD in bcd:bcd+1:bcd+2:bcd+3
C_calc	call	divide
	call	Get_Ccal	; Times 10,000 ( = 1000.0pF)
	call	multiply
	goto	PorM		; includes return
L_calc	call	multiply
	call	Get_Lcal	; Precomputed 1/(Ccal*4*PI*PI)
	call	multiply
L_divF1	call	Get_F1		; Divide by F1^2
	call	S_push
	call	multiply
	call	S_swap
	call	divide
;	Handle space or - in front of FP number
PorM	btfss	AARGB0,7	; test sign
	goto	Pplus
Pminus	movlw	0x2d		; minus
	goto	PMdisp
Pplus	movlw	0x20		; plus
PMdisp	call	DATS		; print it
	bcf	AARGB0,7	; make plus anyway
;	Format as raw BCD string in bcd:bcd+1:bcd+2:bcd+3
	call	INT2424		; To INT in AARGB0 etc.
	goto	B2_BCD		; includes return
;	Calculate (F1/F3)^2-1, leave result on stack
F1_F3	call	Get_F3
	goto	F1_F1
;	Calculate (F1/F2)^2-1, leave result on stack
F1_F2	call	Get_F2
F1_F1	call	Get_F1
	call	divide		; F1/Fx
	call	S_push
	call	multiply		; (F1/Fx)^2
	call	Get_One
	call	S_swap
	goto	subtract	; (F1/Fx)^2-1
				; includes return
;	Fetch assorted things used for the calculation
;	of Unknown L and C
Get_Lcal	call	S_push		; make room first
		movlw	0xAB		; 2.53303e+13
		movwf	AEXP		; Create FP version of
		movlw	0x38		; Precomputed 1/(Ccal*4*PI*PI)
		movwf	AARGB0		; times any needed
		movlw	0x4D		; fiddle factor (1/100)
		goto	B1_2_stak
Get_Ccal	call	S_push		; make room first
		movlw	0x8c		; 10,000
		movlw	0x1C		; Precomputed Ccal
		movlw	0x40		; fiddle factor
B1_2_stak	movwf	AARGB1
		return
Get_One		call	S_push		; make room first
		clrf	AEXP		; Create a binary 1
		clrf	AARGB0
		clrf	AARGB1
		movlw	0x01
		goto	LSB2stak
Get_F1		movlw	F1		; Includes stack push
		goto	W2stak
Get_F2		movlw	F2		; Includes stack push
		goto	W2stak
Get_F3		movlw	F3		; Includes stack push
;		goto	W2stak
;	Copy 16 bit number, pointed to by W, to stack
;	and convert to FP (positive value only)
;	via a 24 bit number in AARGB0,1,2
W2stak		movwf	FSR
		clrf	AEXP
		clrf	AARGB0
		movf	INDF,W		; Big Byte first
		movwf	AARGB1
		incf	FSR,F		; then little byte
		movf	INDF,W
LSB2stak	movwf	AARGB2
		goto	FLO2424		; 24 bit int -> 24 bit FP
	INCLUDE <FP.TXT>
 	END
