; Source created with Parsic Version 3.x
; at              : 2009.10.18. 11:25:15
; Project File    : C:\DOCUME~1\ALLUSE~1\ASZTAL\voltamp.PIC
; Project Version : 1.0.2
; Created         : 2009.09.13. 20:14:00
; Last change     : 2009.10.18. 11:25:10
	PROCESSOR 16F877A
	INCLUDE P16F877A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ADC0	= 32	; located in Bank 0
ADC0_HI	= 33	; located in Bank 0
S0	= 34	; located in Bank 0
S0_HI	= 35	; located in Bank 0
S1	= 36	; located in Bank 0
S1_HI	= 37	; located in Bank 0
S2	= 38	; located in Bank 0
S2_HI	= 39	; located in Bank 0
S3	= 40	; located in Bank 0
S3_HI	= 41	; located in Bank 0
S4	= 42	; located in Bank 0
S4_HI	= 43	; located in Bank 0
LT1_FD	= 44	; located in Bank 0
LT2_FD	= 45	; located in Bank 0
TR1	= 46	; located in Bank 0
TR1_HI	= 47	; located in Bank 0
S10	= 48	; located in Bank 0
LT3_FD	= 49	; located in Bank 0
S9	= 50	; located in Bank 0
S9_HI	= 51	; located in Bank 0
S8	= 52	; located in Bank 0
S8_HI	= 53	; located in Bank 0
S7	= 54	; located in Bank 0
S7_HI	= 55	; located in Bank 0
S6	= 56	; located in Bank 0
S6_HI	= 57	; located in Bank 0
S5	= 58	; located in Bank 0
S5_HI	= 59	; located in Bank 0
LT4_FD	= 60	; located in Bank 0
LT5_FD	= 61	; located in Bank 0
LT6_FD	= 62	; located in Bank 0
ADC1	= 63	; located in Bank 0
ADC1_HI	= 64	; located in Bank 0
LT7_FD	= 65	; located in Bank 0
LT8_FD	= 66	; located in Bank 0
RAM	= 67	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP7	= 120	; located in Bank 0, 1, 2, 3
SYS_TMP9	= 121	; located in Bank 0, 1, 2, 3
SYS_TMP10	= 122	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 123	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 124	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 125	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 126	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Multiplikation 16 - Bit
; OP1 = SYS_TMP1,2
; OP2 = SYS_TMP3,4
SYSMUL16
	MOVLW 16	; set loopcounter
	MOVWF SYS_TMP7
	CLRF SYS_TMP5	; clear result
	CLRF SYS_TMP6
SYSMUL16_1
	RRF SYS_TMP4,F
	RRF SYS_TMP3,F
	BTFSS STATUS,CARRY
	GOTO SYSMUL16_2
	MOVFW SYS_TMP2	; add High-Byte
	ADDWF SYS_TMP6,F
	MOVFW SYS_TMP1	; add Low-Byte
	ADDWF SYS_TMP5,F
	BTFSC STATUS,CARRY	; carry ?
	INCF SYS_TMP6,F	; add 256 to result
SYSMUL16_2
	BCF STATUS,CARRY
	RLF SYS_TMP1,F
	RLF SYS_TMP2,F
	DECFSZ SYS_TMP7,F
	GOTO SYSMUL16_1
	RETURN
; Division 16 - Bit
; OP1 = SYS_TMP1,2
; OP2 = SYS_TMP3,4
SYSDIV16
	MOVFW SYS_TMP3	; Division durch 0 ?
	IORWF SYS_TMP4,W
	BTFSC STATUS,ZERO
	GOTO SYSDIV16_ERROR
	CLRF SYS_TMP5	; Ergebnis löschen
	CLRF SYS_TMP6
	MOVLW 1
	MOVWF SYS_TMP7
SYSDIV16_0
	BTFSC SYS_TMP4,7	; OP2 linksbündig
	GOTO SYSDIV16_1
	INCF SYS_TMP7,F
	BCF STATUS,CARRY
	RLF SYS_TMP3,F
	RLF SYS_TMP4,F
	GOTO SYSDIV16_0
SYSDIV16_1
	MOVFW SYS_TMP4	; OP1 und OP2 vergleichen
	SUBWF SYS_TMP2,W	; F-W -> W
	BTFSS STATUS,ZERO
	GOTO SYSDIV16_2
	MOVFW SYS_TMP3
	SUBWF SYS_TMP1,W	; F-W -> W
SYSDIV16_2
	BTFSS STATUS,CARRY
	GOTO SYSDIV16_3
	MOVFW SYS_TMP4	; OP1-OP2
	SUBWF SYS_TMP2,F	; F-W -> F
	MOVFW SYS_TMP3
	SUBWF SYS_TMP1,F	; F-W -> F
	BTFSS STATUS,CARRY
	DECF SYS_TMP2,F
	BSF STATUS,CARRY
SYSDIV16_3
	RLF SYS_TMP5,F	; Ergebnis aktualisieren
	RLF SYS_TMP6,F
	RRF SYS_TMP4,F	; OP2 nach rechts schieben
	RRF SYS_TMP3,F
	DECFSZ SYS_TMP7,F	; Zähler -1
	GOTO SYSDIV16_1
	RETURN
SYSDIV16_ERROR
	MOVLW 255
	MOVWF SYS_TMP5
	MOVWF SYS_TMP6
	RETURN
; Subroutines
; Read  -> AN0
READ_AN0
	MOVLW B'100'
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF ADCON1
	BSF TRISA,0
	BSF ADCON1,ADFM	; Right-Justified
	MOVLW B'11000001'	; CH0
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_0
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_0
	BSF ADCON0,GO	; Start convert
SYS_ADC_LABEL_1
	BTFSC ADCON0,GO	; ready ?
	GOTO SYS_ADC_LABEL_1	; no
	MOVFW ADRESL
	MOVWF ADC0
	MOVFW ADRESH
	MOVWF ADC0_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
; Read  -> AN1
READ_AN1
	MOVLW B'100'
	MOVWF ADCON1
	BSF TRISA,1
	MOVLW B'11001001'	; CH1
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_2
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_2
SYS_ADC_LABEL_3
	GOTO SYS_ADC_LABEL_3	; no
	MOVFW ADRESL
	MOVWF ADC1
	MOVFW ADRESH
	MOVWF ADC1_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
; Subroutines for LB1
LCD_LB1_INIT
	BCF PORTB,4	; ir-register
LCD_LB1_L1
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L1
	MOVFW PORTB
	ANDLW H'F0'
	IORLW B'0011'	; Function Set
	MOVWF PORTB
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	BSF SYS_TMP1,5	; wait
LCD_LB1_L2
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L2
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BCF PORTB,0	; 4-Bit Interface
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	MOVLW B'00101000'	; Function Set 4-Bit,2-Lines
	CALL LCD_LB1_OUT
	MOVLW B'00001100'	; Display on, Cursor off, Blink off
	CALL LCD_LB1_OUT
	MOVLW B'00000110'	; Entrymode set
	CALL LCD_LB1_OUT
LCD_LB1_CLR
	MOVLW B'00000001'	; Display clear
	CALL LCD_LB1_OUT
LCD_LB1_L3
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L3
	GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
	MOVLW H'40'
	BTFSC SYS_TMP2,0	; Ypos
	ADDWF SYS_TMP1,F
	BSF SYS_TMP1,7	; select dd-ram
	GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
	BSF PORTB,4	; dd-ram
LCD_LB1_WRITESTR1
	CALL LCD_LB1_CHAROUT
	BSF INTCON,GIE
	ANDLW H'FF'	; last is zero
	BTFSC STATUS,ZERO
	RETURN
	MOVWF SYS_TMP1
	MOVLW HIGH LCD_LB1_OUT1	; set page
	MOVWF PCLATH
	CALL LCD_LB1_OUT1
	INCFSZ SYS_TMP4,F	; next char
	GOTO LCD_LB1_WRITESTR1
	INCF SYS_TMP5,F	; next page
LCD_LB1_CHAROUT
	BCF INTCON,GIE
	MOVFW SYS_TMP5
	MOVWF PCLATH
	MOVFW SYS_TMP4
	MOVWF PCL
LCD_LB1_DEZO10000
	MOVLW LOW 10000
	MOVWF SYS_TMP1
	MOVLW HIGH 10000
	MOVWF SYS_TMP2
	CALL LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1000
	CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
LCD_LB1_DEZO100
	MOVLW LOW 100
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
	MOVLW LOW 10
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
	MOVLW 48
	ADDWF SYS_TMP4,W
	GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
	INCF SYS_TMP6,F
	MOVFW SYS_TMP1
	SUBWF SYS_TMP4,F
	MOVFW SYS_TMP2
	BTFSS STATUS,CARRY
	INCFSZ SYS_TMP2,W
	SUBWF SYS_TMP5,F
	BTFSC STATUS,CARRY
	GOTO LCD_LB1_CONVERTDEZ2
	MOVFW SYS_TMP2
	ADDWF SYS_TMP5,F
	MOVFW SYS_TMP1
	ADDWF SYS_TMP4,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP5,F
	DECF SYS_TMP6,W
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	RETURN
LCD_LB1_CONVERTHEX
	ANDLW 15
	MOVWF SYS_TMP1
	MOVLW 48
	ADDWF SYS_TMP1,F
	MOVLW 58
	SUBWF SYS_TMP1,W
	BTFSS STATUS,CARRY
	GOTO $+3
	MOVLW 7
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
	MOVWF SYS_TMP1	; store
LCD_LB1_OUT1
	CLRF SYS_TMP3	; LCDWriteStr (first nibble)
LCD_LB1_OUT2
	SWAPF SYS_TMP1,W	;high nibble
LCD_LB1_OUT3
	ANDLW H'0F'	; mask
	MOVWF SYS_TMP2	; store
	MOVFW PORTB	; load port
	ANDLW H'F0'	; mask
	IORWF SYS_TMP2,W	; add cmd
	MOVWF PORTB	; out
	BSF PORTB,5	; E high
	GOTO $+1
	BCF PORTB,5	; E low
	BTFSC SYS_TMP3,3	; ready ?
	GOTO LCD_LB1_OUT4	; yes
	BSF SYS_TMP3,3	; second nibble
	MOVFW SYS_TMP1
	GOTO LCD_LB1_OUT3	; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
	DECFSZ SYS_TMP3,F
	GOTO LCD_LB1_OUTV
	RETURN
LCD_LB1_CHECKNULL
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	MOVWF SYS_TMP1
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	MOVLW 48
	BTFSC SYS_TMP10,0
	ADDWF SYS_TMP1,f
	MOVLW 32
	BTFSS SYS_TMP10,0
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
; 014B
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW B'00000000'
	MOVWF PORTD
	MOVLW B'00000000'
	MOVWF PORTE
	MOVLW 15
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11000000'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
	MOVLW B'11111111'
	MOVWF TRISD
	MOVLW B'00000111'
	MOVWF TRISE
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
; Init LCD -> LB1
	CALL LCD_LB1_INIT
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
	CALL READ_AN0
	CALL READ_AN1
;AF1
	MOVFW ADC0
	MOVWF SYS_TMP1
	MOVFW ADC0_HI
	MOVWF SYS_TMP2
	MOVLW LOW 12
	MOVWF SYS_TMP3
	MOVLW HIGH 12
	MOVWF SYS_TMP4
	MOVLW HIGH SYSMUL16
	MOVWF PCLATH
	CALL SYSMUL16
	MOVLW HIGH LABEL_AF1
	MOVWF PCLATH
LABEL_AF1
	MOVFW SYS_TMP5
	MOVWF S0
	MOVFW SYS_TMP6
	MOVWF S0_HI
LABEL_AF1_EXIT
;AF2
	MOVFW S0
	MOVWF SYS_TMP1
	MOVFW S0_HI
	MOVWF SYS_TMP2
	MOVLW LOW 4
	MOVWF SYS_TMP3
	MOVLW HIGH 4
	MOVWF SYS_TMP4
	MOVLW HIGH SYSDIV16
	MOVWF PCLATH
	CALL SYSDIV16
	MOVLW HIGH LABEL_AF2
	MOVWF PCLATH
LABEL_AF2
	MOVFW SYS_TMP5
	MOVWF S1
	MOVFW SYS_TMP6
	MOVWF S1_HI
LABEL_AF2_EXIT
;AF3
	MOVFW S1
	MOVWF SYS_TMP1
	MOVFW S1_HI
	MOVWF SYS_TMP2
	MOVLW LOW 100
	MOVWF SYS_TMP3
	MOVLW HIGH 100
	MOVWF SYS_TMP4
	MOVLW HIGH SYSDIV16
	MOVWF PCLATH
	CALL SYSDIV16
	MOVLW HIGH LABEL_AF3
	MOVWF PCLATH
LABEL_AF3
	MOVFW SYS_TMP5
	MOVWF S2
	MOVFW SYS_TMP6
	MOVWF S2_HI
LABEL_AF3_EXIT
;AF4
	MOVFW S2
	MOVWF SYS_TMP1
	MOVFW S2_HI
	MOVWF SYS_TMP2
	MOVLW LOW 100
	MOVWF SYS_TMP3
	MOVLW HIGH 100
	MOVWF SYS_TMP4
	MOVLW HIGH SYSMUL16
	MOVWF PCLATH
	CALL SYSMUL16
	MOVLW HIGH LABEL_AF4
	MOVWF PCLATH
LABEL_AF4
	MOVFW SYS_TMP5
	MOVWF S3
	MOVFW SYS_TMP6
	MOVWF S3_HI
LABEL_AF4_EXIT
;AF5
	MOVFW S3_HI
	SUBWF S1_HI,W
	MOVWF S4_HI
	MOVFW S3
	SUBWF S1,W
	MOVWF S4
	BTFSS STATUS,CARRY
	DECF S4_HI,F
LABEL_AF5_EXIT
; LCD -> LT1
; test of positiv edge
	BTFSC LT1_FD,0
	GOTO LABEL_LT1_SETFD
	BTFSS S10,0
	MOVLW 2
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVLW HIGH LCD_LB1_GOTOXY	; set page
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW S2
	MOVWF SYS_TMP4
	MOVFW S2_HI
	MOVWF SYS_TMP5
	BCF SYS_TMP10,0
	MOVLW 4
	MOVWF SYS_TMP9
	MOVLW HIGH LCD_LB1_DEZO10000	; set page
	MOVWF PCLATH
	CALL LCD_LB1_DEZO10000
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
LABEL_LT1_SETFD
	BTFSS S10,0
	GOTO LABEL_LT1_SETFD2
	BSF LT1_FD,0
	GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
	BCF LT1_FD,0
LABEL_LT1_END
; LCD -> LT2
	BTFSC LT2_FD,0
	GOTO LABEL_LT2_SETFD
	BTFSS S10,0
	MOVLW 5
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW S4
	MOVWF SYS_TMP4
	MOVFW S4_HI
	MOVWF SYS_TMP5
	BSF SYS_TMP10,0
	MOVLW 4
	MOVWF SYS_TMP9
	MOVWF PCLATH
LABEL_LT2_SETFD
	BTFSS S10,0
	GOTO LABEL_LT2_SETFD2
	BSF LT2_FD,0
	GOTO LABEL_LT2_END
LABEL_LT2_SETFD2
	BCF LT2_FD,0
LABEL_LT2_END
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 39
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 39
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S10,0
	GOTO LABEL_TR1_CLR
	BSF S10,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S10,0
LABEL_TR1_ENDE
; LCD -> LT3
	BTFSC LT3_FD,0
	GOTO LABEL_LT3_SETFD
	BTFSS S10,0
	MOVLW 4
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT3
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT3
	MOVWF SYS_TMP5
	MOVLW HIGH LCD_LB1_WRITESTR	; set page
	MOVWF PCLATH
	CALL LCD_LB1_WRITESTR
LABEL_LT3_SETFD
	BTFSS S10,0
	GOTO LABEL_LT3_SETFD2
	BSF LT3_FD,0
	GOTO LABEL_LT3_END
LABEL_LT3_SETFD2
	BCF LT3_FD,0
LABEL_LT3_END
;AF6
	MOVFW ADC1
	MOVWF SYS_TMP1
	MOVFW ADC1_HI
	MOVWF SYS_TMP2
	MOVLW LOW 10
	MOVWF SYS_TMP3
	MOVLW HIGH 10
	MOVWF SYS_TMP4
	MOVLW HIGH SYSMUL16
	MOVWF PCLATH
	CALL SYSMUL16
	MOVLW HIGH LABEL_AF6
	MOVWF PCLATH
LABEL_AF6
	MOVFW SYS_TMP5
	MOVWF S9
	MOVFW SYS_TMP6
	MOVWF S9_HI
LABEL_AF6_EXIT
;AF7
	MOVFW S9
	MOVWF SYS_TMP1
	MOVFW S9_HI
	MOVWF SYS_TMP2
	MOVLW LOW 2
	MOVWF SYS_TMP3
	MOVLW HIGH 2
	MOVWF SYS_TMP4
	MOVLW HIGH SYSDIV16
	MOVWF PCLATH
	CALL SYSDIV16
	MOVLW HIGH LABEL_AF7
	MOVWF PCLATH
LABEL_AF7
	MOVFW SYS_TMP5
	MOVWF S8
	MOVFW SYS_TMP6
	MOVWF S8_HI
LABEL_AF7_EXIT
;AF8
	MOVFW S8
	MOVWF SYS_TMP1
	MOVFW S8_HI
	MOVWF SYS_TMP2
	MOVLW LOW 100
	MOVWF SYS_TMP3
	MOVLW HIGH 100
	MOVWF SYS_TMP4
	MOVLW HIGH SYSDIV16
	MOVWF PCLATH
	CALL SYSDIV16
	MOVLW HIGH LABEL_AF8
	MOVWF PCLATH
LABEL_AF8
	MOVFW SYS_TMP5
	MOVWF S7
	MOVFW SYS_TMP6
	MOVWF S7_HI
LABEL_AF8_EXIT
;AF9
	MOVFW S7
	MOVWF SYS_TMP1
	MOVFW S7_HI
	MOVWF SYS_TMP2
	MOVLW LOW 100
	MOVWF SYS_TMP3
	MOVLW HIGH 100
	MOVWF SYS_TMP4
	MOVLW HIGH SYSMUL16
	MOVWF PCLATH
	CALL SYSMUL16
	MOVLW HIGH LABEL_AF9
	MOVWF PCLATH
LABEL_AF9
	MOVFW SYS_TMP5
	MOVWF S6
	MOVFW SYS_TMP6
	MOVWF S6_HI
LABEL_AF9_EXIT
;AF10
	MOVFW S6_HI
	SUBWF S8_HI,W
	MOVWF S5_HI
	MOVFW S6
	SUBWF S8,W
	MOVWF S5
	BTFSS STATUS,CARRY
	DECF S5_HI,F
LABEL_AF10_EXIT
; LCD -> LT4
	BTFSC LT4_FD,0
	GOTO LABEL_LT4_SETFD
	BTFSS S10,0
	MOVLW 2
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW S7
	MOVWF SYS_TMP4
	MOVFW S7_HI
	MOVWF SYS_TMP5
	BCF SYS_TMP10,0
	MOVLW 4
	MOVWF SYS_TMP9
	MOVWF PCLATH
LABEL_LT4_SETFD
	BTFSS S10,0
	GOTO LABEL_LT4_SETFD2
	BSF LT4_FD,0
	GOTO LABEL_LT4_END
LABEL_LT4_SETFD2
	BCF LT4_FD,0
LABEL_LT4_END
; LCD -> LT5
	BTFSC LT5_FD,0
	GOTO LABEL_LT5_SETFD
	BTFSS S10,0
	MOVLW 5
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVFW S5
	MOVWF SYS_TMP4
	MOVFW S5_HI
	MOVWF SYS_TMP5
	BCF SYS_TMP10,0
	MOVLW 4
	MOVWF SYS_TMP9
	MOVWF PCLATH
LABEL_LT5_SETFD
	BTFSS S10,0
	GOTO LABEL_LT5_SETFD2
	BSF LT5_FD,0
	GOTO LABEL_LT5_END
LABEL_LT5_SETFD2
	BCF LT5_FD,0
LABEL_LT5_END
; LCD -> LT6
	BTFSC LT6_FD,0
	GOTO LABEL_LT6_SETFD
	BTFSS S10,0
	MOVLW 4
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT6
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT6
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT6_SETFD
	BTFSS S10,0
	GOTO LABEL_LT6_SETFD2
	BSF LT6_FD,0
	GOTO LABEL_LT6_END
LABEL_LT6_SETFD2
	BCF LT6_FD,0
LABEL_LT6_END
; LCD -> LT7
	BTFSC LT7_FD,0
	GOTO LABEL_LT7_SETFD
	BTFSS S10,0
	MOVLW 8
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT7
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT7
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT7_SETFD
	BTFSS S10,0
	GOTO LABEL_LT7_SETFD2
	BSF LT7_FD,0
	GOTO LABEL_LT7_END
LABEL_LT7_SETFD2
	BCF LT7_FD,0
LABEL_LT7_END
; LCD -> LT8
	BTFSC LT8_FD,0
	GOTO LABEL_LT8_SETFD
	BTFSS S10,0
	MOVLW 8
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT8
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT8
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT8_SETFD
	BTFSS S10,0
	GOTO LABEL_LT8_SETFD2
	BSF LT8_FD,0
	GOTO LABEL_LT8_END
LABEL_LT8_SETFD2
	BCF LT8_FD,0
LABEL_LT8_END
	GOTO MAIN
TAB_LT3
	RETLW 44	; ,
	RETLW 0	; end
TAB_LT6
	RETLW 44	; ,
	RETLW 0	; end
TAB_LT7
	RETLW 65	; A
	RETLW 109	; m
	RETLW 112	; p
	RETLW 101	; e
	RETLW 114	; r
	RETLW 32	;  
	RETLW 0	; end
TAB_LT8
	RETLW 86	; V
	RETLW 111	; o
	RETLW 108	; l
	RETLW 116	; t
	RETLW 0	; end
	END
