# Makefile for foodloader
TARGET = foodloader
# microcontroller and project specific settings (everything can be overridden using config.mk)
F_CPU = 16000000UL
MCU = atmega8
# include avr-generic makefile configuration
include avr.mk
# bootloader section start
# (see datasheet)
ifeq ($(MCU),atmega8)
	# atmega8 with 1024 words bootloader:
	# bootloader section starts at 0xc00 (word-address) == 0x1800 (byte-address)
	#BOOT_SECTION_START = 0x1800
	# atmega8 with 512 words bootloader:
	# bootloader section starts at 0xe00 (word-address) == 0x1c00 (byte-address)
	BOOT_SECTION_START = 0x1c00
	# 7kb data memory (raw memory minus bootloader space)
	DATA_MEM = 7
endif
ifeq ($(MCU),atmega88)
	# atmega88 with 1024 words bootloader:
	# atmega88 with 512 words bootloader:
	DATA_MEM = 7
endif
ifeq ($(MCU),atmega168)
	# atmega168 with 1024 words bootloader:
	# bootloader section starts at 0x1c00 (word-address) == 0x3800 (byte-address)
	BOOT_SECTION_START = 0x3800
	# atmega168 with 512 words bootloader:
	# bootloader section starts at 0x1e00 (word-address) == 0x3c00 (byte-address)
	#BOOT_SECTION_START = 0x3c00
	# 14kb data memory (raw memory minus bootloader space)
	DATA_MEM = 14
endif
ifeq ($(MCU),atmega32)
	# atmega32 with 1024 words bootloader:
	# bootloader section starts at 0x3c00 (word-address) == 0x7800 (byte-address)
	#BOOT_SECTION_START = 0x7800
	# atmega32 with 512 words bootloader:
	# bootloader section starts at 0x3e00 (word-address) == 0x7c00 (byte-address)
	BOOT_SECTION_START = 0x7c00
	# 31kb data memory (raw memory minus bootloader space)
	DATA_MEM = 31
endif
ifeq ($(MCU),atmega644)
	# atmega644 with 1024 words bootloader:
	# bootloader section starts at 0x7c00 (word-address) == 0xf800 (byte-address)
	BOOT_SECTION_START = 0xf800
	# atmega644 with 512 words bootloader:
	# bootloader section starts at 0x7e00 (word-address) == 0xfc00 (byte-address)
	#BOOT_SECTION_START = 0xfc00
	# 62kb data memory (raw memory minus bootloader space)
	DATA_MEM = 62
endif
LDFLAGS += -Wl,--section-start=.text=$(BOOT_SECTION_START)
CFLAGS += -DBOOT_SECTION_START=$(BOOT_SECTION_START)
OBJECTS += $(patsubst %.c,%.o,$(shell echo *.c))
HEADERS += $(shell echo *.h)
CFLAGS += -Werror
LDFLAGS += -L/usr/local/avr/avr/lib
.PHONY: all launcher
all: $(TARGET).hex $(TARGET).lss launcher
	@echo "==============================="
	@echo "compiled for: $(MCU)"
	@echo -n "bootloader size is: "
	@$(SIZE) -A $< | grep "\.sec1" | tr -s " " | cut -d" " -f2
$(TARGET): $(OBJECTS) $(TARGET).o
%.o: $(HEADERS)
.PHONY: install
install: program-isp-$(TARGET)
	@echo "don't forget: the lock-bits have been cleaned by the chip-erase!"
.PHONY: clean clean-$(TARGET) clean-launcher
clean: clean-$(TARGET) clean-uploadtest clean-launcher
clean-$(TARGET):
	rm -f $(TARGET)
clean-uploadtest:
	rm -f datatestfile.raw
clean-launcher:
	$(MAKE) -C launcher clean
datatestfile.raw:
	dd if=/dev/urandom of=datatestfile.raw bs=1 count=$$((1024*$(DATA_MEM)))
uploadtest: datatestfile.raw
	@echo "uploading datatestfile"
	$(AVRDUDE) $(AVRDUDE_FLAGS) -c $(SERIAL_PROG) -s -u -P $(SERIAL_DEV) -U f:w:$<:r
lock:
	$(AVRDUDE) $(AVRDUDE_FLAGS) -c avr910 -P $(ISP_DEV) -U lock:w:0x2f:m
launcher:
	$(MAKE) -C launcher
fuses-atmega8:
	$(AVRDUDE) $(AVRDUDE_FLAGS) -c avr910 -P $(ISP_DEV) -U lfuse:w:0xE0:m
	$(AVRDUDE) $(AVRDUDE_FLAGS) -c avr910 -P $(ISP_DEV) -U hfuse:w:0xD2:m
fuses-atmega168:
	$(AVRDUDE) $(AVRDUDE_FLAGS) -c avr910 -P $(ISP_DEV) -U hfuse:w:0xD7:m
	$(AVRDUDE) $(AVRDUDE_FLAGS) -c avr910 -P $(ISP_DEV) -U efuse:w:0x01:m
