//////// Standard Header file for the PIC16F57 device ////////////////
#device PIC16F57
#nolist
//////// Program memory: 2048x12  Data RAM: 72  Stack: 2
//////// I/O: 20   Analog Pins: 0
//////// C Scratch area: 08   ID Location: 0800
//////// Fuses: LP,XT,HS,RC,NOWDT,WDT,PROTECT,NOPROTECT
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
//                         PORT_x_PULLUPS(), INPUT(),
//                         OUTPUT_LOW(), OUTPUT_HIGH(),
//                         OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_B0  48
#define PIN_B1  49
#define PIN_B2  50
#define PIN_B3  51
#define PIN_B4  52
#define PIN_B5  53
#define PIN_B6  54
#define PIN_B7  55
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
#define PIN_C6  62
#define PIN_C7  63
////////////////////////////////////////////////////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int8
#define BOOLEAN int1
#define getc getch
#define fgetc getch
#define getchar getch
#define putc putchar
#define fputc putchar
#define fgets gets
#define fputs puts
////////////////////////////////////////////////////////////////// Control
// Control Functions:  RESET_CPU(), SLEEP(), RESTART_CAUSE()
// Constants returned from RESTART_CAUSE() are:
#define WDT_FROM_SLEEP  3     
#define WDT_TIMEOUT     11    
#define MCLR_FROM_SLEEP 19    
#define MCLR_FROM_RUN   27    
#define NORMAL_POWER_UP 25    
#define BROWNOUT_RESTART 26   
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
//                              SET_TIMER0() or SET_RTCC(),
//                              GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER_0() are:
#define RTCC_INTERNAL   0
#define RTCC_EXT_L_TO_H 32
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1      8
#define RTCC_DIV_2      0
#define RTCC_DIV_4      1
#define RTCC_DIV_8      2
#define RTCC_DIV_16     3
#define RTCC_DIV_32     4
#define RTCC_DIV_64     5
#define RTCC_DIV_128    6
#define RTCC_DIV_256    7
#define RTCC_8_BIT      0     
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
//                            RESTART_WDT()
// WDT base is 18ms
#define WDT_18MS        8   
#define WDT_36MS        9   
#define WDT_72MS       10   
#define WDT_144MS      11   
#define WDT_288MS      12   
#define WDT_576MS      13   
#define WDT_1152MS     14   
#define WDT_2304MS     15   
#define DISABLE_PULLUPS            0x40  // for 508 and 509 only
#define DISABLE_WAKEUP_ON_CHANGE   0x80  // for 508 and 509 only
#ifndef PIN_CHANGE_FROM_SLEEP
#define PIN_CHANGE_FROM_SLEEP      0x90  // for 508 and 509 only
#endif
#list
