#include <16F84A.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOBROWNOUT               //No brownout reset
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#use delay(clock=20000000)  //20MHz-es kvarc
void main() //főprogram itt indul
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   // TODO: USER CODE!!
do{  //végtelen ciklus:do-while. Az ebben levőt ismétli folyamatosan
delay_ms(500); //500ms (fél másodperc)-et vár
output_toggle(PIN_B1); // PIN_B1 az a port ahova a LED-et kötöd  ,kimenetet átvált. 
					   // Ha H volt L lesz, ha L volt H lesz.=>villog a led.
   }while(!0);
