; Source created with Parsic Version 3.x
; at              : 2009.07.22. 21:26:37
; Project File    : C:\DOCUME~1\ALLUSE~1\Asztal\óra.pic
; Project Version : 1.0.2
; Created         : 2008.11.09. 21:30:00
; Last change     : 2009.07.22. 21:26:33
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _HS_OSC & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV1	= 32	; located in Bank 0
ZV1_FD	= 33	; located in Bank 0
ZV2	= 34	; located in Bank 0
ZV2_FD	= 35	; located in Bank 0
ZV3	= 36	; located in Bank 0
ZV3_FD	= 37	; located in Bank 0
S0	= 38	; located in Bank 0
LT1_FD	= 39	; located in Bank 0
LT2_FD	= 40	; located in Bank 0
LT3_FD	= 41	; located in Bank 0
ZV4	= 42	; located in Bank 0
ZV4_HI	= 43	; located in Bank 0
ZV4_FD	= 44	; located in Bank 0
S1	= 45	; located in Bank 0
TR1	= 46	; located in Bank 0
TR1_HI	= 47	; located in Bank 0
LT4_FD	= 48	; located in Bank 0
LT5_FD	= 49	; located in Bank 0
ZV5	= 50	; located in Bank 0
ZV5_FD	= 51	; located in Bank 0
ZV6	= 52	; located in Bank 0
ZV6_FD	= 53	; located in Bank 0
LT6_FD	= 54	; located in Bank 0
LT7_FD	= 55	; located in Bank 0
LT8_FD	= 56	; located in Bank 0
LT9_FD	= 57	; located in Bank 0
LT10_FD	= 58	; located in Bank 0
LT11_FD	= 59	; located in Bank 0
RAM	= 60	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 113	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 115	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP9	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP10	= 119	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 120	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 121	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 122	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Subroutines for LB1
LCD_LB1_INIT
	BCF PORTB,4	; ir-register
LCD_LB1_L1
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L1
	MOVFW PORTB
	ANDLW H'F0'
	IORLW B'0011'	; Function Set
	MOVWF PORTB
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	BSF SYS_TMP1,5	; wait
LCD_LB1_L2
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L2
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BCF PORTB,0	; 4-Bit Interface
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	MOVLW B'00101000'	; Function Set 4-Bit,2-Lines
	CALL LCD_LB1_OUT
	MOVLW B'00001100'	; Display on, Cursor off, Blink off
	CALL LCD_LB1_OUT
	MOVLW B'00000110'	; Entrymode set
	CALL LCD_LB1_OUT
LCD_LB1_CLR
	MOVLW B'00000001'	; Display clear
	CALL LCD_LB1_OUT
LCD_LB1_L3
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L3
	GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
	MOVLW H'40'
	BTFSC SYS_TMP2,0	; Ypos
	ADDWF SYS_TMP1,F
	BSF SYS_TMP1,7	; select dd-ram
	GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
	BSF PORTB,4	; dd-ram
LCD_LB1_WRITESTR1
	CALL LCD_LB1_CHAROUT
	BSF INTCON,GIE
	ANDLW H'FF'	; last is zero
	BTFSC STATUS,ZERO
	RETURN
	MOVWF SYS_TMP1
	CALL LCD_LB1_OUT1
	INCFSZ SYS_TMP4,F	; next char
	GOTO LCD_LB1_WRITESTR1
	INCF SYS_TMP5,F	; next page
LCD_LB1_CHAROUT
	BCF INTCON,GIE
	MOVFW SYS_TMP5
	MOVWF PCLATH
	MOVFW SYS_TMP4
	MOVWF PCL
LCD_LB1_DEZO10000
	MOVLW LOW 10000
	MOVWF SYS_TMP1
	MOVLW HIGH 10000
	MOVWF SYS_TMP2
	CALL LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1000
	CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
LCD_LB1_DEZO100
	MOVLW LOW 100
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
	MOVLW LOW 10
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
	MOVLW 48
	ADDWF SYS_TMP4,W
	GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
	INCF SYS_TMP6,F
	MOVFW SYS_TMP1
	SUBWF SYS_TMP4,F
	MOVFW SYS_TMP2
	BTFSS STATUS,CARRY
	INCFSZ SYS_TMP2,W
	SUBWF SYS_TMP5,F
	BTFSC STATUS,CARRY
	GOTO LCD_LB1_CONVERTDEZ2
	MOVFW SYS_TMP2
	ADDWF SYS_TMP5,F
	MOVFW SYS_TMP1
	ADDWF SYS_TMP4,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP5,F
	DECF SYS_TMP6,W
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	RETURN
LCD_LB1_CONVERTHEX
	ANDLW 15
	MOVWF SYS_TMP1
	MOVLW 48
	ADDWF SYS_TMP1,F
	MOVLW 58
	SUBWF SYS_TMP1,W
	BTFSS STATUS,CARRY
	GOTO $+3
	MOVLW 7
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
	MOVWF SYS_TMP1	; store
LCD_LB1_OUT1
	CLRF SYS_TMP3	; LCDWriteStr (first nibble)
LCD_LB1_OUT2
	SWAPF SYS_TMP1,W	;high nibble
LCD_LB1_OUT3
	ANDLW H'0F'	; mask
	MOVWF SYS_TMP2	; store
	MOVFW PORTB	; load port
	ANDLW H'F0'	; mask
	IORWF SYS_TMP2,W	; add cmd
	MOVWF PORTB	; out
	BSF PORTB,5	; E high
	GOTO $+1
	BCF PORTB,5	; E low
	BTFSC SYS_TMP3,3	; ready ?
	GOTO LCD_LB1_OUT4	; yes
	BSF SYS_TMP3,3	; second nibble
	MOVFW SYS_TMP1
	GOTO LCD_LB1_OUT3	; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
	DECFSZ SYS_TMP3,F
	GOTO LCD_LB1_OUTV
	RETURN
LCD_LB1_CHECKNULL
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	MOVWF SYS_TMP1
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	MOVLW 48
	BTFSC SYS_TMP10,0
	ADDWF SYS_TMP1,f
	MOVLW 32
	BTFSS SYS_TMP10,0
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
; 00CF
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'01000000'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
; Init LCD -> LB1
	CALL LCD_LB1_INIT
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
	BTFSS S0,0	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S0,1
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S0,5	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S0,1
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Zähler -> ZV2
	BTFSS S0,3	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S0,2
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S0,2
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Zähler -> ZV3
	BTFSS S0,4	; Reset ?
	GOTO LABEL_ZV3_COUNT
	CLRF ZV3
	GOTO LABEL_ZV3_SETOUT
LABEL_ZV3_COUNT
	BTFSS S0,6
	GOTO LABEL_ZV3_SETFD
	BTFSC ZV3_FD,0
	BSF ZV3_FD,0
	GOTO LABEL_ZV3_BACKWARD
	INCF ZV3,F
LABEL_ZV3_BACKWARD
	DECF ZV3,F
LABEL_ZV3_SETOUT
LABEL_ZV3_SETFD
	BTFSC S0,6
	GOTO LABEL_ZV3_EXIT
	BCF ZV3_FD,0
LABEL_ZV3_EXIT
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S0,0	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVLW 60
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 60
LABEL_ST1_TEST
	SUBWF ZV1,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S0,0	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S0,0	; if less
LABEL_ST1_ENDE
; Schmitt-Trigger 8-Bit -> ST2
	BTFSC S0,3	; Ausgang gesetzt ?
	GOTO LABEL_ST2_MH	; dann mit Hysterese ?
	MOVLW 60
	GOTO LABEL_ST2_TEST
LABEL_ST2_MH
	MOVLW 60
LABEL_ST2_TEST
	SUBWF ZV2,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST2_RESET
	BSF S0,3	; if greater or equal
	GOTO LABEL_ST2_ENDE
LABEL_ST2_RESET
	BCF S0,3	; if less
LABEL_ST2_ENDE
; Schmitt-Trigger 8-Bit -> ST3
	BTFSC S0,4	; Ausgang gesetzt ?
	GOTO LABEL_ST3_MH	; dann mit Hysterese ?
	MOVLW 24
	GOTO LABEL_ST3_TEST
LABEL_ST3_MH
	MOVLW 24
LABEL_ST3_TEST
	SUBWF ZV3,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST3_RESET
	BSF S0,4	; if greater or equal
	GOTO LABEL_ST3_ENDE
LABEL_ST3_RESET
	BCF S0,4	; if less
LABEL_ST3_ENDE
; GND
	BCF S0,5	; immer Low
; LCD -> LT1
; test of positiv edge
	BTFSC LT1_FD,0
	GOTO LABEL_LT1_SETFD
	BTFSS S0,7
	MOVLW 13
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVFW ZV1
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BSF SYS_TMP10,0
	MOVLW 2
	MOVWF SYS_TMP9
	CALL LCD_LB1_DEZO100
LABEL_LT1_SETFD
	BTFSS S0,7
	GOTO LABEL_LT1_SETFD2
	BSF LT1_FD,0
	GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
	BCF LT1_FD,0
LABEL_LT1_END
; LCD -> LT2
	BTFSC LT2_FD,0
	GOTO LABEL_LT2_SETFD
	BTFSS S0,7
	MOVLW 7
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVFW ZV2
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BSF SYS_TMP10,0
	MOVLW 2
	MOVWF SYS_TMP9
LABEL_LT2_SETFD
	BTFSS S0,7
	GOTO LABEL_LT2_SETFD2
	BSF LT2_FD,0
	GOTO LABEL_LT2_END
LABEL_LT2_SETFD2
	BCF LT2_FD,0
LABEL_LT2_END
; LCD -> LT3
	BTFSC LT3_FD,0
	GOTO LABEL_LT3_SETFD
	BTFSS S0,7
	MOVLW 1
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVFW ZV3
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BSF SYS_TMP10,0
	MOVLW 2
	MOVWF SYS_TMP9
LABEL_LT3_SETFD
	BTFSS S0,7
	GOTO LABEL_LT3_SETFD2
	BSF LT3_FD,0
	GOTO LABEL_LT3_END
LABEL_LT3_SETFD2
	BCF LT3_FD,0
LABEL_LT3_END
; Zähler -> ZV4
	BTFSS S1,0	; Reset ?
	GOTO LABEL_ZV4_COUNT
	CLRF ZV4
	CLRF ZV4_HI
	GOTO LABEL_ZV4_SETOUT
LABEL_ZV4_COUNT
	BTFSS S0,7
	GOTO LABEL_ZV4_SETFD
	BTFSC ZV4_FD,0
	BSF ZV4_FD,0
	GOTO LABEL_ZV4_BACKWARD
	INCFSZ ZV4,F
	INCF ZV4_HI,F
LABEL_ZV4_BACKWARD
	DECF ZV4,F
	INCFSZ ZV4,W
	DECF ZV4_HI,F
LABEL_ZV4_SETOUT
LABEL_ZV4_SETFD
	BTFSC S0,7
	GOTO LABEL_ZV4_EXIT
	BCF ZV4_FD,0
LABEL_ZV4_EXIT
; Schmitt-Trigger 16-Bit -> ST4
	MOVLW LOW 100
	MOVWF SYS_TMP1
	MOVLW HIGH 100
	MOVWF SYS_TMP2
	BTFSS S1,0	; Ausgang gesetzt ?
	GOTO LABEL_ST4_TEST	; without Hysterese
	MOVLW HIGH 0
	SUBWF SYS_TMP2,F
	MOVLW LOW 0
	SUBWF SYS_TMP1,F
	BTFSS STATUS,CARRY
	DECF SYS_TMP2,F
LABEL_ST4_TEST
	MOVFW SYS_TMP2
	SUBWF ZV4_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_ST4_TEST2
	MOVFW SYS_TMP1
	SUBWF ZV4,W
LABEL_ST4_TEST2
	BTFSS STATUS,CARRY
	GOTO LABEL_ST4_RESET
LABEL_ST4_SET
	BSF S1,0	; if greater or equal
	GOTO LABEL_ST4_ENDE
LABEL_ST4_RESET
	BCF S1,0	; if less
LABEL_ST4_ENDE
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 20
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 20
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S0,7
	GOTO LABEL_TR1_CLR
	BSF S0,7
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S0,7
LABEL_TR1_ENDE
; ODER - Gatter -> LG1
LABEL_LG1_1
	BTFSC S0,3
	GOTO LABEL_LG1_TRUE
LABEL_LG1_2
	BTFSS PORTA,4
	GOTO LABEL_LG1_TRUE
LABEL_LG1_FALSE
	BCF S0,6
	GOTO LABEL_LG1_ENDE
LABEL_LG1_TRUE
	BSF S0,6
LABEL_LG1_ENDE
; ODER - Gatter -> LG2
LABEL_LG2_1
	BTFSC S0,0
	GOTO LABEL_LG2_TRUE
LABEL_LG2_2
	BTFSS PORTA,3
	GOTO LABEL_LG2_TRUE
LABEL_LG2_FALSE
	BCF S0,2
	GOTO LABEL_LG2_ENDE
LABEL_LG2_TRUE
	BSF S0,2
LABEL_LG2_ENDE
; ODER - Gatter -> LG3
LABEL_LG3_1
	BTFSS PORTA,2
	GOTO LABEL_LG3_TRUE
LABEL_LG3_2
	BTFSC S1,0
	GOTO LABEL_LG3_TRUE
LABEL_LG3_FALSE
	BCF S0,1
	GOTO LABEL_LG3_ENDE
LABEL_LG3_TRUE
	BSF S0,1
LABEL_LG3_ENDE
; LCD -> LT4
	BTFSC LT4_FD,0
	GOTO LABEL_LT4_SETFD
	BTFSS S0,7
	MOVLW 9
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT4
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT4
	MOVWF SYS_TMP5
	CALL LCD_LB1_WRITESTR
LABEL_LT4_SETFD
	BTFSS S0,7
	GOTO LABEL_LT4_SETFD2
	BSF LT4_FD,0
	GOTO LABEL_LT4_END
LABEL_LT4_SETFD2
	BCF LT4_FD,0
LABEL_LT4_END
; LCD -> LT5
	BTFSC LT5_FD,0
	GOTO LABEL_LT5_SETFD
	BTFSS S0,7
	MOVLW 3
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT5
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT5
	MOVWF SYS_TMP5
LABEL_LT5_SETFD
	BTFSS S0,7
	GOTO LABEL_LT5_SETFD2
	BSF LT5_FD,0
	GOTO LABEL_LT5_END
LABEL_LT5_SETFD2
	BCF LT5_FD,0
LABEL_LT5_END
; Vergleich -> IF1
	MOVFW ZV5
	SUBWF ZV2,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S1,1
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S1,1
LABEL_IF1_EXIT
; Vergleich -> IF2
	MOVFW ZV6
	SUBWF ZV3,W	; F - W -> W
LABEL_IF2_CHECK
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S1,2
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S1,2
LABEL_IF2_EXIT
; Zähler -> ZV5
	BTFSS S1,3	; Reset ?
	GOTO LABEL_ZV5_COUNT
	CLRF ZV5
	GOTO LABEL_ZV5_SETOUT
LABEL_ZV5_COUNT
	BTFSS PORTA,0
	GOTO LABEL_ZV5_SETFD
	BTFSC ZV5_FD,0
	BSF ZV5_FD,0
	BTFSC S1,7	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV5_BACKWARD
	INCF ZV5,F
LABEL_ZV5_BACKWARD
	DECF ZV5,F
LABEL_ZV5_SETOUT
LABEL_ZV5_SETFD
	BTFSC PORTA,0
	GOTO LABEL_ZV5_EXIT
	BCF ZV5_FD,0
LABEL_ZV5_EXIT
; Zähler -> ZV6
	BTFSS S1,4	; Reset ?
	GOTO LABEL_ZV6_COUNT
	CLRF ZV6
	GOTO LABEL_ZV6_SETOUT
LABEL_ZV6_COUNT
	BTFSS PORTA,1
	GOTO LABEL_ZV6_SETFD
	BTFSC ZV6_FD,0
	BSF ZV6_FD,0
	GOTO LABEL_ZV6_BACKWARD
	INCF ZV6,F
LABEL_ZV6_BACKWARD
	DECF ZV6,F
LABEL_ZV6_SETOUT
LABEL_ZV6_SETFD
	BTFSC PORTA,1
	GOTO LABEL_ZV6_EXIT
	BCF ZV6_FD,0
LABEL_ZV6_EXIT
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S1,1
	GOTO LABEL_LG4_FALSE
LABEL_LG4_2
	BTFSS S1,2
LABEL_LG4_3
	BTFSS PORTB,6
LABEL_LG4_TRUE
	BSF PORTB,7
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF PORTB,7
LABEL_LG4_ENDE
; LCD -> LT6
	BTFSC LT6_FD,0
	GOTO LABEL_LT6_SETFD
	BTFSS S1,5
	MOVLW 5
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVFW ZV5
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BSF SYS_TMP10,0
	MOVLW 2
	MOVWF SYS_TMP9
LABEL_LT6_SETFD
	BTFSS S1,5
	GOTO LABEL_LT6_SETFD2
	BSF LT6_FD,0
	GOTO LABEL_LT6_END
LABEL_LT6_SETFD2
	BCF LT6_FD,0
LABEL_LT6_END
; LCD -> LT7
	BTFSC LT7_FD,0
	GOTO LABEL_LT7_SETFD
	BTFSS S1,5
	MOVLW 10
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVFW ZV6
	MOVWF SYS_TMP4
	CLRF SYS_TMP5
	BSF SYS_TMP10,0
	MOVLW 2
	MOVWF SYS_TMP9
LABEL_LT7_SETFD
	BTFSS S1,5
	GOTO LABEL_LT7_SETFD2
	BSF LT7_FD,0
	GOTO LABEL_LT7_END
LABEL_LT7_SETFD2
	BCF LT7_FD,0
LABEL_LT7_END
; LCD -> LT8
	BTFSC LT8_FD,0
	GOTO LABEL_LT8_SETFD
	BTFSS S1,5
	MOVLW 7
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT8
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT8
	MOVWF SYS_TMP5
LABEL_LT8_SETFD
	BTFSS S1,5
	GOTO LABEL_LT8_SETFD2
	BSF LT8_FD,0
	GOTO LABEL_LT8_END
LABEL_LT8_SETFD2
	BCF LT8_FD,0
LABEL_LT8_END
; LCD -> LT9
	BTFSC LT9_FD,0
	GOTO LABEL_LT9_SETFD
	BTFSS S1,5
	MOVLW 12
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT9
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT9
	MOVWF SYS_TMP5
LABEL_LT9_SETFD
	BTFSS S1,5
	GOTO LABEL_LT9_SETFD2
	BSF LT9_FD,0
	GOTO LABEL_LT9_END
LABEL_LT9_SETFD2
	BCF LT9_FD,0
LABEL_LT9_END
; LCD -> LT10
	BTFSC LT10_FD,0
	GOTO LABEL_LT10_SETFD
	BTFSS S1,5
	MOVLW 0
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT10
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT10
	MOVWF SYS_TMP5
LABEL_LT10_SETFD
	BTFSS S1,5
	GOTO LABEL_LT10_SETFD2
	BSF LT10_FD,0
	GOTO LABEL_LT10_END
LABEL_LT10_SETFD2
	BCF LT10_FD,0
LABEL_LT10_END
; Vergleich -> IF3
	MOVLW 12
	SUBWF ZV5,W	; F - W -> W
LABEL_IF3_CHECK
	GOTO LABEL_IF3_FALSE
LABEL_IF3_TRUE
	BSF S1,3
	GOTO LABEL_IF3_EXIT
LABEL_IF3_FALSE
	BCF S1,3
LABEL_IF3_EXIT
; Vergleich -> IF4
	MOVLW 60
	SUBWF ZV6,W	; F - W -> W
LABEL_IF4_CHECK
	GOTO LABEL_IF4_FALSE
LABEL_IF4_TRUE
	BSF S1,4
	GOTO LABEL_IF4_EXIT
LABEL_IF4_FALSE
	BCF S1,4
LABEL_IF4_EXIT
; UND - Gatter -> LG5
LABEL_LG5_1
	BTFSS S0,7
	GOTO LABEL_LG5_FALSE
LABEL_LG5_2
	BTFSS PORTB,6
LABEL_LG5_TRUE
	BSF S1,5
	GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
	BCF S1,5
LABEL_LG5_ENDE
; UND - Gatter -> LG6
LABEL_LG6_1
	BTFSC PORTB,6
	GOTO LABEL_LG6_FALSE
LABEL_LG6_2
	BTFSS S0,7
LABEL_LG6_TRUE
	BSF S1,6
	GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
	BCF S1,6
LABEL_LG6_ENDE
; LCD -> LT11
	BTFSC LT11_FD,0
	GOTO LABEL_LT11_SETFD
	BTFSS S1,6
	MOVLW 0
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT11
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT11
	MOVWF SYS_TMP5
LABEL_LT11_SETFD
	BTFSS S1,6
	GOTO LABEL_LT11_SETFD2
	BSF LT11_FD,0
	GOTO LABEL_LT11_END
LABEL_LT11_SETFD2
	BCF LT11_FD,0
LABEL_LT11_END
; GND
	BCF S1,7	; immer Low
	GOTO MAIN
TAB_LT4
	RETLW 80	; P
	RETLW 69	; E
	RETLW 82	; R
	RETLW 67	; C
	RETLW 0	; end
TAB_LT5
	RETLW 211	; Ó
	RETLW 82	; R
	RETLW 65	; A
	RETLW 0	; end
TAB_LT8
	RETLW 243	; ó
	RETLW 114	; r
	RETLW 97	; a
	RETLW 0	; end
TAB_LT9
	RETLW 112	; p
	RETLW 101	; e
	RETLW 114	; r
	RETLW 99	; c
	RETLW 0	; end
TAB_LT10
	RETLW 32	;  
	RETLW 201	; É
	RETLW 66	; B
	RETLW 82	; R
	RETLW 46	; .
	RETLW 0	; end
TAB_LT11
	RETLW 32	;  
	RETLW 201	; É
	RETLW 66	; B
	RETLW 82	; R
	RETLW 69	; E
	RETLW 83	; S
	RETLW 90	; Z
	RETLW 84	; T
	RETLW 201	; É
	RETLW 83	; S
	RETLW 45	; -
	RETLW 32	;  
	RETLW 75	; K
	RETLW 73	; I
	RETLW 45	; -
	RETLW 32	;  
	RETLW 32	;  
	RETLW 32	;  
	RETLW 0	; end
	END
