LIST P=16F1936, R=DEC
#include "P16F1936.inc"
OSCFREQ = 16		; 4,8,16 MHz
 __CONFIG _CONFIG1, 0x09A4
 __CONFIG _CONFIG2, 0x1433
cblock 0x20
 Loop1,Loop2
endc
; full bridge PWM: P1D+P1A or P1B+P1C (16F1936 P1A=RC2, P1B=RB2, P1C=RB1, P1D=RB4)
trisamask			EQU b'11111111'
trisbmask			EQU b'11000000'
triscmask			EQU b'11000000'
functionport		EQU PORTC		; func 3-5-1-2-4
func1				EQU .5
func2				EQU .4
func3				EQU .0
func4				EQU .1
func5				EQU .3
P1ATRISPORT			EQU TRISC
P1A					EQU .2
P1BTRISPORT			EQU TRISB
P1B					EQU .2
P1C					EQU .1
P1D					EQU .4
 #include "settings_pwm.inc"
goto main
delay_250			; 250 millisec
	movlw 250
	movwf Loop1
Outer1	movlw 250
	movwf Loop2
Inner1	nop
	nop
		decfsz Loop2,F
	goto Inner1		; Inner loop = 5 usec
	decfsz Loop1,F
	goto Outer1
return
pwm_init
	banksel P1ATRISPORT
		bsf P1ATRISPORT,P1A
		bsf P1BTRISPORT,P1B
		bsf P1BTRISPORT,P1C
		bsf P1BTRISPORT,P1D
banksel PR2
	movlw 0x3F		; Fosc=16 MHz, TMR2PRESC=16, PR2=0x3F, f=3,9 kHz
	movwf PR2
banksel INTCON
	clrf INTCON		; disable all ints
banksel PIE1
	clrf PIE1		; disable all ints
banksel T2CON
	movlw b'01111100'	; 1:16 prescaler, T2ON=1.
	movwf T2CON
banksel CCPR1L
	clrf CCPR1L
banksel CCP1CON
; fbrdg activeH forward 01001100
; fbrdg activeH reverse 11001100
	movlw b'11001100'	; full bridge PWM output, active H
	movwf CCP1CON
	banksel P1ATRISPORT
		bcf P1ATRISPORT,P1A
		bcf P1BTRISPORT,P1B
		bcf P1BTRISPORT,P1C
		bcf P1BTRISPORT,P1D
banksel PORTA
return
pwm_base_duty			; 25%=0x1F, 50%=0x3E, 75%=0x5D
	;movf ADRES,0
	movlw 0x5D
	movwf CCPR1L
return
forward
banksel T2CON
		bcf T2CON,2	; TMR2 off
		nop		; waits for a while
		nop
		nop
		nop
		bcf CCP1CON,7	;  full duplex, forward
		bsf T2CON,2	; TMR2 on
banksel PORTA
return
reverse
banksel T2CON
		nop
		nop
		nop
		bsf CCP1CON,7	;  full duplex, reverse
banksel PORTA
return
main
call pwm_init	
call pwm_base_duty
ide
	call forward
call delay_250
call delay_250
call delay_250
call delay_250
call delay_250
	call reverse
call delay_250
call delay_250
call delay_250
call delay_250
call delay_250
nop
nop
nop
nop
nop
goto ide
;goto main
end
;CCPXCON: CCPX CONTROL REGISTER
;bit 7-6 PxM<1:0>: Enhanced PWM Output Configuration bits(1)
;If CCPxM<3:2> = 11:
;00 = Single output; PxA modulated; PxB, PxC, PxD assigned as port pins
;01 = Full-Bridge output forward; P1D modulated; P1A active; P1B, P1C inactive
;10 = Half-Bridge output; P1A, P1B modulated with dead-band control; P1C, P1D assigned as port pins
;11 = Full-Bridge output reverse; P1B modulated; P1C active; P1A, P1D inactive
;bit 5-4 DCxB<1:0>: PWM Duty Cycle Least Significant bits
;These bits are the two LSbs of the PWM duty cycle. The eight MSbs are found in CCPRxL.
;bit 3-0 CCPxM<3:0>: ECCPx Mode Select bits
;1100 = PWM mode: PxA, PxC active-high; PxB, PxD active-high
;1101 = PWM mode: PxA, PxC active-high; PxB, PxD active-low
;1110 = PWM mode: PxA, PxC active-low; PxB, PxD active-high
;1111 = PWM mode: PxA, PxC active-low; PxB, PxD active-low
