LCDcenter2.0                                   v.0.2
          http://www.borderfield.com
	    incubus@shrimpwars.be
Requirements:
 - MatrixOrbital unit or lcdriver-compatible unit
 - mbm4 or 5
Features:
 - temperature and fan monitoring
 - voltage monitoring
 - uptime
 - date&time
 - cpu load
 - memory usage
 - diskspace usage
 - network traffic monitoring
 - new mail notification
Running the program:
 When LCDcenter starts, it will loop through the
 different screens defined in the ini file. Clicking
 any key on the LK202-25 will make the menu show up.
 Using the up and down arrows you can browse the menu.
 The left arrow's function is to return to a previous menu.
 The right arrow acts as an 'enter' key, activating the
 menu item on the first line of the display.
 The upper right key has the same function.
 The key below activates the menu item on the second line.
 Finally, the lower right key also serves as a return to
 previous menu key.
 The movie available at www.borderfield.com illustrates the
 use of the keys.
 More information: http://www.borderfield.com/lcdinstallation.php
Tested on a Matrix-Orbital LK202-25
If you experience problems or have suggestions,
contact me at:
Enjoy,
-Jo
