#DEFINE AKTUALIS_DATUM 	"20090923"
#DEFINE AKTUALIS_VALTOZAT "0.00"
    #include <p18f14k22.inc>
    __CONFIG _CONFIG1H, _FOSC_IRC_1H & _FCMEN_OFF_1H & _PLLEN_ON_1H & _PCLKEN_OFF_1H & _IESO_OFF_1H 
    __CONFIG _CONFIG2L, _PWRTEN_ON_2L & _BORV_19_2L & _BOREN_SBORDIS_2L 
    __CONFIG _CONFIG2H, _WDTEN_OFF_2H & _WDTPS_1_2H 
    __CONFIG _CONFIG3H, _MCLRE_OFF_3H & _HFOFST_OFF_3H
    __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L & _BBSIZ_ON_4L & _STVREN_ON_4L
    __CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L
    __CONFIG _CONFIG5H, _CPB_ON_5H & _CPD_OFF_5H
    __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    __CONFIG _CONFIG7H, _EBTRB_OFF_7H
;OSCILLATOR FREQUENCY
#define OSCILLATOR	D'64000000'
#define ADCONV_DONE	0
INT_VAR 	UDATA 0x00000000
w_saved      		RES 1   ; variable used for context saving (for low-priority interrupts only)
status_saved 		RES 1   ; variable used for context saving (for low-priority interrupts only)
bsr_saved    		RES 1   ; variable used for context saving (for low-priority interrupts only)
result_h		RES 1
result_l		RES 1
summ_h			RES 1
summ_l			RES 1
avg_h			RES 1
avg_l			RES 1
calc_01			RES 1
calc_02			RES 1
flags			RES 1
STARTUP CODE 0x0000
	nop                       ; needed for ICD2 debugging
	bra    START               ; menj a start kódra
;INTERRUPT SERVICE ROUTINE
; high priority interrupt vector
HIGH_INT_VECTOR CODE 0x0008
	retfie	FAST
PROG	CODE ; 0x00030
;INITIALIZATION OF THE PORTS AND TIMERS	
PWM_MODULE_ON
	movlw 	0xFF			; 	PWM kimenet idoalapja ( kb 8 kHz )
	movwf 	PR2
	movlw 	0x004			;  Timer 2 bekapcsolasa
	movwf 	T2CON
	movlw 	b'00111100'			; 	PWM uzemmod inditasa
	movwf 	CCP1CON
	movlw 	0x7F
	movwf 	CCPR1L
	movlw	b'00000011'
	movwf	PSTRCON
	return
FAST_RC
	bsf	OSCCON,6	;INTERNAL OSCILLATOR SELECTION
	bsf	OSCCON,5
	bsf	OSCCON,4
	return
AD_CONV_COMPLETE				;ADC INTERRUPT
	bcf	PIR1,ADIF			;ADIF FLAG IS CLEARED FOR NEXT INTERRUPT
	movlw	b'00100101'			;Channel9 is selected for next conversion
	movwf	ADCON0
	movf	ADRESH,W			;READ AD CONVERSION RESULT
	movwf	result_h
	movf	ADRESL,W
	movwf	result_l
	bsf	ADCON0, GO				;then start a new conversion
	bcf	STATUS,C
	rlcf	result_l,f
	rlcf	result_h,f
	rlcf	result_l,f
	rlcf	result_h,f
	rlcf	result_l,f
	rlcf	result_h,f
	rlcf	result_l,f
	rlcf	result_h,f
	rlcf	result_l,f
	rlcf	result_h,f
	bsf	flags,ADCONV_DONE
	return
PWM_DUTY_UPDATE
	movf	CCP1CON,w
	andlw	b'11001111'
	movwf	calc_02
	rrncf	avg_l,w
	movwf	calc_01
	rrncf	calc_01,w
	andlw	b'00110000'
	iorwf	calc_02,w
	movwf	CCP1CON
	movf	avg_h,w
	movwf	CCPR1L
	return
UPDATE_DATA
	movf	avg_l,w
	subwf	summ_l,f
	btfss	STATUS,C
	decf	summ_h,f
	movf	avg_h,w
	subwf	summ_h,f
	movf	result_l,w
	addwf	summ_l,f
	btfsc	STATUS,C
	incf	summ_h,f
	movf	result_h,w
	addwf	summ_h,f
	bcf	STATUS,C
	rrcf	summ_h,w
	movwf	avg_h
	rrcf	summ_l,w
	movwf	avg_l	
	return
SIGNAL_UPDATE
	bcf	flags,ADCONV_DONE
	call	UPDATE_DATA
	call	PWM_DUTY_UPDATE
	bcf	LATC,3
	movf	summ_h,W
	sublw	.240
	btfss	STATUS,C
	bsf	LATC,3
	bcf	LATC,2
	movlw	.15
	subwf	summ_h,W
	btfss	STATUS,C
	bsf	LATC,2
	btg	LATC,0
	return
START
	call	FAST_RC
	clrf 	LATC
	clrf 	ANSEL
	clrf	ANSELH
	clrf	WPUA
	clrf	IOCA
	bsf	ANSEL,0		;AN0 CONFIGURED AS ANALOG INPUT
	bsf	ANSEL,1		;AN1 CONFIGURED AS ANALOG INPUT
	bsf 	ANSEL,2		;AN2 CONFIGURED AS ANALOG INPUT
	bsf 	ANSELH,0	;AN8 CONFIGURED AS ANALOG INPUT
	bsf	ANSELH,1	;AN9 CONFIGURED AS ANALOG INPUT	
	movlw	b'11000000'
	movwf	TRISC		;RC0-RC5 CONFIGURED AS OUTPUT, RC6-RC7 AS INPUT
	movlw	b'10000000'
	movwf	TRISB		;RB4-RB6 CONFIGURED AS OUTPUT, RB7 AS INPUT
	clrf	TRISA		
	comf	TRISA,F		;RA0-RA7 CONFIGURED AS INPUT
;INITIALIZE ADC REGISTERS
	movlw	0X25		;ADC ON
	movwf	ADCON0		;CHANNEL9 FOR CONVERSION - AN0
	movlw	b'00000000'	;POSITIVE Source is Vdd
	movwf	ADCON1		;NEGATIVE Source is Vss
	movlw	b'10000111'	;CONFIGURE ADCLOCK for ( Frc ) clock
	movwf	ADCON2
	bsf	ADCON0, GO
	call	PWM_MODULE_ON
	clrf	summ_h
	clrf	summ_l	
	clrf	avg_h
	clrf	avg_l
;MAIN LOOP, THE PROGRAM WILL BE LOOPING
MAIN_LOOP
	btfsc	PIR1,ADIF				;ADC CONVERSION COMPLETE?
	call	AD_CONV_COMPLETE			;YES - CONVERSON RESULT 'F - MOTOR FREQUENCY'
	btfsc	flags,ADCONV_DONE
	call	SIGNAL_UPDATE
	bra 	MAIN_LOOP
DATA_EEPROM	CODE	0xf00000
	de	AKTUALIS_DATUM
	de	AKTUALIS_VALTOZAT
	END
