CCS PCH C Compiler, Version 4.088, 36728               26-aug.-09 18:53
               Filename: E:\Raktar\Elektronika\AGC-Ferro\main.lst
               ROM used: 728 bytes (4%)
                         Largest free fragment is 15656
               RAM used: 14 (2%) at main() level
                         19 (2%) worst case
               Stack:    2 locations
0000:  GOTO   019E
.................... #include "E:\Raktar\Elektronika\AGC-Ferro\main.h" 
.................... #include <18F14K50.h> 
.................... //////// Standard Header file for the PIC18F14K50 device //////////////// 
.................... #device PIC18F14K50 
.................... #list 
.................... #device adc=8 
.................... #FUSES NOWDT                    //No Watch Dog Timer 
.................... #FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale 
.................... #FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT 
.................... #FUSES FCMEN                    //Fail-safe clock monitor enabled 
.................... #FUSES NOBROWNOUT               //No brownout reset 
.................... #FUSES BORV22                   //Brownout reset at 2.2V 
.................... #FUSES PUT                    // Power Up Timer 
.................... #FUSES NOCPD                    //No EE protection 
.................... #FUSES STVREN                   //Stack full/underflow will cause reset 
.................... #FUSES NODEBUG                  //No Debug mode for ICD 
.................... #FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode) 
.................... #FUSES NOWRT                    //Program memory not write protected 
.................... #FUSES NOWRTD                   //Data EEPROM not write protected 
.................... #FUSES NOWRTC                   //configuration not registers write protected 
.................... #FUSES IESO                     //Internal External Switch Over mode enabled 
.................... #FUSES NOEBTR                   //Memory not protected from table reads 
.................... #FUSES NOEBTRB                  //Boot block not protected from table reads 
.................... #FUSES MCLR                     //Master Clear pin enabled 
.................... #FUSES NOPROTECT                //Code not protected from reading 
.................... #FUSES NOCPB                    //No Boot Block code protection 
.................... #FUSES NOWRTB                   //Boot block not write protected 
.................... #FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O 
.................... #FUSES NOHFOFST               
.................... #FUSES WRT0                   
.................... #FUSES WRT1                   
.................... #FUSES USBDIV2                
.................... #FUSES PCLKEN                 
.................... #FUSES BBSIZ2K                  //2K words Boot Block size 
.................... #FUSES PLLEN                  
.................... #FUSES CPUDIV4                  //System Clock by 4 
.................... #use delay(clock=8000000) 
0004:  MOVLW  09
0006:  SUBWF  12,F
0008:  BNC   0020
000A:  CLRF   FEA
000C:  MOVLW  12
000E:  MOVWF  FE9
0010:  BCF    FD8.0
0012:  RRCF   FEF,F
0014:  MOVF   FEF,W
0016:  BZ    0020
0018:  BRA    001C
001A:  NOP   
001C:  DECFSZ FEF,F
001E:  BRA    001A
0020:  RETLW  00
006C:  CLRF   FEA
006E:  MOVLW  0E
0070:  MOVWF  FE9
0072:  MOVF   FEF,W
0074:  BZ    0090
0076:  MOVLW  02
0078:  MOVWF  01
007A:  CLRF   00
007C:  DECFSZ 00,F
007E:  BRA    007C
0080:  DECFSZ 01,F
0082:  BRA    007A
0084:  MOVLW  97
0086:  MOVWF  00
0088:  DECFSZ 00,F
008A:  BRA    0088
008C:  DECFSZ FEF,F
008E:  BRA    0076
0090:  RETLW  00
.................... #include <float.h> 
.................... ////        (C) Copyright 1996,2003 Custom Computer Services           //// 
.................... //// This source code may only be used by licensed users of the CCS C  //// 
.................... //// compiler.  This source code may only be distributed to other      //// 
.................... //// licensed users of the CCS C compiler.  No other use, reproduction //// 
.................... //// or distribution is permitted without written permission.          //// 
.................... //// Derivative programs created using this software in object code    //// 
.................... //// form are not restricted in any way.                               //// 
.................... /* float.h  */ 
.................... #ifndef _FLOAT 
.................... #define _FLOAT 
....................     /* Float properties */ 
.................... #define FLT_RADIX       2 
.................... #define FLT_MANT_DIG    24                              // # of bits in mantissa 
.................... #define FLT_DIG         6                               // # of decimal digits of precision 
.................... #define FLT_MIN_EXP     (-125)                          // min binary exponent 
.................... #define FLT_MIN_10_EXP  (-37)                           // min decimal exponent 
.................... #define FLT_MAX_EXP     128                             // max binary exponent 
.................... #define FLT_MAX_10_EXP  38                              // max decimal exponent 
.................... #define FLT_MAX         3.402823466e+38F                // max value 
.................... #define FLT_EPSILON     1.192092896e-07F                // smallest such that 1.0+FLT_EPSILON != 1.0 
.................... #define FLT_MIN         1.175494351e-38F                // min positive value 
....................       /* Double properties */ 
.................... #define DBL_MANT_DIG    53                              // # of bits in mantissa 
.................... #define DBL_DIG         15                              // # of decimal digits of precision 
.................... #define DBL_MIN_EXP     (-1021)                         // min binary exponent 
.................... #define DBL_MIN_10_EXP  (-307)                          // min decimal exponent 
.................... #define DBL_MAX_EXP     1024                            // max binary exponent 
.................... #define DBL_MAX_10_EXP  308                             // max decimal exponent 
.................... #define DBL_MAX         1.79769313486231e+308F          // max value 
.................... #define DBL_EPSILON     2.2204460492503131e-16F         // smallest such that 1.0+FLT_EPSILON != 1.0 
.................... #define DBL_MIN         2.22507385850721e-308F          // min positive value 
....................          /*Long double properties */ 
.................... #define LDBL_MANT_DIG    64                             // # of bits in mantissa 
.................... #define LDBL_DIG         18                             // # of decimal digits of precision 
.................... #define LDBL_MIN_EXP     (-16381)                       // min binary exponent 
.................... #define LDBL_MIN_10_EXP  (-4931)                        // min decimal exponent 
.................... #define LDBL_MAX_EXP     16384                          // max binary exponent 
.................... #define LDBL_MAX_10_EXP  4932                           // max decimal exponent 
.................... #define LDBL_MAX         1.18973149535723176502e+4932F  // max value 
.................... #define LDBL_EPSILON     1.084202172485504434e-019F     // smallest such that 1.0+FLT_EPSILON != 1.0 
.................... #define LDBL_MIN         3.36210314311209350626e-4932F  // min positive value 
.................... #endif 
.................... #include <math.h> 
.................... ////        (C) Copyright 1996,2008 Custom Computer Services            //// 
.................... //// History:                                                           //// 
.................... ////  * 9/20/2001 :  Improvments are made to sin/cos code.              //// 
.................... ////                 The code now is small, much faster,                //// 
.................... ////                 and more accurate.                                 //// 
.................... ////  * 2/21/2007 :  Compiler handles & operator differently and does 
.................... ////                 not return generic (int8 *) so type cast is done   //// 
.................... #ifndef MATH_H 
.................... #define MATH_H 
.................... #ifdef PI 
.................... #undef  PI 
.................... #define PI     3.1415926535897932 
.................... #define SQRT2  1.4142135623730950 
.................... //float const ps[4] = {5.9304945, 21.125224, 8.9403076, 0.29730279}; 
.................... //float const qs[4] = {1.0000000, 15.035723, 17.764134, 2.4934718}; 
.................... ///////////////////////////// Round Functions ////////////////////////////// 
.................... float32 CEIL_FLOOR(float32 x, unsigned int8 n) 
....................    float32 y, res; 
....................    unsigned int16 l; 
....................    int1 s; 
....................    s = 0; 
....................    y = x; 
....................    if (x < 0) 
....................       s = 1; 
....................       y = -y; 
....................    if (y <= 32768.0) 
....................   res = (float32)(unsigned int16)y; 
....................  else if (y < 10000000.0) 
....................   l = (unsigned int16)(y/32768.0); 
....................       y = 32768.0*(y/32768.0 - (float32)l); 
....................   res = 32768.0*(float32)l; 
....................   res += (float32)(unsigned int16)y; 
....................   res = y; 
....................  y = y - (float32)(unsigned int16)y; 
....................  if (s) 
....................   res = -res; 
....................  if (y != 0) 
....................   if (s == 1 && n == 0) 
....................    res -= 1.0; 
....................   if (s == 0 && n == 1) 
....................    res += 1.0; 
....................  if (x == 0) 
....................     res = 0; 
....................  return (res); 
.................... // Overloaded Functions to take care for new Data types in PCD 
.................... // Overloaded function CEIL_FLOOR() for data type - Float48 
.................... #if defined(__PCD__) 
.................... float48 CEIL_FLOOR(float48 x, unsigned int8 n) 
....................    float48 y, res; 
....................   res = (float48)(unsigned int16)y; 
....................       y = 32768.0*(y/32768.0 - (float48)l); 
....................   res += (float48)(unsigned int16)y; 
....................  y = y - (float48)(unsigned int16)y; 
.................... // Overloaded function CEIL_FLOOR() for data type - Float64 
.................... float64 CEIL_FLOOR(float64 x, unsigned int8 n) 
....................    float64 y, res; 
....................   res = (float64)(unsigned int16)y; 
....................       y = 32768.0*(y/32768.0 - (float64)l); 
....................   res = 32768.0*(float64)l; 
....................   res += (float64)(unsigned int16)y; 
....................  y = y - (float64)(unsigned int16)y; 
.................... //   float floor(float x) 
.................... // Description : rounds down the number x. 
.................... // Date : N/A 
.................... float32 floor(float32 x) 
....................    return CEIL_FLOOR(x, 0); 
.................... // Following 2 functions are overloaded functions of floor() for PCD 
.................... // Overloaded function floor() for data type - Float48 
.................... float48 floor(float48 x) 
.................... // Overloaded function floor() for data type - Float64 
.................... float64 floor(float64 x) 
.................... //   float ceil(float x) 
.................... // Description : rounds up the number x. 
.................... float32 ceil(float32 x) 
....................    return CEIL_FLOOR(x, 1); 
.................... // Following 2 functions are overloaded functions of ceil() for PCD 
.................... // Overloaded function ceil() for data type - Float48 
.................... float48 ceil(float48 x) 
.................... // Overloaded function ceil() for data type - Float64 
.................... float64 ceil(float64 x) 
.................... //   float fabs(float x) 
.................... // Description : Computes the absolute value of floating point number x 
.................... // Returns : returns the absolute value of x 
.................... #define fabs abs 
.................... //   float fmod(float x) 
.................... // Description : Computes the floating point remainder of x/y 
.................... // Returns : returns the value of x= i*y, for some integer i such that, if y 
.................... // is non zero, the result has the same isgn of x na dmagnitude less than the 
.................... // magnitude of y. If y is zero then a domain error occurs. 
.................... float fmod(float32 x,float32 y) 
....................    float32 i; 
....................    if (y!=0.0) 
....................       i=(x/y < 0.0)? ceil(x/y): floor(x/y); 
....................       return(x-(i*y)); 
....................    #ifdef _ERRNO 
....................       errno=EDOM; 
.................... //Overloaded function for fmod() for PCD 
.................... // Overloaded function fmod() for data type - Float48 
.................... float48 fmod(float48 x,float48 y) 
....................    float48 i; 
.................... // Overloaded function fmod() for data type - Float64 
.................... float64 fmod(float64 x,float64 y) 
....................    float64 i; 
.................... //////////////////// Exponential and logarithmic functions //////////////////// 
.................... //   float exp(float x) 
.................... // Description : returns the value (e^x) 
.................... #define LN2 0.6931471805599453 
.................... float const pe[6] = {0.000207455774, 0.00127100575, 0.00965065093, 
....................                      0.0554965651,  0.240227138,  0.693147172}; 
.................... float32 exp(float32 x) 
....................    float32 y, res, r; 
....................    int8 data1; 
....................    signed int8 n; 
....................    if(x > 88.722838) 
....................       errno=ERANGE; 
....................       return(0); 
....................    n = (signed int16)(x/LN2); 
....................       n = -n; 
....................    res = 0.0; 
.................... #if !defined(__PCD__) 
....................    *((unsigned int8 *)(&res)) = n + 0x7F; 
.................... #if defined(__PCD__)  // Takes care of IEEE format for PCD 
....................    data1 = n+0x7F; 
....................    if(bit_test(data1,0)) 
....................    bit_set(*(((unsigned int8 *)(&res)+2)),7); 
....................    rotate_right(&data1,1); 
....................    bit_clear(data1,7); 
....................    *(((unsigned int8 *)(&res)+3)) = data1; 
....................    y = y/LN2 - (float32)n; 
....................    r = pe[0]*y + pe[1]; 
....................    r = r*y + pe[2]; 
....................    r = r*y + pe[3]; 
....................    r = r*y + pe[4]; 
....................    r = r*y + pe[5]; 
....................    res = res*(1.0 + y*r); 
....................       res = 1.0/res; 
....................    return(res); 
.................... //Overloaded function for exp() for PCD 
.................... // Overloaded function exp() for data type - Float48 
.................... float48 exp(float48 x) 
....................    float48 y, res, r; 
....................    bit_set(*(((unsigned int8 *)(&res)+4)),7); 
....................    *(((unsigned int8 *)(&res)+5)) = data1; 
....................    y = y/LN2 - (float48)n; 
.................... // Overloaded function exp() for data type - Float64 
.................... float64 exp(float64 x) 
....................    float64 y, res, r; 
....................    unsigned int16 data1, data2; 
....................    unsigned int16 *p; 
....................    signed int16 n; 
....................    if(x > 709.7827128) 
....................    *((unsigned int16 *)(&res)) = n + 0x7F; 
....................    p= (((unsigned int16 *)(&res))+3); 
....................    data1 = *p; 
....................    data2 = *p;    
....................    data1 = n + 0x3FF; 
....................    data1 = data1 <<4; 
....................    if(bit_test(data2,15)) 
....................    bit_set(data1,15); 
....................    data2 = data2 & 0x000F; 
....................    data1 ^= data2; 
....................    *(((unsigned int16 *)(&res)+3)) = data1; 
....................    y = y/LN2 - (float64)n; 
.................... #ENDIF 
.................... float32 const pl[4] = {0.45145214, -9.0558803, 26.940971, -19.860189}; 
.................... float32 const ql[4] = {1.0000000,  -8.1354259, 16.780517, -9.9300943}; 
.................... //   float log(float x) 
.................... // Description : returns the the natural log of x 
.................... float32 log(float32 x) 
....................    float32 y, res, r, y2; 
....................    unsigned int8  data1,data2; 
....................    if(x <0) 
....................    if(x ==0) 
....................    if (y != 1.0) 
....................     *((unsigned int8 *)(&y)) = 0x7E;  
....................    data2 = *(((unsigned int8 *)(&y))+3); 
....................    *(((unsigned int8 *)(&y))+3) = 0x3F; 
....................    data1 = *(((unsigned int8 *)(&y))+2); 
....................    *(((unsigned int8 *)(&y))+2) = data1; 
....................    if(bit_test(data2,7)) 
....................    bit_set(*(((unsigned int8 *)(&y))+3),7); 
....................       y = (y - 1.0)/(y + 1.0); 
....................       y2=y*y; 
....................       res = pl[0]*y2 + pl[1]; 
....................       res = res*y2 + pl[2]; 
....................       res = res*y2 + pl[3]; 
....................       r = ql[0]*y2 + ql[1]; 
....................       r = r*y2 + ql[2]; 
....................       r = r*y2 + ql[3]; 
....................       res = y*res/r; 
....................       n = *((unsigned int8 *)(&x)) - 0x7E; 
....................     data1 = *(((unsigned int8 *)(&x)+3)); 
....................     rotate_left(&data1,1); 
....................     data2 = *(((unsigned int8 *)(&x)+2)); 
....................     if(bit_test (data2,7)) 
....................       bit_set(data1,0); 
....................     n = data1 - 0x7E; 
....................       if (n<0)  
....................          r = -(float32)-n; 
....................          r = (float32)n; 
....................       res += r*LN2; 
.................... //Overloaded function for log() for PCD 
.................... // Overloaded function log() for data type - Float48 
.................... float48 log(float48 x) 
....................    float48 y, res, r, y2; 
....................       data2 = *(((unsigned int8 *)(&y))+5); 
....................       *(((unsigned int8 *)(&y))+5) = 0x3F; 
....................       data1 = *(((unsigned int8 *)(&y))+4); 
....................       *(((unsigned int8 *)(&y))+4) = data1; 
....................          bit_set(*(((unsigned int8 *)(&y))+4),7); 
....................     data1 = *(((unsigned int8 *)(&x)+5)); 
....................     data2 = *(((unsigned int8 *)(&x)+4)); 
....................          r = -(float48)-n; 
....................          r = (float48)n; 
.................... float32 const pl_64[4] = {0.45145214, -9.0558803, 26.940971, -19.860189}; 
.................... float32 const ql_64[4] = {1.0000000,  -8.1354259, 16.780517, -9.9300943}; 
.................... float64 log(float64 x) 
....................    float64 y, res, r, y2; 
....................    unsigned int16  data1,data2; 
....................       p= (((unsigned int16 *)(&y))+3); 
....................       data1 = 0x3FE; 
....................       if(bit_test (data2,15)) 
....................       data1 ^=data2; 
....................       *p = data1; 
....................       res = pl_64[0]*y2 + pl_64[1]; 
....................       res = res*y2 + pl_64[2]; 
....................       res = res*y2 + pl_64[3]; 
....................       r = ql_64[0]*y2 + ql_64[1]; 
....................       r = r*y2 + ql_64[2]; 
....................       r = r*y2 + ql_64[3]; 
....................       p= (((unsigned int16 *)(&x))+3); 
....................       bit_clear(data1,15); 
....................       data1 = data1 >>4;     
....................       n = data1 - 0x3FE; 
....................          r = -(float64)-n; 
....................          r = (float64)n; 
.................... #define LN10 2.3025850929940456 
.................... //   float log10(float x) 
.................... // Description : returns the the log base 10 of x 
.................... float32 log10(float32 x) 
....................    float32 r; 
....................    r = log(x); 
....................    r = r/LN10; 
....................    return(r); 
.................... //Overloaded functions for log10() for PCD 
.................... // Overloaded function log10() for data type - Float48 
.................... float48 log10(float48 x) 
....................    float48 r; 
.................... // Overloaded function log10() for data type - Float64 
.................... float64 log10(float64 x) 
....................    float64 r; 
.................... //   float modf(float x) 
.................... // Description :breaks the argument value int integral and fractional parts, 
.................... // ach of which have the same sign as the argument.  It stores the integral part 
.................... // as a float in the object pointed to by the iptr 
.................... // Returns : returns the signed fractional part of value. 
.................... float32 modf(float32 value,float32 *iptr) 
....................    *iptr=(value < 0.0)? ceil(value): floor(value); 
....................    return(value - *iptr); 
.................... //Overloaded functions for modf() for PCD 
.................... // Overloaded function modf() for data type - Float48 
.................... float48 modf(float48 value,float48 *iptr) 
.................... // Overloaded function modf() for data type - Float64 
.................... float64 modf(float64 value,float64 *iptr) 
.................... //   float pwr(float x,float y) 
.................... // Description : returns the value (x^y) 
.................... float32 pwr(float32 x,float32 y) 
....................    if(x>=0) 
....................      return(  exp(y*log(x)) ); 
....................      return(  -exp(y*log(-x)) ); 
.................... //Overloaded functions for pwr() for PCD 
.................... // Overloaded function pwr() for data type - Float48 
.................... float48 pwr(float48 x,float48 y) 
.................... // Overloaded function pwr() for data type - Float64 
.................... float64 pwr(float64 x,float64 y) 
.................... //////////////////// Power functions //////////////////// 
.................... //   float pow(float x,float y) 
.................... float32 pow(float32 x,float32 y) 
.................... //Overloaded functions for pow() for PCD 
.................... // Overloaded function for pow() data type - Float48 
.................... float48 pow(float48 x,float48 y) 
.................... // Overloaded function pow() for data type - Float64 
.................... float64 pow(float64 x,float64 y) 
.................... //   float sqrt(float x) 
.................... // Description : returns the square root of x 
.................... float32 sqrt(float32 x) 
....................    BYTE *p; 
....................    if(x < 0) 
....................    if( x<=0.0) 
....................       return(0.0); 
....................    y=x; 
....................     p=&y; 
....................    (*p)=(BYTE)((((unsigned int16)(*p)) + 127) >> 1); 
....................     p = (((unsigned int8 *)(&y))+3); 
....................     data1 = *(((unsigned int8 *)(&y))+3); 
....................     data2 = *(((unsigned int8 *)(&y))+2); 
....................     data1 = ((data1+127) >>1); 
....................     bit_clear(data2,7); 
....................     bit_set(data2,7); 
....................     data1 = data1 >>1; 
....................     *(((unsigned int8 *)(&y))+3) = data1; 
....................     *(((unsigned int8 *)(&y))+2) = data2; 
....................    do { 
....................       res=y; 
....................       y+=(x/y); 
....................      (*p)--; 
....................     data1--; 
....................    } while(res != y); 
.................... //Overloaded functions for sqrt() for PCD 
.................... // Overloaded function sqrt() for data type - Float48 
.................... float48 sqrt(float48 x) 
....................     p = (((unsigned int8 *)(&y))+5); 
....................     data1 = *(((unsigned int8 *)(&y))+5); 
....................     data2 = *(((unsigned int8 *)(&y))+4); 
....................     *(((unsigned int8 *)(&y))+5) = data1; 
....................     *(((unsigned int8 *)(&y))+4) = data2; 
.................... // Overloaded function sqrt() for data type - Float64 
.................... float64 sqrt(float64 x) 
....................    unsigned int16 temp1,temp2; 
....................    temp1 = *p; 
....................    temp2 = *p; 
....................    bit_clear(temp1,15); 
....................    temp1 = (temp1>>4)+1023; 
....................    temp1 = temp1 >> 1; 
....................    temp1 = (temp1<<4) & 0xFFF0; 
....................    if(bit_test(temp2,15)) 
....................    bit_set(temp1,15); 
....................    temp2 = temp2 & 0x000F; 
....................    temp1 ^= temp2; 
....................    (*p) = temp1; 
....................      temp1 = (temp1>>4); 
....................      temp1--; 
.................... ////////////////////////////// Trig Functions ////////////////////////////// 
.................... #ifdef PI_DIV_BY_TWO 
.................... #undef PI_DIV_BY_TWO 
.................... #define PI_DIV_BY_TWO   1.5707963267948966 
.................... #ifdef TWOBYPI 
.................... #undef TWOBYPI 
.................... #define TWOBYPI          0.6366197723675813 
.................... //   float cos(float x) 
.................... // Description : returns the cosine value of the angle x, which is in radian 
.................... // Date : 9/20/2001 
.................... float32 cos(float32 x) 
....................    float32 y, t, t2 = 1.0; 
....................    unsigned int8 quad, i; 
....................    float32 frac; 
....................    float32 p[4] = { 
....................       -0.499999993585, 
....................        0.041666636258, 
....................       -0.0013888361399, 
....................        0.00002476016134 
....................    if (x < 0) x = -x;                  // absolute value of input 
....................    quad = (unsigned int8)(x / PI_DIV_BY_TWO);    // quadrant 
....................    frac = (x / PI_DIV_BY_TWO) - quad;  // fractional part of input 
....................    quad = quad % 4;                    // quadrant (0 to 3) 
....................    if (quad == 0 || quad == 2) 
....................       t = frac * PI_DIV_BY_TWO; 
....................    else if (quad == 1) 
....................       t = (1-frac) * PI_DIV_BY_TWO; 
....................    else // should be 3 
....................       t = (frac-1) * PI_DIV_BY_TWO; 
....................    y = 0.999999999781; 
....................    t = t * t; 
....................    for (i = 0; i <= 3; i++) 
....................       t2 = t2 * t; 
....................       y = y + p[i] * t2; 
....................    if (quad == 2 || quad == 1) 
....................       y = -y;  // correct sign 
....................    return (y); 
.................... //Overloaded functions for cos() for PCD 
.................... // Overloaded function cos() for data type - Float48 
.................... float48 cos(float48 x) 
....................    float48 y, t, t2 = 1.0; 
....................    float48 frac; 
....................    float48 p[4] = { 
.................... float64 cos(float64 x) 
....................    float64 y, t, t2 = 1.0; 
....................    float64 frac; 
....................    float64 p[4] = { 
.................... //   float sin(float x) 
.................... // Description : returns the sine value of the angle x, which is in radian 
.................... float32 sin(float32 x) 
....................    return cos(x - PI_DIV_BY_TWO); 
.................... //Overloaded functions for sin() for PCD 
.................... // Overloaded function sin() for data type - Float48 
.................... float48 sin(float48 x) 
.................... float64 sin(float64 x) 
.................... //   float tan(float x) 
.................... // Description : returns the tangent value of the angle x, which is in radian 
.................... float32 tan(float32 x) 
....................    float32 c, s; 
....................    c = cos(x); 
....................    if (c == 0.0) 
....................       return (1.0e+36); 
....................    s = sin(x); 
....................    return(s/c); 
.................... //Overloaded functions for tan() for PCD 
.................... // Overloaded function tan() for data type - Float48 
.................... float48 tan(float48 x) 
....................    float48 c, s; 
.................... float64 tan(float64 x) 
....................    float64 c, s; 
.................... float32 const pas[3] = {0.49559947, -4.6145309, 5.6036290}; 
.................... float32 const qas[3] = {1.0000000,  -5.5484666, 5.6036290}; 
.................... float32 ASIN_COS(float32 x, unsigned int8 n) 
....................    if(x <-1 || x > 1) 
....................    if (y > 0.5) 
....................       y = sqrt((1.0 - y)/2.0); 
....................       n += 2; 
....................    res = pas[0]*y2 + pas[1]; 
....................    res = res*y2 + pas[2]; 
....................    r = qas[0]*y2 + qas[1]; 
....................    r = r*y2 + qas[2]; 
....................    if (n & 2)     // |x| > 0.5 
....................       res = PI_DIV_BY_TWO - 2.0*res; 
....................    if (n & 1)           // take arccos 
....................       res = PI_DIV_BY_TWO - res; 
.................... //Overloaded functions for ASIN_COS() for PCD 
.................... // Overloaded function ASIN_COS() for data type - Float48 
.................... float48 ASIN_COS(float48 x, unsigned int8 n) 
.................... // Overloaded function ASIN_COS() for data type - Float64 
.................... float64 ASIN_COS(float64 x, unsigned int8 n) 
.................... //   float asin(float x) 
.................... // Description : returns the arcsine value of the value x. 
.................... float32 asin(float32 x) 
....................    r = ASIN_COS(x, 0); 
.................... //Overloaded functions for asin() for PCD 
.................... // Overloaded function asin() for data type - Float48 
.................... float48 asin(float48 x) 
.................... // Overloaded function asin() for data type - Float64 
.................... float64 asin(float64 x) 
.................... //   float acos(float x) 
.................... // Description : returns the arccosine value of the value x. 
.................... float32 acos(float32 x) 
....................    r = ASIN_COS(x, 1); 
.................... //Overloaded functions for acos() for PCD 
.................... // Overloaded function acos() for data type - Float48 
.................... float48 acos(float48 x) 
.................... // Overloaded function acos() for data type - Float64 
.................... float64 acos(float64 x) 
.................... float32 const pat[4] = {0.17630401, 5.6710795, 22.376096, 19.818457}; 
.................... float32 const qat[4] = {1.0000000,  11.368190, 28.982246, 19.818457}; 
.................... //   float atan(float x) 
.................... // Description : returns the arctangent value of the value x. 
.................... float32 atan(float32 x) 
....................    int1 s, flag; 
....................    flag = 0; 
....................    if (y > 1.0) 
....................       y = 1.0/y; 
....................       flag = 1; 
....................    res = pat[0]*y*y + pat[1]; 
....................    res = res*y*y + pat[2]; 
....................    res = res*y*y + pat[3]; 
....................    r = qat[0]*y*y + qat[1]; 
....................    r = r*y*y + qat[2]; 
....................    r = r*y*y + qat[3]; 
....................    if (flag)                              // for |x| > 1 
.................... //Overloaded functions for atan() for PCD 
.................... // Overloaded function atan() for data type - Float48 
.................... float48 atan(float48 x) 
.................... // Overloaded function atan() for data type - Float64 
.................... float64 atan(float64 x) 
.................... //   float atan2(float y, float x) 
.................... // Description :computes the principal value of arc tangent of y/x, using the 
.................... // signs of both the arguments to determine the quadrant of the return value 
.................... // Returns : returns the arc tangent of y/x. 
.................... float32 atan2(float32 y,float32 x) 
....................    float32 z; 
....................    int1 sign; 
....................    unsigned int8 quad; 
....................    sign=0; 
....................    quad=0; //quadrant 
....................    quad=((y<=0.0)?((x<=0.0)?3:4):((x<0.0)?2:1)); 
....................    if(y<0.0) 
....................       sign=1; 
....................       y=-y; 
....................    if(x<0.0) 
....................       x=-x; 
....................    if (x==0.0) 
....................       if(y==0.0) 
....................          if(sign) 
....................          return (-(PI_DIV_BY_TWO)); 
....................          return (PI_DIV_BY_TWO); 
....................       z=y/x; 
....................       switch(quad) 
....................          case 1: 
....................             return atan(z); 
....................             break; 
....................          case 2: 
.................... //            return (atan(z)+PI_DIV_BY_TWO);  //2L3122 
....................             return (PI-atan(z)); 
....................          case 3: 
....................             return (atan(z)-PI); 
....................          case 4: 
....................             return (-atan(z)); 
.................... //Overloaded functions for atan2() for PCD 
.................... // Overloaded function atan2() for data type - Float48 
.................... float48 atan2(float48 y,float48 x) 
....................    float48 z; 
.................... // Overloaded function atan2() for data type - Float64 
.................... float64 atan2(float64 y,float64 x) 
....................    float64 z; 
.................... //////////////////// Hyperbolic functions //////////////////// 
.................... //   float cosh(float x) 
.................... // Description : Computes the hyperbolic cosine value of x 
.................... // Returns : returns the hyperbolic cosine value of x 
.................... float32 cosh(float32 x) 
....................    return ((exp(x)+exp(-x))/2); 
.................... //Overloaded functions for cosh() for PCD 
.................... // Overloaded function cosh() for data type - Float48 
.................... float48 cosh(float48 x) 
.................... // Overloaded function cosh() for data type - Float64 
.................... float64 cosh(float64 x) 
.................... //   float sinh(float x) 
.................... // Description : Computes the hyperbolic sine value of x 
.................... // Returns : returns the hyperbolic sine value of x 
.................... float32 sinh(float32 x) 
....................    return ((exp(x) - exp(-x))/2); 
.................... //Overloaded functions for sinh() for PCD 
.................... // Overloaded function sinh() for data type - Float48 
.................... float48 sinh(float48 x) 
.................... float64 sinh(float64 x) 
.................... //   float tanh(float x) 
.................... // Description : Computes the hyperbolic tangent value of x 
.................... // Returns : returns the hyperbolic tangent value of x 
.................... float32 tanh(float32 x) 
....................    return(sinh(x)/cosh(x)); 
.................... //Overloaded functions for tanh() for PCD 
.................... // Overloaded function tanh() for data type - Float48 
.................... float48 tanh(float48 x) 
.................... // Overloaded function tanh() for data type - Float64 
.................... float64 tanh(float64 x) 
.................... //   float frexp(float x, signed int *exp) 
.................... // Description : breaks a floating point number into a normalized fraction and an integral 
.................... // power of 2. It stores the integer in the signed int object pointed to by exp. 
.................... // Returns : returns the value x, such that x is a double with magnitude in the interval 
.................... // [1/2,1) or zero, and value equals x times 2 raised to the power *exp.If value is zero, 
.................... // both parts of the result are zero. 
.................... #define LOG2 .30102999566398119521 
.................... float32 frexp(float32 x, signed int8 *exp) 
....................    float32 res; 
....................    int1 sign = 0; 
....................    if(x == 0.0) 
....................       *exp=0; 
....................       return (0.0); 
....................    if(x < 0.0) 
....................    if (x > 1.0) 
....................       *exp=(ceil(log10(x)/LOG2)); 
....................       res=x/(pow(2, *exp)); 
....................       if (res == 1) 
....................          *exp=*exp+1; 
....................           res=.5; 
....................       if(x < 0.5) 
....................          *exp=-1; 
....................          res=x*2; 
....................           res=x; 
....................       res=-res; 
....................    return res; 
.................... //Overloaded functions for frexp() for PCD 
.................... // Overloaded function frexp() for data type - Float48 
.................... float48 frexp(float48 x, signed int8 *exp) 
....................    float48 res; 
.................... // Overloaded function frexp() for data type - Float64 
.................... float64 frexp(float64 x, signed int8 *exp) 
....................    float64 res; 
.................... //   float ldexp(float x, signed int *exp) 
.................... // Description : multiplies a floating point number by an integral power of 2. 
.................... // Returns : returns the value of x times 2 raised to the power exp. 
.................... float32 ldexp(float32 value, signed int8 exp) 
....................    return (value * pow(2,exp)); 
.................... //Overloaded functions for ldexp() for PCD 
.................... // Overloaded function ldexp() for data type - Float48 
.................... float48 ldexp(float48 value, signed int8 exp) 
.................... // Overloaded function ldexp() for data type - Float64 
.................... float64 ldexp(float64 value, signed int8 exp) 
.................... #include <stdio.h> 
.................... #ifndef _STDIO 
.................... #define _STDIO 
.................... #include <string.h> 
.................... #ifndef _STRING 
.................... #define _STRING 
.................... #include <stddef.h> 
.................... #ifndef _STDDEF 
.................... #define _STDDEF 
.................... #if sizeof(unsigned int8 *)==1 
.................... #define ptrdiff_t unsigned int8 
.................... #else 
.................... #define ptrdiff_t unsigned int16 
.................... #define size_t unsigned int8 
.................... #define wchar_t char 
.................... #define NULL 0 
.................... #define offsetof(s,f) (offsetofbit(s,f)/8) 
.................... #include <ctype.h> 
.................... #ifndef _CTYPE 
.................... #define _CTYPE 
.................... #define islower(x)  isamong(x,"abcdefghijklmnopqrstuvwxyz") 
.................... #define isupper(x)  isamong(x,"ABCDEFGHIJKLMNOPQRSTUVWXYZ") 
.................... #define isalnum(x)  isamong(x,"0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz") 
.................... #define isalpha(x)  isamong(x,"ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz") 
.................... #define isdigit(x)  isamong(x,"0123456789") 
.................... #define isspace(x)  ((x)==' ') 
.................... #define isxdigit(x) isamong(x,"0123456789ABCDEFabcdef") 
.................... #define iscntrl(x)  ((x)<' ') 
.................... #define isprint(x)  ((x)>=' ') 
.................... #define isgraph(x)  ((x)>' ') 
.................... #define ispunct(x)  (((x)>' ')&&!isalnum(x)) 
.................... //// Uncomment the following define to    //// 
.................... //// allow some functions to use a        //// 
.................... //// quicker algorithm, but use more ROM  //// 
.................... //// #define FASTER_BUT_MORE_ROM          //// 
.................... /*Copying functions*/ 
.................... /* standard template: 
....................    void *memmove(void *s1, void *s2, size_t n). 
....................    Copies max of n characters safely (not following ending '\0') 
....................    from s2 in s1; if s2 has less than n characters, appends 0 */ 
.................... char *memmove(void *s1,char *s2,size_t n) 
....................    char *sc1; 
....................    char *sc2; 
....................    sc1=s1; 
....................    sc2=s2; 
....................    if(sc2<sc1 && sc1 <sc2 +n) 
....................       for(sc1+=n,sc2+=n;0<n;--n) 
....................          *--sc1=*--sc2; 
....................       for(;0<n;--n) 
....................          *sc1++=*sc2++; 
....................   return s1; 
.................... /* Standard template: char *strcpy(char *s1, const char *s2) 
....................    copies the string s2 including the null character to s1. 
....................    This is a compiler built in to handle the different address 
....................    spaces */ 
.................... #define strcopy strcpy 
....................    char *strncpy(char *s1, const char *s2, size_t n). 
....................    Copies max of n characters (not following ending '\0') 
.................... char *strncpy(char *s1, char *s2, size_t n) 
....................   char *s; 
....................   for (s = s1; n > 0 && *s2 != '\0'; n--) 
....................      *s++ = *s2++; 
....................   for (; n > 0; n--) 
....................      *s++ = '\0'; 
....................   return(s1); 
.................... /*concatenation functions*/ 
.................... /* standard template: char *strcat(char *s1, const char *s2) 
.................... appends s2 to s1*/ 
.................... char *strcat(char *s1, char *s2) 
....................    for (s = s1; *s != '\0'; ++s); 
....................    while(*s2 != '\0') 
....................       *s = *s2; 
....................       ++s; 
....................       ++s2; 
....................    *s = '\0'; 
.................... /* standard template: char *strncat(char *s1, char *s2,size_t n) 
.................... appends not more than n characters from s2 to s1*/ 
.................... char *strncat(char *s1, char *s2, size_t n) 
....................    while(*s2 != '\0' && 0<n) 
....................       --n; 
.................... /*comparison functions*/ 
.................... /* standard template: signed int memcmp(void *s1, void *s2). 
....................    Compares s1 & s2; returns -1 if s1<s2, 0 if s1=s2, 1 if s1>s2 */ 
.................... signed int8 memcmp(void * s1,char *s2,size_t n) 
.................... char *su1, *su2; 
.................... for(su1=s1, su2=s2; 0<n; ++su1, ++su2, --n) 
....................    if(*su1!=*su2) 
....................       return ((*su1<*su2)?-1:+1); 
.................... return 0; 
.................... /* standard template: int strcmp(const char *s1, const char *s2). 
.................... signed int8 strcmp(char *s1, char *s2) 
....................    for (; *s1 == *s2; s1++, s2++) 
....................       if (*s1 == '\0') 
....................    return((*s1 < *s2) ? -1: 1); 
.................... /* standard template: int strcoll(const char *s1, const char *s2). 
.................... signed int8 strcoll(char *s1, char *s2) 
....................    int strncmp(const char *s1, const char *s2, size_t n). 
....................    Compares max of n characters (not following 0) from s1 to s2; 
....................    returns same as strcmp */ 
.................... signed int8 strncmp(char *s1, char *s2, size_t n) 
....................    for (; n > 0; s1++, s2++, n--) 
....................       if (*s1 != *s2) 
....................          return((*s1 <*s2) ? -1: 1); 
....................       else if (*s1 == '\0') 
....................    int strxfrm(const char *s1, const char *s2, size_t n). 
....................    transforms maximum of n characters from s2 and places them into s1*/ 
.................... size_t strxfrm(char *s1, char *s2, size_t n) 
....................   unsigned int8 n1; 
....................   n1=n; 
....................   return(n1); 
.................... /*Search functions*/ 
.................... /* standard template: void *memchr(const char *s, int c). 
....................    Finds first occurrence of c in n characters of s */ 
.................... char *memchr(void *s,unsigned int8 c,size_t n) 
....................    char uc; 
....................    char *su; 
....................    uc=c; 
....................    for(su=s;0<n;++su,--n) 
....................       if(*su==uc) 
....................       return su; 
....................    return NULL; 
.................... /* standard template: char *strchr(const char *s, int c). 
....................    Finds first occurrence of c in s */ 
.................... char *strchr(char *s, unsigned int8 c) 
....................    for (; *s != c; s++) 
....................       if (*s == '\0') 
....................    return(s); 
....................    size_t strcspn(const char *s1, const char *s2). 
....................    Computes length of max initial segment of s1 that 
....................    consists entirely of characters NOT from s2*/ 
.................... unsigned int8  strcspn(char *s1, char *s2) 
....................    char *sc1, *sc2; 
....................    for (sc1 = s1; *sc1 != 0; sc1++) 
....................       for (sc2 = s2; *sc2 != 0; sc2++) 
....................          if (*sc1 == *sc2) 
....................             return(sc1 - s1); 
....................    char *strpbrk(const char *s1, const char *s2). 
....................    Locates first occurence of any character from s2 in s1; 
....................    returns s1 if s2 is empty string */ 
.................... char *strpbrk(char *s1, char *s2) 
....................             return(sc1); 
.................... /* standard template: char *strrchr(const char *s, int c). 
....................    Finds last occurrence of c in s */ 
.................... char *strrchr(char *s, unsigned int8 c) 
....................    char *p; 
....................    for (p = 0; ; s++) 
....................       if (*s == c) 
....................          p = s; 
....................          return(p); 
.................... /* computes length of max initial segment of s1 consisting 
....................    entirely of characters from s2 */ 
.................... unsigned int8  strspn(char *s1, char *s2) 
....................       for (sc2 = s2; ; sc2++) 
....................     if (*sc2 == '\0') 
....................          else if (*sc1 == *sc2) 
....................    char *strstr(const char *s1, const char *s2); 
....................    Locates first occurence of character sequence s2 in s1; 
....................    returns 0 if s2 is empty string 
....................    Uncomment #define FASTER_BUT_MORE_ROM at the top of the 
....................    file to use the faster algorithm */ 
.................... char *strstr(char *s1, char *s2) 
....................    char *s, *t; 
....................    #ifdef FASTER_BUT_MORE_ROM 
....................    if (*s2 == '\0') 
....................    while (*s1) 
....................       for(s = s1, t = s2; *t && (*s == *t); ++s, ++t); 
....................       if (*t == '\0') 
....................       ++s1; 
....................          while(*s1 != '\0' && *s1 != *s2) 
.................... /* standard template: char *strtok(char *s1, const char *s2). 
....................    Finds next token in s1 delimited by a character from separator 
....................    string s2 (which can be different from call to call).  First call 
....................    starts at beginning of s1 searching for first character NOT 
....................    contained in s2; returns 0 if none is found. 
....................    If one is found, it is the start of first token (return value). 
....................    Function then searches from there for a character contained in s2. 
....................    If none is found, current token extends to end of s1, and subsequent 
....................    searches for a token will return 0.  If one is found, it is 
....................    overwritten by '\0', which terminates current token.  Function saves 
....................    pointer to following character from which next search will start. 
....................    Each subsequent call, with 0 as first argument, starts searching 
....................    from saved pointer */ 
.................... char *strtok(char *s1, char *s2) 
....................    char *beg, *end; 
....................    static char *save; 
....................    beg = (s1)? s1: save; 
....................    beg += strspn(beg, s2); 
....................    if (*beg == '\0') 
....................       *save = ' '; 
....................    end = strpbrk(beg, s2); 
....................    if (*end != '\0') 
....................       *end = '\0'; 
....................       end++; 
....................    save = end; 
....................    return(beg); 
.................... /*Miscellaneous functions*/ 
.................... maps error number in errnum to an error message string 
.................... Returns: Pointer to string 
.................... char * strerror(unsigned int8 errnum) 
.................... char s[15]; 
.................... switch( errnum) 
.................... case 0: 
....................    strcpy(s,"no errors"); 
....................    return s; 
.................... case EDOM : 
....................    strcpy(s,"domain error"); 
.................... case ERANGE: 
....................    strcpy(s,"range error"); 
.................... /* standard template: size_t strlen(const char *s). 
....................    Computes length of s1 (preceding terminating 0) */ 
.................... unsigned int8 strlen(char *s) 
....................    char *sc; 
....................    for (sc = s; *sc != 0; sc++); 
....................    return(sc - s); 
.................... /* standard template: size_t stricmp(const char *s1, const char *s2). 
....................    Compares s1 to s2 ignoring case (upper vs. lower) */ 
.................... signed int8 stricmp(char *s1, char *s2) 
....................  for(; *s1==*s2||(isalpha(*s1)&&isalpha(*s2)&&(*s1==*s2+32||*s2==*s1+32)); 
....................     s1++, s2++) 
.................... /* standard template: char *strlwr(char *s). 
....................    Replaces uppercase letters by lowercase; 
....................    returns pointer to new string s */ 
.................... char *strlwr(char *s) 
....................    for (p = s; *p != '\0'; p++) 
....................       if (*p >= 'A' && *p <='Z') 
....................          *p += 'a' - 'A'; 
.................... #ifndef getc 
.................... #define getc getch 
.................... #define getchar getch 
.................... #define puts(s) {printf(s); putchar(13); putchar(10);} 
.................... #define putc putchar 
.................... /* maps error number to an error message. Writes a sequence of characters to 
.................... stderr stream thus: if s is not null then string pointed to by s follwed by 
.................... a colon (:) and a space and the appropriate error message returned by strerror 
.................... function with argument errno 
.................... Returns: no value 
.................... void perror(char *s) 
....................   if(s) 
....................   fprintf(STDERR,"%s: ",s); 
....................   fprintf(STDERR,"%s\r\n",strerror(errno)); 
.................... #include <stdlib.h> 
.................... ////        (C) Copyright 1996,2007 Custom Computer Services           //// 
.................... #ifndef _STDLIB 
.................... #define _STDLIB 
.................... // Definitions and types 
.................... #ifndef RAND_MAX 
.................... #define RAND_MAX  32767    // The value of which is the maximum value 
....................                            // ... returned by the rand function 
.................... #IF (sizeof(int16*)>1) 
.................... #DEFINE LONG_POINTERS 1 
.................... #ELSE  
.................... #DEFINE LONG_POINTERS 0 
.................... typedef struct { 
....................    signed int quot; 
....................    signed int rem; 
.................... } div_t; 
....................    signed long quot; 
....................    signed long rem; 
.................... } ldiv_t; 
.................... // String conversion functions 
.................... /* Standard template: signed int  atoi(char * s) 
....................  * converts the initial portion of the string s to a signed int 
....................  * returns the converted value if any, 0 otherwise 
.................... signed int atoi(char *s); 
.................... /* Syntax: signed int32  atoi32(char * s) 
....................    converts the initial portion of the string s to a signed int32 
....................    returns the converted value if any, 0 otherwise*/ 
.................... #if (sizeof(long)==4) 
....................  #define atoi32(s) atol(s) 
....................  signed int32 atoi32(char *s); 
.................... // The following functions only work on the 24 bit compiler 
.................... // for the 30F, 33F, 24F and 24H parts 
.................... /* Syntax: signed int48  atoi48(char * s) 
....................    converts the initial portion of the string s to a signed int48 
.................... signed int48 atoi48(char *s); 
.................... /* Syntax: signed int64  atoi64(char * s) 
....................    converts the initial portion of the string s to a signed int64 
.................... signed int64 atoi64(char *s); 
.................... /* Syntax: char *  itoa(signed int32 num, int8 base, char * s) 
....................    converts the signed int32 to a string and 
.................... char * itoa(signed int32 num, unsigned int base, char * s); 
.................... /* Standard template: signed int16  atol(char * s) 
....................  * converts the initial portion of the string s to a signed int16 
.................... signed long atol(char *s); 
.................... /* Standard template: int16 strtoul(char * s,char *endptr,signed int base) 
....................  * converts the initial portion of the string s, represented as an 
....................  * integral value of radix base  to a signed long. 
....................  * Returns the converted value if any, 0 otherwise 
....................  * the final string is returned in the endptr, if endptr is not null 
.................... signed long strtol(char *s,char *endptr, signed int base); 
....................  * integral value of radix base to a unsigned long. 
.................... unsigned long strtoul(char *s,char *endptr, signed int base); 
.................... /* Standart template: float strtof(char * s,char *endptr) 
....................                       float48 strtof48(char *s,char *endptr); 
....................                       float64 strtod(char *s,char *endptr); 
....................  * converts the initial portion of the string s to a float32, float48 or float64, 
.................... float strtof(char *s,char *endptr); 
.................... //provided for compatibility 
.................... #define strtof48(s, e) strtof(s, e) 
.................... #define strtod(s, e) strtof(s, e) 
.................... /* Standard template: float32 atof(char * s) 
....................  * converts the initial portion of the string s to a float. 
.................... #define atof(s)   strtof(s, 0) 
.................... /* Standard template: float48 atof48(char * s) 
.................... #define atof48(s) strtof48(s, 0) 
.................... /* Standard template: float64 atof64(char * s) 
.................... #define atof64(s) strtod(s, 0) 
.................... /* Standard template: float32 atoe(char * s) 
....................  * also handles E format numbers 
.................... float atoe(char * s); 
.................... float32 atoe(char * s); 
.................... // Pseudo-random sequence generation functions 
.................... /* The rand function computes a sequence of pseudo-random integers in 
....................  * the range 0 to RAND_MAX 
....................  * Parameters: 
....................  *       (none) 
....................  * Returns: 
....................  *       The pseudo-random integer 
.................... unsigned int16 rand(void); 
.................... /* The srand function uses the argument as a seed for a new sequence of 
....................  * pseudo-random numbers to be returned by subsequent calls to rand. 
....................  *       [in] seed: The seed value to start from. You might need to pass 
....................  * Remarks 
....................  *          The srand function sets the starting point for generating 
....................  *       a series of pseudorandom integers. To reinitialize the 
....................  *       generator, use 1 as the seed argument. Any other value for 
....................  *       seed sets the generator to a random starting point. rand 
....................  *       retrieves the pseudorandom numbers that are generated. 
....................  *       Calling rand before any call to srand generates the same 
....................  *       sequence as calling srand with seed passed as 1. 
....................  *          Usually, you need to pass a time here from outer source 
....................  *       so that the numbers will be different every time you run. 
.................... void srand(unsigned int32 seed); 
.................... // Memory management functions 
.................... // Comming soon 
.................... // Communication with the environment 
.................... /* The function returns 0 always 
.................... signed int8 system(char *string); 
.................... // Searching and sorting utilities 
.................... /* Performs a binary search of a sorted array.. 
....................  *       [in] key: Object to search for 
....................  *       [in] base: Pointer to base of search data 
....................  *       [in] num: Number of elements 
....................  *       [in] width: Width of elements 
....................  *       [in] compare: Function that compares two elements 
....................  *       bsearch returns a pointer to an occurrence of key in the array pointed 
....................  *       to by base. If key is not found, the function returns NULL. If the 
....................  *       array is not in order or contains duplicate records with identical keys, 
....................  *       the result is unpredictable. 
.................... //void *bsearch(const void *key, const void *base, size_t num, size_t width, 
.................... //              int (*compare)(const void *, const void *)); 
.................... /* Performs the shell-metzner sort (not the quick sort algorithm). The contents 
....................  * of the array are sorted into ascending order according to a comparison 
....................  * function pointed to by compar. 
.................... //void *qsort(const void *base, size_t num, size_t width, 
.................... // Integer arithmetic functions 
.................... #define labs abs 
.................... div_t div(signed int numer, signed int denom); 
.................... ldiv_t ldiv(signed long numer, signed long denom); 
.................... // Multibyte character functions 
.................... // Not supported 
.................... // Multibyte string functions 
.................... // Internal implementation 
....................    div_t val; 
....................    val.quot = numer / denom; 
....................    val.rem = numer - (denom * val.quot); 
....................    return (val); 
....................    ldiv_t val; 
....................    float32 pow10 = 1.0; 
....................    float32 result = 0.0; 
....................    unsigned int8 sign = 0; 
....................    unsigned int8 expsign = 0; 
....................    char c; 
....................    unsigned int8 ptr = 0; 
....................    unsigned int8 i; 
....................    float32 exp = 1.0; 
....................    unsigned int8 expcnt = 0; 
....................    c = s[ptr++]; 
....................    if ((c>='0' && c<='9') || c=='+' || c=='-' || c=='.' || c=='E' || c=='e') { 
....................       if(c == '-') { 
....................          sign = 1; 
....................       if(c == '+') 
....................       while((c >= '0' && c <= '9')) { 
....................          result = 10*result + c - '0'; 
....................       if (c == '.') { 
....................              pow10 = pow10*10; 
....................              result += (c - '0')/pow10; 
....................       // Handling the exponent 
....................       if (c=='e' || c=='E') { 
....................             expsign = 1; 
....................             expcnt = 10*expcnt + c - '0'; 
....................          for(i=0;i<expcnt;i++) 
....................             exp*=10; 
....................          if(expsign==1) 
....................             result/=exp; 
....................             result*=exp; 
....................    if (sign == 1) 
....................       result = -1*result; 
....................    return(result); 
....................    float pow10 = 1.0; 
....................    float result = 0.0; 
....................    float exp = 1.0; 
....................    signed int result; 
....................    unsigned int sign, base, index; 
....................    index = 0; 
....................    sign = 0; 
....................    base = 10; 
....................    result = 0; 
....................    if (!s) 
....................    // Omit all preceeding alpha characters 
....................    c = s[index++]; 
....................    // increase index if either positive or negative sign is detected 
....................    if (c == '-') 
....................       sign = 1;         // Set the sign to negative 
....................    else if (c == '+') 
....................    if (c >= '0' && c <= '9') 
....................       // Check for hexa number 
....................       if (c == '0' && (s[index] == 'x' || s[index] == 'X')) 
....................          base = 16; 
....................          index++; 
....................       // The number is a decimal number 
....................       if (base == 10) 
....................          while (c >= '0' && c <= '9') 
....................             result = 10*result + (c - '0'); 
....................       else if (base == 16)    // The number is a hexa number 
....................          c = toupper(c); 
....................          while ( (c >= '0' && c <= '9') || (c >= 'A' && c<='F')) 
....................                result = (result << 4) + (c - '0'); 
....................                result = (result << 4) + (c - 'A' + 10); 
....................    if (sign == 1 && base == 10) 
....................        result = -result; 
....................    signed long result; 
....................          while ( (c >= '0' && c <= '9') || (c >= 'A' && c <='F')) 
....................             c = s[index++];c = toupper(c); 
....................    if (base == 10 && sign == 1) 
.................... /* A fast routine to multiply by 10 
.................... signed int32 mult_with10(int32 num) 
....................    return ( (num << 1) + (num << 3) ); 
.................... #if sizeof(long)==2 
....................    signed int32 result; 
....................    int8 sign, base, index; 
....................          while (c >= '0' && c <= '9') { 
....................             result = (result << 1) + (result << 3);  // result *= 10; 
....................             result += (c - '0'); 
....................          while ((c >= '0' && c <= '9') || (c >= 'A' && c <='F')) 
....................    signed int48 result; 
....................    signed int64 result; 
....................      unsigned int32 temp=1; 
....................      unsigned int8 i,sign=0,cnt=0; 
....................      if(num<0) { 
....................          sign=1;        // Check for negative number 
....................          num*=-1; 
....................      while(temp>0) { 
....................          temp=(num/base); 
....................          s[cnt]=(num%base)+'0';    // Conversion 
....................          if(s[cnt]>0x39) 
....................             s[cnt]+=0x7; 
....................          cnt++; 
....................          num=temp; 
....................      if(sign==1) { 
....................          s[cnt]=0x2D;      // Negative sign 
....................      for(i = 0;i<(int8)(cnt/2);i++) { 
....................          c=s[i]; 
....................          s[i]=s[cnt-i-1];        // Reverse the number 
....................          s[cnt-i-1]=c; 
....................      s[cnt]='\0';     // End the string 
.................... float strtof(char *s, char *endptr) 
....................    int1 skip = TRUE, sign = FALSE, point = FALSE; 
....................    for(c=s[ptr++]; c!=0; c=s[ptr++]) 
....................       if (skip && !isspace(c)) 
....................          skip = FALSE; 
....................          if (c == '+') 
....................             sign = FALSE; 
....................             continue; 
....................          else if (c == '-') 
....................             sign = TRUE; 
....................       if (!skip && (c == '.') && !point) 
....................          point = TRUE; 
....................       else if (!skip && isdigit(c)) 
....................          c -= '0'; 
....................          if (point) 
....................             pow10 = pow10 * 10.0; 
....................             result += (float)c / pow10;    
....................             result = 10.0 * result + (float)c; 
....................       else if (!skip) 
....................    if (sign) 
....................    if(endptr) 
....................       if (ptr) { 
....................          ptr--; 
....................        #IF LONG_POINTERS  
....................          *((long *)endptr)= s+ptr;  
....................          *((char *)endptr)=s+ptr; 
....................       *((long *)endptr)= s;  
....................       *((char *)endptr)=s; 
.................... float48 strtof48(char *s, char *endptr) 
....................    float48 pow10 = 1.0; 
....................    float48 result = 0.0; 
....................             result += (float48)c / pow10;    
....................             result = 10.0 * result + (float48)c; 
.................... float64 strtod(char *s, char *endptr) 
....................    float64 pow10 = 1.0; 
....................    float64 result = 0.0; 
....................             result += (float64)c / pow10;    
....................             result = 10.0 * result + (float64)c; 
.................... unsigned long strtoul(char *s, char *endptr, signed int base) 
....................    char *sc,*s1,*sd; 
....................    unsigned long x=0; 
....................    char sign; 
....................    char digits[]="0123456789abcdefghijklmnopqstuvwxyz"; 
....................    for(sc=s;isspace(*sc);++sc); 
....................    sign=*sc=='-'||*sc=='+'?*sc++:'+'; 
....................    if(sign=='-' || base <0 || base ==1|| base >36) // invalid base 
....................    goto StrtoulGO; 
....................    else if (base) 
....................       if(base==16 && *sc =='0'&&(sc[1]=='x' || sc[1]=='X')) 
....................          sc+=2; 
....................       if(base==8 && *sc =='0') 
....................          sc+=1; 
....................       if(base==2 && *sc =='0'&&sc[1]=='b') 
....................    else if(*sc!='0') // base is 0, find base 
....................       base=10; 
....................    else if (sc[1]=='x' || sc[1]=='X') 
....................       base =16,sc+=2; 
....................    else if(sc[1]=='b') 
....................       base=2,sc+=2; 
....................       base=8; 
....................    for (s1=sc;*sc=='0';++sc);// skip leading zeroes 
....................    sd=memchr(digits,tolower(*sc),base); 
....................    for(; sd!=0; ) 
....................       x=x*base+(int16)(sd-digits); 
....................       ++sc; 
....................    if(s1==sc) 
....................    StrtoulGO: 
....................       if (endptr) 
....................          *((long *)endptr)= sc;  
....................          *((char *)endptr)=sc;  
....................    return x; 
....................    signed long x=0; 
....................    if (base <0 || base ==1|| base >36) // invalid base 
....................    goto StrtolGO; 
....................    for(;sd!=0;) 
....................    StrtolGO: 
....................    if(sign=='-') 
....................       x  =-x; 
.................... int8 mblen(char *s,size_t n) 
....................    return strlen(s); 
.................... int8 mbtowc(wchar_t *pwc,char *s,size_t n) 
....................    *pwc=*s; 
....................    return 1; 
.................... int8 wctomb(char *s,wchar_t wchar) 
....................    *s=wchar; 
.................... size_t mbstowcs(wchar_t *pwcs,char *s,size_t n) 
....................    strncpy(pwcs,s,n); 
....................    return strlen(pwcs); 
.................... size_t wcstombs(char *s,wchar_t *pwcs,size_t n) 
....................    strncpy(s,pwcs,n); 
.................... // The random number implementation 
.................... unsigned int32 _Randseed; 
....................    _Randseed = _Randseed * 1103515245 + 12345; 
....................    return ((unsigned int16)(_Randseed >> 16) % RAND_MAX); 
....................    _Randseed = seed; 
.................... // Searching and sorting utilities implementation 
.................... typedef signed int8 (*_Cmpfun)(char * p1,char * p2);  
.................... typedef signed int16 (*_Cmpfun)(char * p1,char * p2);  
.................... void qsort(char * qdata, unsigned int qitems, unsigned int qsize, _Cmpfun cmp) { 
....................    unsigned int m,j,i,l; 
....................    int1 done; 
....................    BYTE t[16]; 
....................    m = qitems/2; 
....................    while( m > 0 ) { 
....................      for(j=0; j<(qitems-m); ++j) { 
....................         i = j; 
....................            done=TRUE; 
....................            l = i+m; 
....................            if( (*cmp)(qdata+i*qsize, qdata+l*qsize) > 0 ) { 
....................               memcpy(t, qdata+i*qsize, qsize); 
....................               memcpy(qdata+i*qsize, qdata+l*qsize, qsize); 
....................               memcpy(qdata+l*qsize, t, qsize); 
....................               if(m <= i) 
....................                 i -= m; 
....................                 done = FALSE; 
....................         } while(!done); 
....................      m = m/2; 
.................... char *bsearch(char *key, char *base, size_t num, size_t width,_Cmpfun cmp) 
....................    char *p, *q; 
....................    size_t n; 
....................    size_t pivot; 
....................    signed int val; 
....................    p = base; 
....................    n = num; 
....................    while (n > 0) 
....................       pivot = n >> 1; 
....................       q = p + width * pivot; 
....................       val = (*cmp)(key, q); 
....................       if (val < 0) 
....................          n = pivot; 
....................       else if (val == 0) 
....................          return ((char *)q); 
....................       else { 
....................          p = q + width; 
....................          n -= pivot + 1; 
....................    return NULL;      // There's no match 
.................... #endif 
.................... #ZERO_RAM 
.................... #use standard_io(ALL) 
.................... #int_AD 
.................... #define  LED1      PIN_A5        //ez nalam nem mukodik 
.................... #define  LED2      PIN_A4 
.................... #define  LED3      PIN_C5 
.................... #define  LED4      PIN_C4      
.................... #define  BUTTON1   PIN_C6 
.................... #define  BUTTON2   PIN_C1 
.................... #define  BUTTON3   PIN_B4 
.................... #define  SPEAKER   PIN_C2 
.................... #define  SPI1      PIN_B5 
.................... #define  SPI2      PIN_B7 
.................... #define  SPI_OUT   PIN_C7 
.................... #define  SPI_CLK   PIN_B6 
.................... int8     run; 
.................... //void  AD_isr(void)  
.................... void sound(int8 pitty, int16 sound)     //pitty: a hossza, sound: a hangmagassága 
.................... //div_t delay; 
.................... int8 c; 
.................... //delay=div(1000000,sound); 
.................... for (c=pitty;c>0;--c) 
0022:  MOVFF  0D,10
0026:  MOVF   10,F
0028:  BZ    006A
....................     output_high(SPEAKER); 
002A:  BCF    F94.2
002C:  BSF    F8B.2
....................     delay_us(sound); 
002E:  MOVFF  0F,11
0032:  INCF   11,F
0034:  DECF   11,F
0036:  BTFSC  FD8.2
0038:  BRA    0042
003A:  MOVLW  FF
003C:  MOVWF  12
003E:  RCALL  0004
0040:  BRA    0034
0042:  MOVFF  0E,12
0046:  RCALL  0004
....................     output_low(SPEAKER); 
0048:  BCF    F94.2
004A:  BCF    F8B.2
004C:  MOVFF  0F,11
0050:  INCF   11,F
0052:  DECF   11,F
0054:  BTFSC  FD8.2
0056:  BRA    0060
0058:  MOVLW  FF
005A:  MOVWF  12
005C:  RCALL  0004
005E:  BRA    0052
0060:  MOVFF  0E,12
0064:  RCALL  0004
0066:  DECF   10,F
0068:  BRA    0026
006A:  RETLW  00
.................... void spi(spi_data) 
....................    int8 a=0; 
0092:  CLRF   0E
....................    int1 bit; 
....................    int8 data; 
....................    data=0xDB;        //command byte 
0094:  MOVLW  DB
0096:  MOVWF  10
....................    output_low(SPI_CLK); 
0098:  BCF    F93.6
009A:  BCF    F8A.6
....................    output_low(SPI1); //SPI1 indit 
009C:  BCF    F93.5
009E:  BCF    F8A.5
....................    while (a<2)                         //ketszer fut le 
00A0:  MOVF   0E,W
00A2:  SUBLW  01
00A4:  BTFSS  FD8.0
00A6:  BRA    0192
....................       bit=bit_test(data,7); 
00A8:  BCF    0F.0
00AA:  BTFSC  10.7
00AC:  BSF    0F.0
....................       if (bit) output_high(SPI_OUT);  
00AE:  BTFSS  0F.0
00B0:  BRA    00B8
00B2:  BCF    F94.7
00B4:  BSF    F8B.7
....................          else output_low(SPI_OUT); 
00B6:  BRA    00BC
00B8:  BCF    F94.7
00BA:  BCF    F8B.7
....................       output_high(SPI_CLK); 
00BC:  BCF    F93.6
00BE:  BSF    F8A.6
....................       bit=bit_test(data,6); 
00C0:  BCF    0F.0
00C2:  BTFSC  10.6
00C4:  BSF    0F.0
00C6:  BCF    F93.6
00C8:  BCF    F8A.6
00CA:  BTFSS  0F.0
00CC:  BRA    00D4
00CE:  BCF    F94.7
00D0:  BSF    F8B.7
00D2:  BRA    00D8
00D4:  BCF    F94.7
00D6:  BCF    F8B.7
00D8:  BCF    F93.6
00DA:  BSF    F8A.6
....................       bit=bit_test(data,5); 
00DC:  BCF    0F.0
00DE:  BTFSC  10.5
00E0:  BSF    0F.0
00E2:  BCF    F93.6
00E4:  BCF    F8A.6
00E6:  BTFSS  0F.0
00E8:  BRA    00F0
00EA:  BCF    F94.7
00EC:  BSF    F8B.7
00EE:  BRA    00F4
00F0:  BCF    F94.7
00F2:  BCF    F8B.7
00F4:  BCF    F93.6
00F6:  BSF    F8A.6
....................       bit=bit_test(data,4); 
00F8:  BCF    0F.0
00FA:  BTFSC  10.4
00FC:  BSF    0F.0
00FE:  BCF    F93.6
0100:  BCF    F8A.6
0102:  BTFSS  0F.0
0104:  BRA    010C
0106:  BCF    F94.7
0108:  BSF    F8B.7
010A:  BRA    0110
010C:  BCF    F94.7
010E:  BCF    F8B.7
0110:  BCF    F93.6
0112:  BSF    F8A.6
....................       bit=bit_test(data,3); 
0114:  BCF    0F.0
0116:  BTFSC  10.3
0118:  BSF    0F.0
011A:  BCF    F93.6
011C:  BCF    F8A.6
011E:  BTFSS  0F.0
0120:  BRA    0128
0122:  BCF    F94.7
0124:  BSF    F8B.7
0126:  BRA    012C
0128:  BCF    F94.7
012A:  BCF    F8B.7
012C:  BCF    F93.6
012E:  BSF    F8A.6
....................       bit=bit_test(data,2); 
0130:  BCF    0F.0
0132:  BTFSC  10.2
0134:  BSF    0F.0
0136:  BCF    F93.6
0138:  BCF    F8A.6
013A:  BTFSS  0F.0
013C:  BRA    0144
013E:  BCF    F94.7
0140:  BSF    F8B.7
0142:  BRA    0148
0144:  BCF    F94.7
0146:  BCF    F8B.7
0148:  BCF    F93.6
014A:  BSF    F8A.6
....................       bit=bit_test(data,1); 
014C:  BCF    0F.0
014E:  BTFSC  10.1
0150:  BSF    0F.0
0152:  BCF    F93.6
0154:  BCF    F8A.6
0156:  BTFSS  0F.0
0158:  BRA    0160
015A:  BCF    F94.7
015C:  BSF    F8B.7
015E:  BRA    0164
0160:  BCF    F94.7
0162:  BCF    F8B.7
0164:  BCF    F93.6
0166:  BSF    F8A.6
....................       bit=bit_test(data,0); 
0168:  BCF    0F.0
016A:  BTFSC  10.0
016C:  BSF    0F.0
016E:  BCF    F93.6
0170:  BCF    F8A.6
0172:  BTFSS  0F.0
0174:  BRA    017C
0176:  BCF    F94.7
0178:  BSF    F8B.7
017A:  BRA    0180
017C:  BCF    F94.7
017E:  BCF    F8B.7
0180:  BCF    F93.6
0182:  BSF    F8A.6
....................       a=a+1; 
0184:  MOVLW  01
0186:  ADDWF  0E,F
0188:  BCF    F93.6
018A:  BCF    F8A.6
....................       data=spi_data; 
018C:  MOVFF  0D,10
0190:  BRA    00A0
....................    output_high(SPI1);               //SPI1 leallit 
0192:  BCF    F93.5
0194:  BSF    F8A.5
....................    output_low(SPI_OUT); 
0196:  BCF    F94.7
0198:  BCF    F8B.7
019A:  GOTO   028E (RETURN)
.................... void main() 
019E:  CLRF   FF8
01A0:  BCF    FD0.7
01A2:  MOVLW  FE
01A4:  MOVWF  00
01A6:  MOVLW  03
01A8:  MOVWF  01
01AA:  MOVLW  02
01AC:  MOVWF  FE9
01AE:  MOVLW  00
01B0:  MOVWF  FEA
01B2:  CLRF   FEE
01B4:  CLRWDT
01B6:  DECFSZ 00,F
01B8:  BRA    01B2
01BA:  DECFSZ 01,F
01BC:  BRA    01B2
01BE:  CLRF   FEA
01C0:  CLRF   FE9
01C2:  MOVF   FC1,W
01C4:  ANDLW  E0
01C6:  MOVWF  FC1
01C8:  CLRF   FB4
01CA:  CLRF   05
01CC:  CLRF   06
.................... static  int1     button; 
....................    //SET_TRIS_A(0x0F);                // CF: xxoo ixii  (A5 out,A4 out,A3 in,A1 in,A0 in) 
....................    //SET_TRIS_B(0x1F);                // 1F: oooi iiii 
....................    //SET_TRIS_C(0x4B);                // CB: oioo ioii 
....................    setup_adc_ports(NO_ANALOGS);            //AN3|VSS_VDD); 
01CE:  MOVF   FC1,W
01D0:  ANDLW  E0
01D2:  IORLW  0F
01D4:  MOVWF  FC1
....................    //setup_adc(ADC_OFF|ADC_TAD_MUL_12); 
....................    setup_spi(FALSE);     //SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4); 
01D6:  CLRF   FC6
....................    setup_wdt(WDT_OFF); 
01D8:  BCF    FD1.0
....................   // setup_timer_0(RTCC_INTERNAL); 
....................    setup_timer_0(RTCC_OFF); 
01DA:  CLRF   FD5
....................    setup_timer_1(T1_DISABLED); 
01DC:  CLRF   FCD
....................    setup_timer_2(T2_DISABLED,0,1); 
01DE:  MOVLW  00
01E0:  MOVWF  FCA
01E2:  MOVLW  00
01E4:  MOVWF  FCB
....................    setup_timer_3(T3_DISABLED);      //|T3_DIV_BY_1); 
01E6:  CLRF   FB1
....................    //setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard 
....................    disable_interrupts(INT_AD); 
01E8:  BCF    F9D.6
....................    disable_interrupts(GLOBAL); 
01EA:  BCF    FF2.6
01EC:  BCF    FF2.7
01EE:  BTFSC  FF2.7
01F0:  BRA    01EC
....................    setup_oscillator(OSC_8MHZ|OSC_INTRC); 
01F2:  MOVLW  72
01F4:  MOVWF  FD3
01F6:  MOVF   FD3,W
01F8:  BCF    F93.5
01FA:  BSF    F8A.5
....................    output_high(SPI2);               //SPI alaphelyzetbe 
01FC:  BCF    F93.7
01FE:  BSF    F8A.7
0200:  BCF    F94.7
0202:  BCF    F8B.7
0204:  BCF    F93.6
0206:  BCF    F8A.6
....................    // TODO: USER CODE!! 
....................    input(BUTTON1); 
0208:  BSF    F94.6
....................    input(BUTTON2); 
020A:  BSF    F94.1
....................    input(BUTTON3); 
020C:  BSF    F93.4
....................    output_high(LED1);                //LEDek bekapcsolva 
020E:  BCF    F92.5
0210:  BSF    F89.5
....................    output_high(LED2); 
0212:  BCF    F92.4
0214:  BSF    F89.4
....................    output_high(LED3); 
0216:  BCF    F94.5
0218:  BSF    F8B.5
....................    output_high(LED4);  
021A:  BCF    F94.4
021C:  BSF    F8B.4
....................    sound(20,800); 
021E:  MOVLW  14
0220:  MOVWF  0D
0222:  MOVLW  03
0224:  MOVWF  0F
0226:  MOVLW  20
0228:  MOVWF  0E
022A:  RCALL  0022
....................    delay_ms(200);  
022C:  MOVLW  C8
022E:  MOVWF  0E
0230:  RCALL  006C
0232:  MOVLW  14
0234:  MOVWF  0D
0236:  MOVLW  03
0238:  MOVWF  0F
023A:  MOVLW  20
023C:  MOVWF  0E
023E:  RCALL  0022
0240:  MOVLW  C8
0242:  MOVWF  0E
0244:  RCALL  006C
....................    sound(10,1800); 
0246:  MOVLW  0A
0248:  MOVWF  0D
024A:  MOVLW  07
024C:  MOVWF  0F
024E:  MOVLW  08
0250:  MOVWF  0E
0252:  RCALL  0022
0254:  MOVLW  C8
0256:  MOVWF  0E
0258:  RCALL  006C
025A:  MOVLW  0A
025C:  MOVWF  0D
025E:  MOVLW  07
0260:  MOVWF  0F
0262:  MOVLW  08
0264:  MOVWF  0E
0266:  RCALL  0022
....................    delay_ms(1200); 
0268:  MOVLW  05
026A:  MOVWF  0D
026C:  MOVLW  F0
026E:  MOVWF  0E
0270:  RCALL  006C
0272:  DECFSZ 0D,F
0274:  BRA    026C
....................    output_low(LED1);                //LEDek kikapcsolva 
0276:  BCF    F92.5
0278:  BCF    F89.5
....................    output_low(LED2); 
027A:  BCF    F92.4
027C:  BCF    F89.4
....................    output_low(LED3); 
027E:  BCF    F94.5
0280:  BCF    F8B.5
....................    output_low(LED4);  
0282:  BCF    F94.4
0284:  BCF    F8B.4
....................    run=0; 
0286:  CLRF   0B
....................    while(TRUE) 
....................     spi(run); 
0288:  MOVFF  0B,0D
028C:  BRA    0092
028E:  BCF    F94.4
0290:  BCF    F8B.4
....................    button=input(BUTTON2); 
0292:  BSF    F94.1
0294:  BCF    0C.0
0296:  BTFSC  F82.1
0298:  BSF    0C.0
....................    if (button==0) output_low(LED2); 
029A:  BTFSC  0C.0
029C:  BRA    02A2
029E:  BCF    F92.4
02A0:  BCF    F89.4
....................    if (button==1) output_high(LED2); 
02A2:  BTFSS  0C.0
02A4:  BRA    02AA
02A6:  BCF    F92.4
02A8:  BSF    F89.4
....................     button=input(BUTTON1); 
02AA:  BSF    F94.6
02AC:  BCF    0C.0
02AE:  BTFSC  F82.6
02B0:  BSF    0C.0
....................     if (button==1) output_low(LED3); 
02B2:  BTFSS  0C.0
02B4:  BRA    02BA
02B6:  BCF    F94.5
02B8:  BCF    F8B.5
....................     if (button==0) output_high(LED3); 
02BA:  BTFSC  0C.0
02BC:  BRA    02C2
02BE:  BCF    F94.5
02C0:  BSF    F8B.5
....................     run++; 
02C2:  INCF   0B,F
....................     delay_ms(100); 
02C4:  MOVLW  64
02C6:  MOVWF  0E
02C8:  RCALL  006C
02CA:  BCF    F94.4
02CC:  BSF    F8B.4
02CE:  MOVLW  64
02D0:  MOVWF  0E
02D2:  RCALL  006C
02D4:  BRA    0288
02D6:  SLEEP 
Configuration Fuses:
   Word  1: CB38   FCMEN IESO USBDIV2 PCLKEN PLLEN CPUDIV4 ECMED
   Word  2: 0E10   NOBROWNOUT WDT128 NOWDT BORV22 PUT
   Word  3: 8000   MCLR NOHFOFST
   Word  4: 0089   STVREN NODEBUG NOXINST NOLVP BBSIZ2K
   Word  5: C003   NOCPD NOPROTECT NOCPB
   Word  6: E003   NOWRT NOWRTD NOWRTC NOWRTB WRT0 WRT1
   Word  7: 4003   NOEBTR NOEBTRB
