/*       RTTTL Ring Tone Player for Microchip PIC16F87x Microcontrollers     */
/*                   Copyright Craig.Peacock@beyondlogic.org                 */
/*                       Version 1.0 17th August 2003                        */
#define TONE    RB0_bit
void InitTimer(void);
void delayms(unsigned char cnt);
void PlayNote(unsigned short note, unsigned char octave, unsigned int duration);
unsigned char beep;
unsigned char preloadTMR1L;
unsigned char preloadTMR1H;
unsigned short TMR0Count;
unsigned char beat_speed;
#define MissionImpossible
void main(void)
    unsigned int pointer = 0;
    unsigned int octave = 0;
    unsigned int duration = 0;
    unsigned short note = 0;
    unsigned int defaultoctave = 0;
    unsigned int defaultduration = 0;
#ifdef AxelF
    /* AxelF */
    const unsigned char static Melody[] = {"32p,8g,8p,16a#.,8p,16g,16p,16g,8c6,8g,8f,8g,8p,16d.6,8p,16g,16p,16g,8d#6,8d6,8a#,8g,8d6,8g6,16g,16f,16p,16f,8d,8a#,2g,4p,16f6,8d6,8c6,8a#,4g,8a#.,16g,16p,16g,8c6,8g,8f,4g,8d.6,16g,16p,16g,8d#6,86,8a#,8g,8d6,8g6,16g,16f,16p,16f,8d,8a#,2g"};
    defaultoctave = 5;
    defaultduration = 4;
    beat_speed = 125;
#endif
#ifdef HappyBirthday
    /* HappyBirthday */
    const unsigned char static Melody[] = {"8g.,16g,a,g,c6,2b,8g.,16g,a,g,d6,2c6,8g.,16g,g6,e6,c6,b,a,8f6.,16f6,e6,c6,d6,2c6,8g.,16g,a,g,c6,2b,8g.,16g,a,g,d6,2c6,8g.,16g,g6,e6,c6,b,a,8f6.,16f6,e6,c6,d6,2c6"};
    defaultoctave = 5;
    beat_speed = 125;
#endif
#ifdef Itchy
    /* Itchy & Scratcy */
    const unsigned char static Melody[] = {"8c,8a5,4p,8c,8a,4p,8c,a5,8c,a5,8c,8a,4p,8p,8c,8d,8e,8p,8e,8f,8g,4p,8d,8c,4d,8f,4a#,4a,2c7"};
    defaultoctave = 6;
    defaultduration = 8;
    beat_speed = 198;
#endif
#ifdef MissionImpossible
    /* Mission Impossible */
    const unsigned char static Melody[] = {"16d5,16d#5,16d5,16d#5,16d5,16d#5,16d5,16d5,16d#5,16e5,16f5,16f#5,16g5,8g5,4p,8g5,4p,8a#5,8p,8c6,8p,8g5,4p,8g5,4p,8f5,8p,8p,8g5,4p,4p,8a#5,8p,8c6,8p,8g5,4p,4p,8f5,8p,8f#5,8p,8a#5,8g5,1d5"};
    defaultoctave = 6;
    beat_speed = 150;
#endif
    TRISB0_bit = 0;     /* Make TONE an output */
    beep = 0;
    InitTimer();
    PEIE_bit = 1;
    GIE_bit = 1;      /* Enable General Purpose Interrupts */
    do {
        octave = defaultoctave; 	/* Set Default Octave */
        if ((Melody[pointer] == '3') && (Melody[pointer+1] == '2')) {
            duration = 32;
            pointer += 2;
        else if ((Melody[pointer] == '1') && (Melody[pointer+1] == '6')) {
            duration = 16;
            pointer += 2;
        else if (Melody[pointer] == '8') {
            duration = 8;
            pointer++;
        else if (Melody[pointer] == '4') {
            duration = 4;
            pointer++;
        else if (Melody[pointer] == '2') {
            duration = 2;
            pointer++;
        else if (Melody[pointer] == '1') {
            duration = 1;
            pointer++;
        } else duration = defaultduration;
        if (Melody[pointer + 1] == '#') {
            /* Process Sharps */
            switch (Melody[pointer]) {
                case 'a' : note = 10726;
                           break;
                case 'c' : note = 9019;
                           break;
                case 'd' : note = 8035;
                           break;
                case 'f' : note = 6757;
                           break;
                case 'g' : note = 6024;
                           break;
            pointer +=2;
        } else {
                case 'a' : note = 11364;
                           break;
                case 'b' : note = 10123;
                           break;
                case 'c' : note = 9555;
                           break;
                case 'd' : note = 8513;
                           break;
                case 'e' : note = 7584;
                           break;
                case 'f' : note = 7158;
                           break;
                case 'g' : note = 6378;
                           break;
                case 'p' : note = 0;
                           break;
            pointer++;
        if (Melody[pointer] == '.') {
            /* Duration 1.5x */
            duration = duration + 128;
            pointer++;
            octave = 4;
            pointer++;
        } else if (Melody[pointer] == '5') {
            octave = 5;
            pointer++;
        } else     if (Melody[pointer] == '6') {
            octave = 6;
            pointer++;
        } else     if (Melody[pointer] == '7') {
            octave = 7;
            pointer++;
            /* Duration 1.5x */
            pointer++;
        PlayNote(note, octave, duration);
     } while (Melody[pointer++] == ',');
    /* Wait until last note has played */
    while(TMR0Count) { };
    beep = 0;
    /* Loop */
    while(1) {};
    /* Process octave */
    switch (octave) {
        case 4 : /* Do noting */
             break;
        case 5 : /* %2 */
             note = note >> 1;
             break;
        case 6 : /* %4 */
             note = note >> 2;
             break;
        case 7 : /* %8 */
             note = note >> 4;
             break;
    beep = 0;
    /* Process New Note Frequency */
    if (note) {
        note = ~note;
        preloadTMR1L = (note & 0xFF);
        preloadTMR1H = ((note & 0xFF00) >> 8);
    /* Process Note Duration */
    TMR0Count = 255/(duration & 0x7F);
    /* If duration is 1.5x add .5 to duration */
    if (duration & 0x80) TMR0Count = (TMR0Count + (TMR0Count >> 1));
    if (note) beep = 1;
    /* Initialise Timer 0 */
    OPTION_REG = 0b11010111;  /* Set TMR0 to Internal CLk, 1:256 */
    T0IF_bit = 0;             /* Clear TMR0 Flag, ready for use */
    T0IE_bit = 1;             /* Enable Timer Overflow Interrupt */
    /* Initialise Timer 1 */
    T1CON = 0b00000001;   /* Counter Enabled, Using Ext Pin 1:1 Prescaler */
    TMR1IF_bit = 0;           /* Clear Flag */
    TMR1IE_bit = 1;           /* Enable Interrupt */
void interrupt(void)
    if (T0IF_bit) {
        TMR0 = beat_speed;
        if (TMR0Count) TMR0Count--;
        T0IF_bit = 0;
    if (TMR1IF_bit) {
        if (beep) TONE = !TONE;
        else      TONE = 0;
        TMR1H = preloadTMR1H;
        TMR1L = preloadTMR1L;
