#include <12F675.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOCPD                    //No EE protection
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES PUT                      //Power Up Timer
#FUSES BROWNOUT                 //Reset when brownout detected
#FUSES BANDGAP_HIGH          
#use delay(clock=4000000)
#define LED PIN_A1
#int_TIMER0
volatile int8 i=50;
volatile int1 timerflag=0;
void LED_on(void)
output_high(LED);
delay_ms(100);
output_low(LED);
void  TIMER0_isr(void) 
  if(--i==0)
   timerflag=1;
  set_timer0(178);
void main()
   setup_adc_ports(NO_ANALOGS|VSS_VDD);
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   clear_interrupt(INT_TIMER0);
   enable_interrupts(INT_TIMER0);
   enable_interrupts(GLOBAL);
  while(1)
      if(timerflag==1)
         LED_on();
  timerflag=0;
