LIST P=18F4321
#include "P18F4321.INC" 
TEMPW		EQU		0x020	; TEMPW
LO			EQU		0x021	; DELAY LO
HI			EQU		0x022	; DELAY HI
INTLO		EQU		0x023
INTHI		EQU		0x024
NUM			EQU		0x025
I2CDATA		EQU		0x026
TCNTEMPINT	EQU		0x027
TCNCONFIG	EQU		0x028	
			ORG		0x0000
			GOTO	INIT
; INIT
INIT:
			MOVLW	B'01100101'			; OSCILLATOR frekvenciája 4MHz
			MOVWF	OSCCON				;
			MOVLW	B'00001111'			; anlóg/digitális bemenetek kiválasztása
			MOVWF	ADCON1				;	
			MOVLW	B'00000000'			;
			MOVWF	TRISE				;
			MOVLW	B'00011000'			;
			MOVWF	TRISC				;
			CALL	LCDINIT				; LCD BEÁLLÍTÁS
			CALL	LCDCRSOFF			;
			CALL	I2CINIT				; I2C BEÁLLÍTÁS
			MOVLW	b'00000000'			; MINDEN ALAPRA
			CALL	TCNSETCONFIG
; MAIN
MAIN:		CALL	LCDCLR				; LCD TÖTLÉSE
			CALL	LCDHOME0			; LCD HOME
			MOVLW	'T'					; 'T=' KIÍRÁSA
			CALL	LCDCHAR				;	
			MOVLW	'='					;
			CALL	LCDCHAR				;
			CALL	TCNREADTEMP			; HŐMÉRÉKLET OLVASÁSA
			MOVF	TCNTEMPINT,WREG		; INTLO = TCNTEMPINT
			MOVWF	INTLO				;
			CLRF	INTHI				; INTHI = 0
			CALL	INTTOSTR			;
			MOVLW	b'11011111'			; A FOK ASCII KÓDJA
			CALL	LCDCHAR				;
			MOVLW	'C'					;
			CALL	LCDCHAR				;
			CALL	PROGRESSBAR			; SZÜNET
			GOTO	MAIN				;
; PROGRESSBAR: PONTOKAT ÍR AZ LCD-RE AZ ÚJ MÉRÉSIG
PROGRESSBAR:CALL	LCDHOME1			;
			MOVLW	0x0A				;
			MOVWF	NUM					;
BCCK		MOVLW	'.'					;
			CALL	LCDCHAR				;
			CALL	DELAYLCD			;
			DECFSZ	NUM					;
			GOTO	BCCK					;
			RETURN
; TCN75 RUTINOK
; USES: TCNCONFIG, TCNTEMPINT
; TCNSETCONFIG: CONFIGURATION REGISTER = W
; TCNREADTEMP: TCNTEMPINT = TEMERATURE REGISTER (!CSAK A HI-BYTE)
;TCN75 ADDRESS: [A7:A4]=FIX(1001b), [A3:A1]=SLAVE(000b), [A0]=W/R
#define TCNWADDRESS		b'10010000'		; CÍM ÍRÁSRA
#define TCNRADDRESS		b'10010001'		; CÍM OLVASÁSRA
#define TCNTEMPREG		0x00			; TEPERATURE REGISTER
#define TCNCONFIGREG	0x01			; CONFIGURATION REGISTER
#define TCNHYSTREG		0x02			; HYSTERESIS REGISTER
#define TCNPOINTREG		0x03			; SET POINT REGISTER
TCNSETCONFIG:
			MOVWF	TCNCONFIG
			CALL	I2CSTART
			MOVLW	TCNWADDRESS
			CALL	I2CWRITE
			MOVLW	TCNCONFIGREG
			CALL	I2CWRITE
			CALL	I2CSTOP
			CALL	I2CSTART
			MOVLW	TCNWADDRESS
			CALL	I2CWRITE
			MOVF	TCNCONFIG,WREG
			CALL	I2CWRITE
			CALL	I2CSTOP
			RETURN
; TCNREADTEMP: KIOLVASSA A TEMERATUR REGISTERT
; ! A TEMPERATURE REGISTER HI BYTE TARTALMA KERÜL A TCNTEMPINT-BE, 
; ! ÍGY KIEJTJÜK A 0.5 C FOKOT ÉS EGÉSZKÉNT KAPJUK A HŐMÉRSÉKLETET 
; ! KETTES KOMPLEMENSBEN.
TCNREADTEMP:CALL	I2CSTART
			MOVLW	TCNWADDRESS
			CALL	I2CWRITE
			MOVLW	TCNTEMPREG
			CALL	I2CWRITE
			CALL	I2CSTOP
			CALL	I2CSTART
			MOVLW	TCNRADDRESS
			CALL	I2CWRITE
			CALL	I2CREAD					; HI BYTE OLVASÁSA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
			MOVWF	TCNTEMPINT				; TCNTEMPINT = HI!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
			CALL	I2CREAD
			CALL	I2CSTOP
			RETURN
; I2C RUTINOK
; USES: I2CDATA
; I2CINIT		: 100 kHz, MASTERMODE
; I2CSTART		: START	KÜLDÉSE
; I2CSTOP		: STOP KÜLDÉSE
; I2CWRITE		: W KIÍRÁSA I2CBUS-RA ÉS I2CDATA-BA
; I2CREAD		: I2CBUS OLVASÁSA W-BE ÉS I2CDATA-BA
; I2CWAIT		: VÁRAKOZÁS, AMÍG A BUS FOGLALT 
; I2CCHECKACK	: NYUGTA ELLENŐRZÉS, HIBA ESETÉN GOTO I2CHALT
; I2CHALT		: PROGRAM LEÁLLÍTÁS I2CACK MIATT, HIBA AZ LCD-RE
#define		FOSC 		.4000
#define		BAUD 		.100
#define 	I2CTRIS	TRISC
#define 	I2CSCL		3
#define 	I2CSDA		4
; I2CINIT: 100 kHz, MASTERMODE
I2CINIT:	BSF		I2CTRIS, I2CSCL			; SCL KIMENET
			BSF		I2CTRIS, I2CSDA			; SDA KIMENET
			MOVLW	b'10000000'				; STANDARD MODE
			MOVWF	SSPSTAT					; SET
			MOVLW	FOSC/(4*BAUD)-1			; 100 kHz
			MOVWF	SSPADD					; SET
			MOVLW	b'00111000'				; SSPEN, MASTERMODE
			MOVWF	SSPCON1					; SET
			RETURN
; I2CSTART: START KÜLDÉSE
I2CSTART:	BSF		SSPCON2, SEN			; START BIT
			BTFSC	SSPCON2, SEN			; KÉSZ?
			GOTO	$-1
			RETURN
; I2CSTOP: STOP KÜLDÉSE
I2CSTOP:	BSF		SSPCON2,PEN				; STOP BIT
			BTFSC	SSPCON2,PEN				; KÉSZ?
			GOTO	$-1
			RETURN
; I2CWRITE: W KIÍRÁSA I2CBUS-RA ÉS I2CDATA-BA
I2CWRITE:	MOVWF	I2CDATA					; I2CDATA = W
			CALL	I2CWAIT					; VÁRAKOZÁS
			MOVF	I2CDATA,WREG			; W = I2CDATA
			MOVWF	SSPBUF					; SSPBUF = W
			BTFSC	SSPSTAT, R_W			; ÍRÁS KÉSZ?
			GOTO	$-1						;
			CALL	I2CCHECKACK				; ACK ?
			RETURN
; I2CREAD: I2CBUS OLVASÁSA W-BE ÉS I2CDATA-BA
I2CREAD:	CALL	I2CWAIT
			BSF		SSPCON2, RCEN			; OLVASÁS
			BTFSC	SSPCON2, RCEN			; KÉSZ?
			GOTO	$-1						;
			MOVF	SSPBUF,WREG				; W = SSPBUF
			RETURN
; I2CWAIT: VÁRAKOZÁS, AMÍG A BUS FOGLALT 
I2CWAIT:	BTFSC 	SSPSTAT,R_W 			; R/W SZABAD ? 
BBCK		GOTO 	$-1 					;
			MOVF	SSPCON2,WREG			; W = SSPCON2 
			ANDLW	0x1F 					; TEST ACKEN,RCEN,PEN,RSEN,SEN 
			BTFSS	STATUS,Z 				; SZABAD ?
			GOTO	BBCK 					;
			RETURN 
; I2CCHECKACK: NYUGTA ELLENŐRZÉS, HIBA ESETÉN GOTO I2CHALT
I2CCHECKACK:BTFSC	SSPCON2, ACKSTAT		; ACK ?
			GOTO	I2CHALT					; LEÁLLÁS
			RETURN
; I2CHALT: PROGRAM LEÁLLÍTÁS I2CACK MIATT, HIBA AZ LCD-RE
I2CHALT:	CALL	LCDCLR
			CALL	LCDHOME0
			MOVLW	'E'
			CALL	LCDCHAR
			MOVLW	':'
			CALL	LCDCHAR
			MOVLW	'A'
			CALL	LCDCHAR
			MOVLW	'C'
			CALL	LCDCHAR
			MOVLW	'K'
			CALL	LCDCHAR
			MOVLW	' '
			CALL	LCDCHAR
			MOVLW	'H'
			CALL	LCDCHAR
			MOVLW	'A'
			CALL	LCDCHAR
			MOVLW	'L'
			CALL	LCDCHAR
			MOVLW	'T'
			CALL	LCDCHAR
			GOTO	$
			RETURN
; LCD RUTINOK
; LCDCHAR:		A W-BEN LEVŐ ADATOT AZ LCD AKTUÁLIS POZÍCIÓJÁBA ÍRJA
; LCDCMD:		A W-BEN LEVŐ UTASÍTÁS KÜLDÉSE AZ LCD-NEK
; LCDWAIT: 		VÁRAKOZÁS AMÍG AZ LCD FOGLALT
; LCDINIT: 		LCD BEÁLLÍTÁS 8BIT, 2SOR, 5×7DOTS, INCREMENT, DISPLAY SHIFT OFF,
;		LCDCLR, LCDHOME0, LCDCRSON
; LCDCLR: 		KIJELZŐ TÖLÉSE
; LCDHOME0: 	CURSOR LINE0 HOME
; LCDHOME1: 	CURSOR LINE1 HOME
; LCDCRSON: 	DISPLAY ON, CURSOR ON, BLINK ON, CURSOR RIGHT SHIFT
; LCDCRSOFF: 	DISPLAY ON, CURSOR OFF, BLINK OFF
#define		LCDBUSTRIS	TRISB			; ADATBUSZ TRIS
#define		LCDCTRLTRIS	TRISE			; VEZÉRLŐ TRIS
#define		LCDBUS	 	PORTB			; AZ LCD ARATBUSZA
#define		LCDCTRL		PORTE			; AZ LCD VEZÉRLŐ VONALAI 
#define		RS		0					; PARANCS/ADAT VONAL 
#define		RW		1					; READ/WRITE VONAL
#define		EN		2					; ENGEDÉLYEZŐVONAL
#define 	LINE0		0x00			; LCD 1 SOR CÍME
#define		LINE1		0x40			; LCD 2 SOR CÍME
LCDCHAR:	MOVWF	TEMPW				; TEMPW = W
			CALL	LCDWAIT				; VÁRAKOZÁS AZ LCD-re
			MOVF	TEMPW,	WREG		; W = TEMPW
			MOVWF	LCDBUS				; LCDBUS = W
			BSF		PORTE,0				; RS = 1 (PARANCS/ADAT)
			BCF		PORTE,1				; RW = 0 (ÍRÁS/OLVASÁS)
			BSF		PORTE,2				; EN = 1 (ADÁS KEZD)		
			NOP							;
			BCF		PORTE,2				; EN = 0 (ADÁS VÉGE)
			RETURN						;
LCDCMD:		MOVWF	TEMPW				; TEMPW = W
			BCF		PORTE,0				; RS = 0 (PARANCS/ADAT)
			NOP							;			
			RETURN						;
LCDWAIT:	MOVLW	0xFF				; LCDBUS OLVASÁSRA
			MOVWF	LCDBUSTRIS			; .
			BSF		PORTE,1				; RW = 1 (ÍRÁS/OLVASÁS)
			MOVF	LCDBUS,	WREG		; W = BUSYFLAG ÉS ADDRESS
			ANDLW	0x80				; BUSYFLAG == 1 AKKOR VISSZA 
			BTFSS	STATUS, Z			; .
			GOTO	LCDWAIT				; .	
			CLRF	LCDBUSTRIS			; LCDBUS ÍRÁSRA		
			RETURN
LCDINIT:	MOVLW	B'00111000'			; 8-BIT, 2-SOR, 5×7 DOTS 
			CALL	LCDCMD				; FUNCTION SET
			MOVLW	B'00001000'			; DISPLAY OFF
			CALL	LCDCMD				; DISPLAY CONTROL
			MOVLW	B'00000110'			; INCREMENT, DISPLAY SHIFT OFF
			CALL	LCDCMD				; ENTRY MODE SET
			CALL	LCDCLR				; DISPLAY CLEAR
			CALL	LCDHOME0			; HOME
			CALL	LCDCRSON			; DISPLAY ON, CURSOR ON, BLINK ON
LCDCLR:		MOVLW	B'00000001'			; TÖRLÉS PARANCS
			CALL	LCDCMD
			RETURN
LCDHOME0:	MOVLW	B'00000010'			; KIJELZŐ ÉS KURZOR ALAPHELYZETBE
			CALL	LCDCMD
			RETURN
LCDHOME1:	MOVLW	LINE1				; 2-SOR CÍME
			IORLW	0x80				; OR DDRAM ADDRESS UTASÍTÁS	
			CALL	LCDCMD				;
			RETURN
LCDCRSON:	MOVLW	B'00001111'			; DISPLAY ON, CURSOR OFF
			MOVLW	B'00011100'			; CURSOR SHIFT, SHIFT RIGHT
			CALL	LCDCMD				;
			RETURN
LCDCRSOFF:	MOVLW	B'00001100'			; DISPLAY ON, CURSOR OFF, BLINK OFF
			RETURN						;
		; DELAYLCD: SZÜNET AMÍG AZ LCD 'FELÁLL'
DELAYLCD:	CLRF	LO
			CLRF	HI
BCK			DECFSZ 	LO
			GOTO	$-1
			DECFSZ	HI
			GOTO	BCK
			RETURN                                               
; MATH
	SAC1	EQU	0x40
	SAC2	EQU	0x41
	SAC3	EQU	0x42
	SAC4	EQU	0x43
	ARG1	EQU	0x44
	ARG2	EQU	0x45
	ARG3	EQU	0x46
	ARG4	EQU	0x47
	REM1	EQU	0x48
	REM2	EQU	0x49
	REM3	EQU	0x4A
	REM4	EQU	0x4B
	LOOP	EQU	0x4C
; INTTOSTR: EGÉSZ-STRING KONVERZIÓ (!CSAK KÉT DECIMÁLIS DIGITRE)
INTTOSTR:	BTFSS	INTLO,7				; ELŐJEL NEGATÍV?
			GOTO	POSITIV				;
			COMF	INTLO, f			; INTLO = NOT(INTLO)
			INCF	INTLO, f			; INTLO = INTLO+1
			MOVLW	'-'					;
			CALL	LCDCHAR				;
POSITIV:								;
			CALL	FLUSH32				;
			MOVF	INTLO,WREG			; SAC = INTLO:INTHI
			MOVWF	SAC1				;
			MOVF	INTHI,WREG			;
			MOVF	SAC2,WREG			;
			MOVLW	LOW .10				; ARG = 10
			MOVWF	ARG1				;
			MOVLW	HIGH .10			;
			MOVWF	ARG2				;
			CALL	DIV16				; DIV16
			MOVF	SAC1,WREG			; 
			ADDLW	.48					; ASCII(W)
			CALL	LCDCHAR				;
			CALL	MUL16				; SAC= SAC-((SAC DIV 10) MUL 10)
			MOVF	SAC1,WREG			;
			MOVWF	ARG1				;
			MOVF	SAC2,WREG			;
			MOVWF	ARG2				;
			MOVF	INTLO,WREG			;
			MOVWF	SAC1				;
			MOVF	INTHI,WREG			;
			MOVWF	SAC2				;
			CALL	SUB16				;	
			MOVF	SAC1,WREG			;
			CALL	LCDCHAR				;
			RETURN
; SUB16: 16 BITES EGÉSZ KIVONÁS
; SAC = SAC - ARG
SUB16:		MOVF	ARG1,WREG
			SUBWF	SAC1,F
			MOVF	ARG2,WREG
			BTFSS	STATUS,C
			INCFSZ	ARG2,W
			SUBWF	SAC2,F
			RETURN
; MUL16: 16 BITES EGÉSZ SZORZÁS
; SAC = SAC * ARG
MUL16:		CLRF 	REM4
			CLRF	REM3
			CLRF 	REM2
			MOVLW  	0x80
			MOVWF	REM1
			RRCF    SAC2,F
			RRCF    SAC1,F
			BTFSS  	STATUS,C
			GOTO   	$+.10
			MOVF   	ARG1,W
			ADDWF  	REM2,F
			MOVF   	ARG2,W
			BTFSC  	STATUS,C
			INCFSZ 	ARG2,W
			ADDWF  	REM3,F
			BTFSC  	STATUS,C
			INCF   	REM4,F
			BTFSS  	SAC1,7
			GOTO   	UPS
			MOVF   	ARG1,W
			ADDWF  	REM3,F
			MOVF   	ARG2,W
			BTFSC  	STATUS,C
			INCFSZ 	ARG2,W
			ADDWF  	REM4,F
UPS			RRCF    REM4,F
			RRCF    REM3,F
			RRCF    REM2,F
			RRCF    REM1,F
			BTFSS  	STATUS,C
			GOTO   	$-.26
			MOVF	REM1,WREG
			MOVWF	SAC1
			MOVF	REM2,WREG
			MOVWF	SAC2
			RETURN
; 16 BITES EGÉSZ OSZTÁS
; SAC1:SAC2 = SAC1:SAC2 DIV ARG1:ARG2
DIV16:		CLRF   	REM1
			CLRF   	REM2
			MOVLW  	0x10
			MOVWF  	LOOP
			RLCF    SAC2,W
			RLCF    REM1,F
			RLCF    REM2,F
			MOVF   	ARG1,W
			SUBWF  	REM1,F
			MOVF   	ARG2,W
			BTFSS  	STATUS,C
			INCFSZ 	ARG2,W
			SUBWF  	REM2,F
			BTFSC  	STATUS,C
			GOTO   	$+0x08
			MOVF   	ARG1,W
			ADDWF  	REM1,F
			MOVF   	ARG2,W
			BTFSC  	STATUS,C
			INCFSZ 	ARG2,W
			ADDWF  	REM2,F
			BCF    	STATUS,C
			RLCF    SAC1,F
			RLCF    SAC2,F
			DECFSZ 	LOOP,F
			GOTO    $-0x15
			RETURN
; FLUSH32: MATH REIGSZETEREK TÖRLÉSE
FLUSH32:	CLRF	SAC1
			CLRF	SAC2
			CLRF	SAC3
			CLRF	SAC4
			CLRF	ARG1
			CLRF	ARG2
			CLRF	ARG3
			CLRF	ARG4
			RETURN
END
