; Source created with Parsic Version 3.x
; at              : 2009.06.09. 19:29:25
; Project File    : C:\picprog\sebfut2.PIC
; Project Version : 1.0.40
; Created         : 2009.06.04. 17:28:00
; Last change     : 2009.06.09. 19:29:23
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_OFF & _WDT_OFF & _BODEN_OFF & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV3	= 32	; located in Bank 0
ZV3_FD	= 33	; located in Bank 0
ZV3_HI	= 34	; located in Bank 0
EE1_FD	= 35	; located in Bank 0
ZV1	= 36	; located in Bank 0
ZV1_FD	= 37	; located in Bank 0
S1	= 38	; located in Bank 0
S0	= 39	; located in Bank 0
S0_HI	= 40	; located in Bank 0
TR1	= 41	; located in Bank 0
TR1_HI	= 42	; located in Bank 0
ZV2	= 43	; located in Bank 0
ZV2_HI	= 44	; located in Bank 0
ZV2_FD	= 45	; located in Bank 0
OS1_FD	= 46	; located in Bank 0
MF1	= 47	; located in Bank 0
MF1_HI	= 48	; located in Bank 0
MF1_FD	= 49	; located in Bank 0
S2	= 50	; located in Bank 0
OS2_FD	= 51	; located in Bank 0
RAM	= 52	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 113	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 115	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_1
	INCF MF1_HI,F
SYS_INT_LABEL_1
EXITINT
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
EEINT_WRITE
	MOVFW INDF
EEINT_WRITE_0
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF EEDATA
	BSF EECON1,WREN
EEINT_DISINT
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO EEINT_DISINT
	MOVLW H'55'
	MOVWF EECON2
	MOVLW H'AA'
	MOVWF EECON2
	BSF EECON1,WR	; start write
	BSF INTCON,GIE
EEINT_WRITE_1
	BTFSC EECON1,WR	; ready ?
	GOTO EEINT_WRITE_1	; no
	BCF EECON1,WREN
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_WRITE
	RETURN
EEINT_READ
	BSF EECON1,RD
	MOVFW EEDATA
	MOVWF INDF
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_READ
	RETURN
; EE-Modul -> EE1
WRITE_EE1
	MOVLW 0
	MOVWF EEADR
	BCF STATUS,IRP	; vars - located in Bank 0
	MOVLW 3
	MOVWF SYS_TMP1
	MOVLW LOW ZV3
	MOVWF FSR
	CALL EEINT_WRITE
	RETURN
; EE-Modul -> EE1
READ_EE1
	MOVLW 0
	MOVWF EEADR
	MOVLW 3
	MOVWF SYS_TMP1
	MOVLW LOW ZV3
	MOVWF FSR
	CALL EEINT_READ
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'10000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 143
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'00111111'
	MOVWF TRISA
	MOVLW B'01110000'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CALL READ_EE1	; read vars from internal EE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
	BTFSS S1,1	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S1,6
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S1,0	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S1,6
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S1,1	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVLW 12
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 12
LABEL_ST1_TEST
	SUBWF ZV1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S1,1	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S1,1	; if less
LABEL_ST1_ENDE
; Call subroutine TAB
	MOVLW LOW TAB
	MOVWF SYS_TMP1
	MOVLW HIGH TAB
	MOVWF SYS_TMP2
	BCF STATUS,CARRY
	RLF ZV1,W
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S0
	INCF SYS_TMP1,F
	BTFSC STATUS,ZERO
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S0_HI
	BSF INTCON,GIE
; Verteiler -> BV1
	BTFSC S0,0
	GOTO LABEL_BV1_0
	BCF PORTB,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTB,0
LABEL_BV1_0_END
	BTFSC S0,1
	GOTO LABEL_BV1_1
	BCF PORTB,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTB,1
LABEL_BV1_1_END
	BTFSC S0,2
	GOTO LABEL_BV1_2
	BCF PORTB,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTB,2
LABEL_BV1_2_END
	BTFSC S0,3
	GOTO LABEL_BV1_3
	BCF PORTB,3
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTB,3
LABEL_BV1_3_END
	BTFSC S0,4
	GOTO LABEL_BV1_4
	BCF PORTB,7
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BSF PORTB,7
LABEL_BV1_4_END
; RS-FLIP-FLOP -> RS1
	BTFSC PORTB,0
	GOTO LABEL_RS1_RESET
	BTFSS PORTB,7
	GOTO LABEL_RS1_ENDE
	BSF S1,0	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S1,0	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 98
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 98
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S1,2
	GOTO LABEL_TR1_CLR
	BSF S1,2
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S1,2
LABEL_TR1_ENDE
; Zähler -> ZV2
	BTFSS S1,7	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	CLRF ZV2_HI
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S1,2
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	BTFSC S1,3	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV2_BACKWARD
	INCFSZ ZV2,F
	INCF ZV2_HI,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
	INCFSZ ZV2,W
	DECF ZV2_HI,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S1,2
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; GND
	BCF S1,3	; immer Low
; One Shot -> OS1
	BTFSS PORTA,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S1,4
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S1,4
	BTFSC PORTA,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; Zähler -> ZV3
	BTFSS S2,1	; Reset ?
	GOTO LABEL_ZV3_COUNT
	CLRF ZV3
	CLRF ZV3_HI
	GOTO LABEL_ZV3_SETOUT
LABEL_ZV3_COUNT
	BTFSS S1,4
	GOTO LABEL_ZV3_SETFD
	BTFSC ZV3_FD,0
	BSF ZV3_FD,0
	BTFSC S1,5	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV3_BACKWARD
	INCFSZ ZV3,F
	INCF ZV3_HI,F
LABEL_ZV3_BACKWARD
	DECF ZV3,F
	INCFSZ ZV3,W
	DECF ZV3_HI,F
LABEL_ZV3_SETOUT
LABEL_ZV3_SETFD
	BTFSC S1,4
	GOTO LABEL_ZV3_EXIT
	BCF ZV3_FD,0
LABEL_ZV3_EXIT
; GND
	BCF S1,5	; immer Low
; Schmitt-Trigger 16-Bit -> ST2
	MOVFW ZV3
	MOVWF SYS_TMP1
	MOVFW ZV3_HI
	MOVWF SYS_TMP2
	BTFSS S1,7	; Ausgang gesetzt ?
	GOTO LABEL_ST2_TEST	; without Hysterese
	MOVLW HIGH 0
	SUBWF SYS_TMP2,F
	MOVLW LOW 0
	SUBWF SYS_TMP1,F
	BTFSS STATUS,CARRY
	DECF SYS_TMP2,F
LABEL_ST2_TEST
	MOVFW SYS_TMP2
	SUBWF ZV2_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_ST2_TEST2
	MOVFW SYS_TMP1
	SUBWF ZV2,W
LABEL_ST2_TEST2
	BTFSS STATUS,CARRY
	GOTO LABEL_ST2_RESET
LABEL_ST2_SET
	BSF S1,7	; if greater or equal
	GOTO LABEL_ST2_ENDE
LABEL_ST2_RESET
	BCF S1,7	; if less
LABEL_ST2_ENDE
; Mono-Flop -> MF1
; Läuft der Impuls ?
	BTFSC MF1_FD,1
	GOTO LABEL_MF1_CHKTIME
	BTFSC MF1_FD,0
	GOTO LABEL_MF1_SETFD
	BTFSS S2,0
LABEL_MF1_RESET
	CLRF MF1
	CLRF MF1_HI
	BSF MF1_FD,1
	BSF S1,6
LABEL_MF1_CHKTIME
	MOVLW 0
	SUBWF MF1_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF1_CHECK
	MOVLW 78
	SUBWF MF1,W
LABEL_MF1_CHECK
	BTFSS STATUS,CARRY
LABEL_MF1_TO
	BCF MF1_FD,1
	BCF S1,6
LABEL_MF1_SETFD
	BTFSS S2,0
	GOTO LABEL_MF1_CLR
	BSF MF1_FD,0
	GOTO LABEL_MF1_ENDE
LABEL_MF1_CLR
	BCF MF1_FD,0
LABEL_MF1_ENDE
; ODER - Gatter -> LG1
LABEL_LG1_1
	BTFSC S1,7
	GOTO LABEL_LG1_TRUE
LABEL_LG1_FALSE
	BCF S2,0
	GOTO LABEL_LG1_ENDE
LABEL_LG1_TRUE
	BSF S2,0
LABEL_LG1_ENDE
; EE-Modul -> EE1
; Test of rising edge
	BTFSS S1,4
	GOTO LABEL_EE1_SETFD
	BTFSC EE1_FD,0
	BSF EE1_FD,0
	CALL WRITE_EE1
LABEL_EE1_SETFD
; test input
	BTFSC S1,4
	GOTO LABEL_EE1_EXIT
	BCF EE1_FD,0
LABEL_EE1_EXIT
; Vergleich -> IF1
	MOVLW 6
	SUBWF ZV3,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S2,1
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S2,1
LABEL_IF1_EXIT
; RS-FLIP-FLOP -> RS2
	BTFSC S2,3
	GOTO LABEL_RS2_RESET
	BTFSS S2,4
	GOTO LABEL_RS2_ENDE
	BSF S2,2	; Ausgang setzen
	GOTO LABEL_RS2_ENDE
LABEL_RS2_RESET
	BCF S2,2	; Ausgang zurücksetzen
LABEL_RS2_ENDE
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S2,2
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSS S2,5
LABEL_LG2_TRUE
	BSF S2,3
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S2,3
LABEL_LG2_ENDE
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S2,5
	GOTO LABEL_LG3_FALSE
LABEL_LG3_2
	BTFSC S2,2
LABEL_LG3_TRUE
	BSF S2,4
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF S2,4
LABEL_LG3_ENDE
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S2,2
	GOTO LABEL_LG4_FALSE
LABEL_LG4_TRUE
	BSF PORTA,6
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF PORTA,6
LABEL_LG4_ENDE
; ODER - Gatter -> LG5
LABEL_LG5_1
	BTFSC S2,2
	GOTO LABEL_LG5_TRUE
LABEL_LG5_FALSE
	BSF PORTA,7
	GOTO LABEL_LG5_ENDE
LABEL_LG5_TRUE
	BCF PORTA,7
LABEL_LG5_ENDE
; One Shot -> OS2
	BTFSS PORTB,0
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S2,5
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S2,5
	BTFSC PORTB,0
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
	GOTO MAIN
; Table -> TAB
TAB
	RETLW 1	; // INDEX 0
	RETLW 0	; // INDEX 0
	RETLW 2	; // INDEX 1
	RETLW 0	; // INDEX 1
	RETLW 4	; // INDEX 2
	RETLW 0	; // INDEX 2
	RETLW 8	; // INDEX 3
	RETLW 0	; // INDEX 3
	RETLW 16	; // INDEX 4
	RETLW 0	; // INDEX 4
	RETLW 32	; // INDEX 5
	RETLW 0	; // INDEX 5
	RETLW 64	; // INDEX 6
	RETLW 0	; // INDEX 6
	RETLW 128	; // INDEX 7
	RETLW 0	; // INDEX 7
	RETLW 0	; // INDEX 8
	RETLW 1	; // INDEX 8
	RETLW 0	; // INDEX 9
	RETLW 2	; // INDEX 9
	RETLW 0	; // INDEX 10
	RETLW 4	; // INDEX 10
	RETLW 0	; // INDEX 11
	RETLW 8	; // INDEX 11
	ORG H'2100'
	DE 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	END
