; Source created with Parsic Version 3.x
; at              : 2009.07.19. 20:27:21
; Project File    : c:\PROGRA~1\PARSIC\RIC_LM.PIC
; Project Version : 1.0.207
; Created         : 2009.07.12. 9:43:00
; Last change     : 2009.07.19. 20:27:17
	PROCESSOR 16F876
	INCLUDE P16F876.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
IISLAVEADR	= 32	; located in Bank 0
IIADR	= 33	; located in Bank 0
IIDATA	= 34	; located in Bank 0
IICOUNT	= 35	; located in Bank 0
IITEMP	= 36	; located in Bank 0
M0	= 37	; located in Bank 0
TR1	= 38	; located in Bank 0
TR1_HI	= 39	; located in Bank 0
S2	= 40	; located in Bank 0
CELSIUS	= 41	; located in Bank 0
CELSIUS_HI	= 42	; located in Bank 0
LT1_FD	= 43	; located in Bank 0
LT2_FD	= 44	; located in Bank 0
LT3_FD	= 45	; located in Bank 0
IIDATA1	= 46	; located in Bank 0
OS1_FD	= 47	; located in Bank 0
S0	= 48	; located in Bank 0
S1	= 49	; located in Bank 0
LT4_FD	= 50	; located in Bank 0
LT5_FD	= 51	; located in Bank 0
LT6_FD	= 52	; located in Bank 0
RAM	= 53	; located in Bank 0
SYS_WSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 115	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP1	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 120	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 121	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 122	; located in Bank 0, 1, 2, 3
SYS_TMP9	= 123	; located in Bank 0, 1, 2, 3
SYS_TMP10	= 124	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 125	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Multiplication 8 - Bit
SYSMUL8
	CLRF SYS_TMP3
	MOVLW 8
	MOVWF SYS_TMP4
SYSMUL8_1
	MOVFW SYS_TMP1
	RRF SYS_TMP2,F
	BTFSC STATUS,CARRY
	ADDWF SYS_TMP3,F
	RLF SYS_TMP1,F
	DECFSZ SYS_TMP4,F
	GOTO SYSMUL8_1
	RETURN
; Division 8 - Bit
SYSDIV8
	MOVF SYS_TMP2,F
	BTFSC STATUS,ZERO
	GOTO SYSDIV8_ERROR
	CLRF SYS_TMP3	; Ergebnis löschen
	MOVLW 1
	MOVWF SYS_TMP4
SYSDIV8_0
	BTFSC SYS_TMP2,7	; OP2 linksbündig
	GOTO SYSDIV8_1
	INCF SYS_TMP4,F
	BCF STATUS,CARRY
	RLF SYS_TMP2,F
	GOTO SYSDIV8_0
SYSDIV8_1
	MOVFW SYS_TMP2	; vergleichen
	SUBWF SYS_TMP1,F	; F-W -> W
	BTFSC STATUS,CARRY
	GOTO SYSDIV8_2
	ADDWF SYS_TMP1,F	; F+W -> F
	BCF STATUS,CARRY
SYSDIV8_2
	RLF SYS_TMP3,F
	RRF SYS_TMP2,F
	DECFSZ SYS_TMP4,F
	GOTO SYSDIV8_1
	RETURN
SYSDIV8_ERROR
	MOVLW 255
	MOVWF SYS_TMP3
	RETURN
; Subroutines
; Subroutines for LB1
LCD_LB1_INIT
	BCF PORTB,4	; ir-register
LCD_LB1_L1
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L1
	MOVFW PORTB
	ANDLW H'F0'
	IORLW B'0011'	; Function Set
	MOVWF PORTB
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	BSF SYS_TMP1,5	; wait
LCD_LB1_L2
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L2
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BCF PORTB,0	; 4-Bit Interface
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	MOVLW B'00101000'	; Function Set 4-Bit,2-Lines
	CALL LCD_LB1_OUT
	MOVLW B'00001100'	; Display on, Cursor off, Blink off
	CALL LCD_LB1_OUT
	MOVLW B'00000110'	; Entrymode set
	CALL LCD_LB1_OUT
LCD_LB1_CLR
	MOVLW B'00000001'	; Display clear
	CALL LCD_LB1_OUT
LCD_LB1_L3
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L3
	GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
	MOVLW H'40'
	BTFSC SYS_TMP2,0	; Ypos
	ADDWF SYS_TMP1,F
	MOVLW D'20'
	BTFSC SYS_TMP2,1	; Ypos
	ADDWF SYS_TMP1,F
	BSF SYS_TMP1,7	; select dd-ram
	GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
	BSF PORTB,4	; dd-ram
LCD_LB1_WRITESTR1
	CALL LCD_LB1_CHAROUT
	BSF INTCON,GIE
	ANDLW H'FF'	; last is zero
	BTFSC STATUS,ZERO
	RETURN
	MOVWF SYS_TMP1
	MOVLW HIGH LCD_LB1_OUT1	; set page
	MOVWF PCLATH
	CALL LCD_LB1_OUT1
	INCFSZ SYS_TMP4,F	; next char
	GOTO LCD_LB1_WRITESTR1
	INCF SYS_TMP5,F	; next page
LCD_LB1_CHAROUT
	BCF INTCON,GIE
	MOVFW SYS_TMP5
	MOVWF PCLATH
	MOVFW SYS_TMP4
	MOVWF PCL
LCD_LB1_DEZO10000
	MOVLW LOW 10000
	MOVWF SYS_TMP1
	MOVLW HIGH 10000
	MOVWF SYS_TMP2
	CALL LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1000
	CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
LCD_LB1_DEZO100
	MOVLW LOW 100
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
	MOVLW LOW 10
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
	MOVLW 48
	ADDWF SYS_TMP4,W
	GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
	INCF SYS_TMP6,F
	MOVFW SYS_TMP1
	SUBWF SYS_TMP4,F
	MOVFW SYS_TMP2
	BTFSS STATUS,CARRY
	INCFSZ SYS_TMP2,W
	SUBWF SYS_TMP5,F
	BTFSC STATUS,CARRY
	GOTO LCD_LB1_CONVERTDEZ2
	MOVFW SYS_TMP2
	ADDWF SYS_TMP5,F
	MOVFW SYS_TMP1
	ADDWF SYS_TMP4,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP5,F
	DECF SYS_TMP6,W
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	RETURN
LCD_LB1_CONVERTHEX
	ANDLW 15
	MOVWF SYS_TMP1
	MOVLW 48
	ADDWF SYS_TMP1,F
	MOVLW 58
	SUBWF SYS_TMP1,W
	BTFSS STATUS,CARRY
	GOTO $+3
	MOVLW 7
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
	MOVWF SYS_TMP1	; store
LCD_LB1_OUT1
	CLRF SYS_TMP3	; LCDWriteStr (first nibble)
LCD_LB1_OUT2
	SWAPF SYS_TMP1,W	;high nibble
LCD_LB1_OUT3
	ANDLW H'0F'	; mask
	MOVWF SYS_TMP2	; store
	MOVFW PORTB	; load port
	ANDLW H'F0'	; mask
	IORWF SYS_TMP2,W	; add cmd
	MOVWF PORTB	; out
	BSF PORTB,5	; E high
	GOTO $+1
	BCF PORTB,5	; E low
	BTFSC SYS_TMP3,3	; ready ?
	GOTO LCD_LB1_OUT4	; yes
	BSF SYS_TMP3,3	; second nibble
	MOVFW SYS_TMP1
	GOTO LCD_LB1_OUT3	; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
	DECFSZ SYS_TMP3,F
	GOTO LCD_LB1_OUTV
	RETURN
LCD_LB1_CHECKNULL
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	MOVWF SYS_TMP1
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	MOVLW 48
	BTFSC SYS_TMP10,0
	ADDWF SYS_TMP1,f
	MOVLW 32
	BTFSS SYS_TMP10,0
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
; 00FE
BEGININC86
	ERRORLEVEL +306	; enable warning (Pageswitching)
	ERRORLEVEL +302	; enable warning (Bankswitching)
	INCLUDE LM75_I2C.INC
ENDINC86
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11000000'
	MOVWF TRISB
	MOVLW B'11111110'
	MOVWF TRISC
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
; Init LCD -> LB1
	CALL LCD_LB1_INIT
BEGININC145
	INCLUDE LM75_AV.INC
ENDINC145
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
BEGININC144
	INCLUDE LM75AV.INC
ENDINC144
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S2,1
	GOTO LABEL_LG1_FALSE
LABEL_LG1_TRUE
	BSF M0,0
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF M0,0
LABEL_LG1_ENDE
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S2,2
	GOTO LABEL_LG2_FALSE
LABEL_LG2_TRUE
	BSF M0,1
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF M0,1
LABEL_LG2_ENDE
; Timer -> TR1
	MOVLW 7	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 161
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 161
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S2,0
	GOTO LABEL_TR1_CLR
	BSF S2,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S2,0
LABEL_TR1_ENDE
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S2,0
	GOTO LABEL_LG3_FALSE
LABEL_LG3_TRUE
	BSF PORTC,0
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF PORTC,0
LABEL_LG3_ENDE
; LCD -> LT1
; test of positiv edge
	BTFSC LT1_FD,0
	GOTO LABEL_LT1_SETFD
	BTFSS S2,0
	MOVLW 10
	MOVWF SYS_TMP1
	MOVLW 2
	MOVWF SYS_TMP2
	MOVLW HIGH LCD_LB1_GOTOXY	; set page
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW IIDATA
	MOVWF SYS_TMP4
	MOVLW 8
	MOVWF SYS_TMP6
LCD_LT1_BIN1
	MOVLW HIGH LCD_LB1_WRITECHAR	; set page
	MOVWF PCLATH
	RLF SYS_TMP4,F
	MOVLW 48
	BTFSC STATUS,CARRY
	MOVLW 49
	CALL LCD_LB1_WRITECHAR
	MOVLW HIGH LCD_LT1_BIN1	; set page
	MOVWF PCLATH
	DECFSZ SYS_TMP6,F
	GOTO LCD_LT1_BIN1
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
LABEL_LT1_SETFD
	BTFSS S2,0
	GOTO LABEL_LT1_SETFD2
	BSF LT1_FD,0
	GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
	BCF LT1_FD,0
LABEL_LT1_END
; LCD -> LT2
	BTFSC LT2_FD,0
	GOTO LABEL_LT2_SETFD
	BTFSS S2,0
	MOVLW 0
	MOVWF SYS_TMP1
	MOVLW 2
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW IIDATA1
	MOVWF SYS_TMP4
	MOVLW 8
	MOVWF SYS_TMP6
LCD_LT2_BIN1
	MOVWF PCLATH
	RLF SYS_TMP4,F
	MOVLW 48
	BTFSC STATUS,CARRY
	MOVLW 49
	MOVLW HIGH LCD_LT2_BIN1	; set page
	MOVWF PCLATH
	DECFSZ SYS_TMP6,F
	GOTO LCD_LT2_BIN1
LABEL_LT2_SETFD
	BTFSS S2,0
	GOTO LABEL_LT2_SETFD2
	BSF LT2_FD,0
	GOTO LABEL_LT2_END
LABEL_LT2_SETFD2
	BCF LT2_FD,0
LABEL_LT2_END
; LCD -> LT3
	BTFSC LT3_FD,0
	GOTO LABEL_LT3_SETFD
	BTFSS S2,0
	MOVLW 11
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW S1
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BSF SYS_TMP10,0
	MOVLW 3
	MOVWF SYS_TMP9
	MOVLW HIGH LCD_LB1_DEZO100	; set page
	MOVWF PCLATH
	CALL LCD_LB1_DEZO100
LABEL_LT3_SETFD
	BTFSS S2,0
	GOTO LABEL_LT3_SETFD2
	BSF LT3_FD,0
	GOTO LABEL_LT3_END
LABEL_LT3_SETFD2
	BCF LT3_FD,0
LABEL_LT3_END
; One Shot -> OS1
	BTFSS S2,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S2,2
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S2,2
	BTFSC S2,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
;AF1
	MOVFW IIDATA
	MOVWF SYS_TMP1
	MOVLW 128
	MOVWF SYS_TMP2
	MOVLW HIGH SYSDIV8
	MOVWF PCLATH
	CALL SYSDIV8
	MOVLW HIGH LABEL_AF1
	MOVWF PCLATH
LABEL_AF1
	MOVFW SYS_TMP3
	MOVWF S0
LABEL_AF1_EXIT
;AF2
	MOVFW S0
	MOVWF SYS_TMP1
	MOVLW 5
	MOVWF SYS_TMP2
	MOVLW HIGH SYSMUL8
	MOVWF PCLATH
	CALL SYSMUL8
	MOVLW HIGH LABEL_AF2
	MOVWF PCLATH
LABEL_AF2
	MOVFW SYS_TMP3
	MOVWF S1
LABEL_AF2_EXIT
; LCD -> LT4
	BTFSC LT4_FD,0
	GOTO LABEL_LT4_SETFD
	BTFSS S2,0
	MOVLW 8
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW IIDATA1
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BCF SYS_TMP10,0
	MOVLW 2
	MOVWF SYS_TMP9
	MOVWF PCLATH
LABEL_LT4_SETFD
	BTFSS S2,0
	GOTO LABEL_LT4_SETFD2
	BSF LT4_FD,0
	GOTO LABEL_LT4_END
LABEL_LT4_SETFD2
	BCF LT4_FD,0
LABEL_LT4_END
; LCD -> LT5
	BTFSC LT5_FD,0
	GOTO LABEL_LT5_SETFD
	BTFSS S2,0
	MOVLW 10
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT5
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT5
	MOVWF SYS_TMP5
	MOVLW HIGH LCD_LB1_WRITESTR	; set page
	MOVWF PCLATH
	CALL LCD_LB1_WRITESTR
LABEL_LT5_SETFD
	BTFSS S2,0
	GOTO LABEL_LT5_SETFD2
	BSF LT5_FD,0
	GOTO LABEL_LT5_END
LABEL_LT5_SETFD2
	BCF LT5_FD,0
LABEL_LT5_END
; LCD -> LT6
	BTFSC LT6_FD,0
	GOTO LABEL_LT6_SETFD
	BTFSS S2,0
	MOVLW 13
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT6
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT6
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT6_SETFD
	BTFSS S2,0
	GOTO LABEL_LT6_SETFD2
	BSF LT6_FD,0
	GOTO LABEL_LT6_END
LABEL_LT6_SETFD2
	BCF LT6_FD,0
LABEL_LT6_END
; GND
	BCF S2,1	; immer Low
	GOTO MAIN
TAB_LT5
	RETLW 46	; .
	RETLW 0	; end
TAB_LT6
	RETLW 67	; C
	RETLW 0	; end
	END
