;                         DIGITAL FREQUENCY COUNTER
;                           Author : Vicsys
;                           Version: 1.0
;                           Http://freki.atw.hu
;      lines 337 to 453 are an example of where to add personal introductory   
;      lines and should be omitted or changed to your own                   
	list p=16f628a
	include p16f628a.inc
	__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _PWRTE_OFF & _BODEN_OFF& _LVP_OFF 
;& _LVP_OFF & _CPD_OFF
INDF	equ	0h
rtcc	equ	1h
pc	equ	2h
status	equ	3h
fsr	equ	4h
port_a	equ	5h
port_b	equ	6h
;port_c	equ	7h
c	equ	0h
dc	equ	1h
z	equ	2h
pd	equ	3h
to	equ	4h
MSB	equ	7h
LSB	equ	0h
cnt	equ	2h  
rs	equ	2h
rw	equ	1h
e	equ	0h
o	equ	7h
count1	equ	3Eh
count2	equ	3Fh
count3  equ	40h
count4  equ     41h
in_reg	equ	42h 
addcnt	equ	43h
TEMP	equ	44h
gate	equ	20h
cnt1	equ	21h
cnt2	equ	22h
cnt3	equ	23h
calc1	equ	24h
calc2	equ	25h
calc3	equ	26h
sum1	equ	27h
sum2	equ	28h
sum3	equ	29h
rtcc2	equ	2Ah
	org	0
	goto	start
int_del	movlw	0x05		;delay 5.000 ms (4 MHz clock)
	movwf	count1
d1	movlw	0xA5
	movwf	count2
d2	decfsz	count2	,f
	goto	d2
	decfsz	count1	,f
	goto	d1
	retlw	0x00
lcd_out	movwf	port_b		;load data into port_b
	bsf   STATUS,RP0   	; select Register-Page 1**************************
	movlw	b'00000000'	;define port_b as output
	tris	port_b
	bcf   STATUS,RP0  	 ; select Register-Page 0 ************************
	bsf	port_a,rs	;rs = data
	bcf	port_a,rw	;r/w = write
	bsf	port_a,e	;toggle enable
	bcf	port_a,e
	movlw	b'11111111'	;define port_b as input
	tris	port_b
	bcf	port_a,rs	;rs = instruction
	bsf	port_a,rw	;r/w = read
	bsf	port_a,e	;enable high
	movf	port_b,w	;get address counter
	movwf	addcnt
	bsf	addcnt,7
	bcf	port_a,e	;enable low
out1	bsf	port_a,e	;enable high
	btfss	port_b,7	;test busy flag
	goto	out2
	goto	out1
out2	bcf	port_a,e	;enable low
	goto	shift
inst	movwf	port_b		;load instruction into port_b
	tris	port_b
	bcf	port_a,e
	tris	port_b
inst1	bsf	port_a,e	;enable high
	goto	inst2
	goto	inst1
inst2	bcf	port_a,e	;enable low
	retlw	0x00
shift	btfss	addcnt,0	;shift to opposite side of display?
	retlw	0x00
	btfss	addcnt,1
	retlw	0x00
	btfss	addcnt,2
	retlw	0x00
	btfss	addcnt,3
	retlw	0x00
	movlw	0x39
	addwf	addcnt,f
	bsf	addcnt,7
	movf	addcnt,w
	goto	inst
sub	bcf	TEMP,o	;clear overflow bit
	movf	calc1,w		;subtract calc1 from cnt1 
	subwf	cnt1	,f
	btfsc	status,c
	goto	sb1
	movlw	0x01		;borrow from cnt2 if overflow
	subwf	cnt2	,f
	btfsc	status,c
	goto	sb1
	subwf	cnt3	,f	;borrow from cnt3 if cnt2 overflow
	btfss	status,c
	bsf	TEMP,o	;set overflow bit if result is negative
sb1	movf	calc2,w		;subtract calc2 from cnt2
	subwf	cnt2	,f
	btfsc	status,c
	goto	sb2
	movlw	0x01		;borrow from cnt3 if cnt2 overflow
	subwf	cnt3	,f
	btfss	status,c
sb2	movf	calc3,w		;subtract calc3 from cnt3
	subwf	cnt3	,f
	btfss	status,c
	retlw	0x00
add	movf	calc1,w		;add calc1 to cnt1
	addwf	cnt1	,f
	btfss	status,c
	goto	ad1
	incfsz	cnt2	,f	;add to cnt2 if cnt1 overflow
	goto	ad1
	incf	cnt3	,f	;add to cnt3 if cnt2 overflow
ad1	movf	calc2,w		;add calc2 to cnt2
	addwf	cnt2	,f
	btfsc	status,c
	movf	calc3,w		;add calc3 to cnt3
	addwf	cnt3	,f
	retlw	0x00
cnvt	movlw	0x07		;7 digits in display
	movwf	count1
	movlw	0x2D		;set fsr for MSB in display
	movwf	fsr
	movlw	0x2F		;one less that ASCII &quot;0&quot;
cnvt0	movwf	INDF
	incf	fsr	,f
	decfsz	count1	,f
	goto	cnvt0
	movlw	0x0F		;load &quot;1,000,000&quot; in calc1-3
	movwf	calc3
	movlw	0x42
	movwf	calc2
	movlw	0x40
	movwf	calc1
cnvt1	call	sub		;subtract number from count
	incf	2D	,f	;increment 1,000,000's register
	movlw	0x3A
	xorwf	2D,w
	btfsc	status,z
	goto	overflow
	btfss	TEMP,o	;check if overflow
	goto	cnvt1
	call	add		;add back last number
	movlw	0x01		;load &quot;100,000&quot; in calc1-3
	movwf	calc3
	movlw	0x86
	movwf	calc2
	movlw	0xA0
	movwf	calc1
cnvt2	call	sub		;subtract number from count
	incf	2E	,f	;increment 100,000's register
	goto	cnvt2
	clrf	calc3		;load &quot;10,000&quot; in calc1-3
	movlw	0x27
	movwf	calc2
	movlw	0x10
	movwf	calc1
cnvt3	call	sub		;subtract number from count
	incf	2F	,f	;increment 10,000's register
	goto	cnvt3
	movlw	0x03		;load &quot;1,000&quot; in calc1-3
	movwf	calc2
	movlw	0xE8
	movwf	calc1
cnvt4	call	sub		;subtract number from count
	incf	30	,f	;increment 1,000's register
	goto	cnvt4
	clrf	calc2		;load &quot;100&quot; in calc1-3
	movlw	0x64
	movwf	calc1
cnvt5	call	sub		;subtract number from count
	incf	31	,f	;increment 100's register
	goto	cnvt5
	call	add		;add back number
	movlw	0x0A		;load &quot;10&quot; in calc1-3
	movwf	calc1
cnvt6	call	sub		;subtract number from count
	incf	32	,f	;increment 10's register
	goto	cnvt6
	movf	cnt1,w		;put remainder in 1's register
	addwf	33,f
	incf	33,f
	retlw	0x00
count	movlw	b'00110111'	;rtcc = ext, 1/256
	option			;************************ITT************
	bsf   STATUS,RP0   ; select Register-Page 1 ********************
	movlw	b'00010000'	;define port_a as output 
	tris	port_a
	bcf	port_a,3
	bcf	port_a,2
	clrf	cnt3
	clrf	rtcc
	clrf	rtcc2
	bsf	port_a,2	;toggle rtcc pin
	bcf	port_a,2
	movf	gate,w		;get gate time
	movwf	count1
	bsf	port_a,3	;start count
fr4	movlw	0xFA
	movwf	count2
	goto	fr6
fr5	nop
	nop
	nop
	nop
	nop
	nop
fr6	movf	rtcc,w		;test for rtcc rollover (12)
	subwf	rtcc2	,f
	btfss	status,z
	goto	fr7
	nop
	goto	fr8
fr7	btfsc	status,c
	incf	cnt3	,f
fr8	movwf	rtcc2
	nop
	nop
	nop
	decfsz	count2	,f
	goto	fr5
	decfsz	count1	,f
	goto	fr4
	bcf	port_a,3	;stop count
	movf	rtcc,w		;get rtcc count
	movwf	cnt2
	subwf	rtcc2	,f	;test for rtcc rollover
	btfss	status,c
	goto	fr9
	btfss	status,z
	incf	cnt3	,f
fr9	clrf	cnt1		;set to get prescaler count
fr10	decf	cnt1	,f
	bcf	port_a,2
	movf	rtcc,w		;test if rtcc has changed
	xorwf	cnt2,w
	btfsc	status,z
	goto	fr10
	retlw	0x00
;                                   START
start	clrf	port_a		;instruction, write, enable low
	bsf   STATUS,RP0   ; select Register-Page 1 ****************************
	movlw	b'00010000'
	tris	port_a
	bcf   STATUS,RP0   ; select Register-Page 0 ****************************
	MOVLW	7
	MOVWF	CMCON
	clrf	port_b
	movlw	b'00000000'
	tris	port_b
	call	int_del
	call	int_del
	call	int_del
	movlw	0x38		;initialize display 
	movwf	port_b
	call	int_del
	bcf	port_a,e
	call	int_del
	bcf	port_a,e
	call	int_del
	bcf	port_a,e
	bcf	port_b,4	;function
	call	inst
	movlw	b'00001100'	;display on, cursor off
	call	inst
	movlw	b'00000001'	;clear display
	call	inst
	movlw	b'00000110'	;entry mode
	call	inst
;  new lines here for intro 
        movlw   0x20		;space
	call	lcd_out
        movlw   0x20		;space
	call	lcd_out
        movlw   0x56		;V
	call	lcd_out
        movlw   0x69		;i
	call	lcd_out
        movlw   0x63		;c
	call	lcd_out
        movlw   0x73		;s
	call	lcd_out
        movlw   0x79		;y
	call	lcd_out
        movlw   0x73		;s
	call	lcd_out
        movlw   0x20		;space
	call	lcd_out
        movlw   0x76		;v
	call	lcd_out
        movlw   0x2e		;.
	call	lcd_out
        movlw   0x31		;1
	call	lcd_out
        movlw   0x2e		;.
	call	lcd_out
	movlw   0x30		;0
	call	lcd_out
        movlw	'm'		;m = MÓDÓSÍTOTT, HOGY 628A-VAL MENJEN
	call	lcd_out
       	movlw   '.'		;.
	call	lcd_out
	movlw	0x06  		;change the 6 to a smaller No. to speed up the intro
	movwf	count3		
wait1	movlw	0xc8
	movwf	count4
wait2	call	int_del
	decfsz	count4	,f
	goto	wait2
	decfsz	count3	,f
	goto	wait1
	call	inst
	call	inst
        movlw   0x20		;space
	call	lcd_out
        movlw   0x20		;space
	call	lcd_out
        movlw   0x49		;I
	call	lcd_out
        movlw   0x6e		;n
	call	lcd_out
        movlw   0x69		;i
	call	lcd_out
        movlw   0x74		;t
	call	lcd_out
        movlw   0x69		;i
	call	lcd_out
        movlw   0x61		;a
	call	lcd_out
        movlw   0x6c		;l
	call	lcd_out
        movlw   0x69		;i
	call	lcd_out
	movlw   0x7a		;z
	call	lcd_out 
        movlw   0x69		;i
	call	lcd_out
        movlw   0x6e		;n
	call	lcd_out
        movlw   0x67		;g
	call	lcd_out
        movlw   0x2e		;.
	call	lcd_out
 	movlw	0x06
	movwf	count3
wait3	movlw	0xc8
	movwf	count4
wait4	call	int_del
	decfsz	count4	,f
	goto	wait4
	decfsz	count3	,f
	goto	wait3
	call	inst
	call	inst
        movlw   0x49		;I
	call	lcd_out
        movlw   0x6e		;n
	call	lcd_out
        movlw   0x69		;i
	call	lcd_out
        movlw   0x74		;t
	call	lcd_out
        movlw   0x69		;i
	call	lcd_out
        movlw   0x61		;a
	call	lcd_out
        movlw   0x6c		;l
	call	lcd_out
        movlw   0x69		;i
	call	lcd_out
	movlw   0x7a		;z
	call	lcd_out 
        movlw   0x69		;i
	call	lcd_out
        movlw   0x6e		;n
	call	lcd_out
        movlw   0x67		;g
	call	lcd_out
        movlw   0x2e		;.
	call	lcd_out
        movlw   0x20		;space
	call	lcd_out
	movlw	0x06
	movwf	count3
wait5	movlw	0xc8
	movwf	count4
wait6	call	int_del
	decfsz	count4	,f
	goto	wait6
	decfsz	count3	,f
	goto	wait5
	call	inst
	call	inst
mhz	movlw	0x14		;0.1 sec gate
	movwf	gate
	call	count
	call	cnvt		;convert binary to BCD
	movlw	0x30		;test if &quot;0&quot;
	xorwf	2D,w
	btfss	status,z
	goto	mhz1
	xorwf	2E,w
	btfsc	status,z
	goto	khz1
mhz1	movlw	0x82		;set display address
	call	inst
	movlw	0x02		;output first 2 characters
	movwf	count1
	movlw	0x2D		;MSD of freq
	movwf	fsr
mhz2	movlw	0x30		;test if &quot;0&quot;
	xorwf	INDF,w
	btfss	status,z
	goto	mhz3
	movlw	0x20		;change preceeding &quot;0's&quot; to &quot;space&quot;
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	mhz2
	goto	mhz4
mhz3	movf	INDF,w
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	mhz3
mhz4	movlw	0x2E		;&quot;.&quot;
	call	lcd_out
	movlw	0x05		;output last 5 characters
	movwf	count1	
mhz5	movf	INDF,w
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	mhz5
	movlw	0x20		;&quot;space&quot;
	call	lcd_out
	movlw	0x4D		;&quot;M&quot;
	call	lcd_out
	movlw	0x48		;&quot;H&quot;
	call	lcd_out
	movlw	0x7A		;&quot;z&quot;
	call	lcd_out
	call	lcd_out
	call	lcd_out
	goto	mhz
khz	movlw	0x14		;0.1 sec gate
	movwf	gate
	call	count
	movlw	0x30		;test if 0
	xorwf	2D,w
	btfss	status,z
	goto	mhz1
	movlw	0x32		;test if &lt; 2
	subwf	2E,w
	btfsc	status,c
	goto	mhz1
	xorwf	2E,w
	btfss	status,z
	goto	khz1
	xorwf	2F,w
	btfsc	status,z
	goto	xkhz
khz1	movlw	0x82		;set display address
	call	inst
	movlw	0x05		;output first 5 characters
	movwf	count1
	movwf	fsr
khz2	movlw	0x30		;test if &quot;0&quot;
	xorwf	INDF,w
	btfss	status,z
	goto	khz3
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	khz2
	goto	khz4
khz3	movf	INDF,w
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	khz3
khz4	movlw	0x2E		;&quot;.&quot;
	call	lcd_out
	movf	INDF,w		;output last 2 characters
	call	lcd_out
	incf	fsr	,f
	movf	INDF,w
	call	lcd_out
	call	lcd_out
	movlw	0x4B		;&quot;K&quot;
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	goto	khz
xkhz	movlw	0xC8		;1 sec gate
	movwf	gate
	call	count
	xorwf	2D,w
	btfss	status,z
	goto	khz
	subwf	2E,w
	btfsc	status,c
	goto	khz
	xorwf	2E,w
	btfss	status,z
	goto	xkhz1
	xorwf	2F,w
	btfsc	status,z
	goto	hz0
xkhz1	movlw	0x82		;set display address
	call	inst
	movlw	0x04		;output first 4 characters
	movwf	count1
	movwf	fsr
xkhz2	movlw	0x30		;test if &quot;0&quot;
	xorwf	INDF,w
	btfss	status,z
	goto	xkhz3
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	xkhz2
	goto	xkhz4
xkhz3	movf	INDF,w
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	xkhz3
xkhz4	movlw	0x2E		;&quot;.&quot;
	call	lcd_out
	movf	INDF,w		;output last 3 characters
	call	lcd_out
	incf	fsr	,f
	movf	INDF,w
	call	lcd_out
	incf	fsr	,f
	movf	INDF,w
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	goto	xkhz
	movwf	gate
	call	count
	xorwf	2D,w
	btfss	status,z
	goto	xkhz1
	xorwf	2E,w
	btfss	status,z
	goto	xkhz1
	subwf	2F,w
	btfsc	status,c
	goto	xkhz1
hz0	movlw	0x82		;set display address
	call	inst
	movlw	0x07		;output first 7 characters
	movwf	count1
	movwf	fsr
hz1	movlw	0x30		;test if &quot;0&quot;
	xorwf	INDF,w
	btfss	status,z
	goto	hz2
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	hz1
	goto	hz3
hz2	movf	INDF,w
	call	lcd_out
	incf	fsr	,f
	decfsz	count1	,f
	goto	hz2
hz3	movlw	0x20		;&quot;space&quot;
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	call	lcd_out
	goto	hz
overflow	movlw	0x01	;clear display
	call	inst
	movlw	0x84		;display address
	call	inst
	movlw	0x4F		;&quot;O&quot;
	call	lcd_out
	movlw	0x76		;&quot;v&quot;
	call	lcd_out
	movlw	0x65		;&quot;e&quot;
	call	lcd_out
	movlw	0x72		;&quot;r&quot;
	call	lcd_out
	movlw	0x66		;&quot;f&quot;
	call	lcd_out
	movlw	0x6C		;&quot;l&quot;
	call	lcd_out
	movlw	0x6F		;&quot;o&quot;
	call	lcd_out
	movlw	0x77		;&quot;w&quot;
	call	lcd_out
	movlw	0x02		;cursor at home
	call	inst
	goto	mhz
	end
