; Source created with Parsic Version 3.x
; at              : 2009.11.05. 6:39:33
; Project File    : C:\DOCUME~1\ALLUSE~1\ASZTAL\lcd.PIC
; Project Version : 1.0.4
; Created         : 2009.02.19. 20:03:00
; Last change     : 2009.11.05. 6:39:28
	PROCESSOR 16F876
	INCLUDE P16F876.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
TR1	= 32	; located in Bank 0
TR1_HI	= 33	; located in Bank 0
S3	= 34	; located in Bank 0
ZV1	= 35	; located in Bank 0
ZV1_FD	= 36	; located in Bank 0
S4	= 37	; located in Bank 0
S2	= 38	; located in Bank 0
S0	= 39	; located in Bank 0
S1	= 40	; located in Bank 0
S5	= 41	; located in Bank 0
ZV2	= 42	; located in Bank 0
ZV2_FD	= 43	; located in Bank 0
S6	= 44	; located in Bank 0
S7	= 45	; located in Bank 0
LT1_FD	= 46	; located in Bank 0
LT2_FD	= 47	; located in Bank 0
LT3_FD	= 48	; located in Bank 0
LT4_FD	= 49	; located in Bank 0
LT5_FD	= 50	; located in Bank 0
LT6_FD	= 51	; located in Bank 0
LT7_FD	= 52	; located in Bank 0
LT8_FD	= 53	; located in Bank 0
LT9_FD	= 54	; located in Bank 0
LT10_FD	= 55	; located in Bank 0
LT11_FD	= 56	; located in Bank 0
LT12_FD	= 57	; located in Bank 0
LT13_FD	= 58	; located in Bank 0
LT14_FD	= 59	; located in Bank 0
LT15_FD	= 60	; located in Bank 0
LT16_FD	= 61	; located in Bank 0
LT17_FD	= 62	; located in Bank 0
LT18_FD	= 63	; located in Bank 0
RAM	= 64	; located in Bank 0
SYS_WSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 115	; located in Bank 0, 1, 2, 3
SYS_PSAV	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP1	= 117	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 118	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 119	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 120	; located in Bank 0, 1, 2, 3
SYS_TMP5	= 121	; located in Bank 0, 1, 2, 3
SYS_TMP6	= 122	; located in Bank 0, 1, 2, 3
SYS_TMP9	= 123	; located in Bank 0, 1, 2, 3
SYS_TMP10	= 124	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 125	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	MOVFW PCLATH
	MOVWF SYS_PSAV
	CLRF PCLATH
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_PSAV
	MOVWF PCLATH
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
; Subroutines for LB1
LCD_LB1_INIT
	BCF PORTB,4	; ir-register
LCD_LB1_L1
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L1
	MOVFW PORTB
	ANDLW H'F0'
	IORLW B'0011'	; Function Set
	MOVWF PORTB
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	BSF SYS_TMP1,5	; wait
LCD_LB1_L2
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L2
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	BCF PORTB,0	; 4-Bit Interface
	BSF PORTB,5	; write
	GOTO $+1
	BCF PORTB,5
	CALL LCD_LB1_OUT4
	MOVLW B'00101000'	; Function Set 4-Bit,2-Lines
	CALL LCD_LB1_OUT
	MOVLW B'00001100'	; Display on, Cursor off, Blink off
	CALL LCD_LB1_OUT
	MOVLW B'00000110'	; Entrymode set
	CALL LCD_LB1_OUT
LCD_LB1_CLR
	MOVLW B'00000001'	; Display clear
	CALL LCD_LB1_OUT
LCD_LB1_L3
	CALL LCD_LB1_OUT4
	DECFSZ SYS_TMP1,F
	GOTO LCD_LB1_L3
	GOTO LCD_LB1_OUT4
LCD_LB1_GOTOXY
	MOVLW H'40'
	BTFSC SYS_TMP2,0	; Ypos
	ADDWF SYS_TMP1,F
	BSF SYS_TMP1,7	; select dd-ram
	GOTO LCD_LB1_OUT1
LCD_LB1_WRITESTR
	BSF PORTB,4	; dd-ram
LCD_LB1_WRITESTR1
	CALL LCD_LB1_CHAROUT
	BSF INTCON,GIE
	ANDLW H'FF'	; last is zero
	BTFSC STATUS,ZERO
	RETURN
	MOVWF SYS_TMP1
	MOVLW HIGH LCD_LB1_OUT1	; set page
	MOVWF PCLATH
	CALL LCD_LB1_OUT1
	INCFSZ SYS_TMP4,F	; next char
	GOTO LCD_LB1_WRITESTR1
	INCF SYS_TMP5,F	; next page
LCD_LB1_CHAROUT
	BCF INTCON,GIE
	MOVFW SYS_TMP5
	MOVWF PCLATH
	MOVFW SYS_TMP4
	MOVWF PCL
LCD_LB1_DEZO10000
	MOVLW LOW 10000
	MOVWF SYS_TMP1
	MOVLW HIGH 10000
	MOVWF SYS_TMP2
	CALL LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1000
	CALL LCD_LB1_CHECKNULL
LCD_LB1_DEZO1000
	MOVLW LOW 1000
	MOVWF SYS_TMP1
	MOVLW HIGH 1000
	MOVWF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
LCD_LB1_DEZO100
	MOVLW LOW 100
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO10
LCD_LB1_DEZO10
	MOVLW LOW 10
	MOVWF SYS_TMP1
	CLRF SYS_TMP2
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	GOTO LCD_LB1_DEZO1
LCD_LB1_DEZO1
	MOVLW 48
	ADDWF SYS_TMP4,W
	GOTO LCD_LB1_WRITECHAR
LCD_LB1_CONVERTDEZ
	MOVF SYS_TMP9,F
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	CLRF SYS_TMP6
LCD_LB1_CONVERTDEZ2
	INCF SYS_TMP6,F
	MOVFW SYS_TMP1
	SUBWF SYS_TMP4,F
	MOVFW SYS_TMP2
	BTFSS STATUS,CARRY
	INCFSZ SYS_TMP2,W
	SUBWF SYS_TMP5,F
	BTFSC STATUS,CARRY
	GOTO LCD_LB1_CONVERTDEZ2
	MOVFW SYS_TMP2
	ADDWF SYS_TMP5,F
	MOVFW SYS_TMP1
	ADDWF SYS_TMP4,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP5,F
	DECF SYS_TMP6,W
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	RETURN
LCD_LB1_CONVERTHEX
	ANDLW 15
	MOVWF SYS_TMP1
	MOVLW 48
	ADDWF SYS_TMP1,F
	MOVLW 58
	SUBWF SYS_TMP1,W
	BTFSS STATUS,CARRY
	GOTO $+3
	MOVLW 7
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
LCD_LB1_WRITECHAR
LCD_LB1_OUT
	MOVWF SYS_TMP1	; store
LCD_LB1_OUT1
	CLRF SYS_TMP3	; LCDWriteStr (first nibble)
LCD_LB1_OUT2
	SWAPF SYS_TMP1,W	;high nibble
LCD_LB1_OUT3
	ANDLW H'0F'	; mask
	MOVWF SYS_TMP2	; store
	MOVFW PORTB	; load port
	ANDLW H'F0'	; mask
	IORWF SYS_TMP2,W	; add cmd
	MOVWF PORTB	; out
	BSF PORTB,5	; E high
	GOTO $+1
	BCF PORTB,5	; E low
	BTFSC SYS_TMP3,3	; ready ?
	GOTO LCD_LB1_OUT4	; yes
	BSF SYS_TMP3,3	; second nibble
	MOVFW SYS_TMP1
	GOTO LCD_LB1_OUT3	; next nibble
LCD_LB1_OUT4
LCD_LB1_OUTV
	DECFSZ SYS_TMP3,F
	GOTO LCD_LB1_OUTV
	RETURN
LCD_LB1_CHECKNULL
	BTFSS STATUS,ZERO
	DECF SYS_TMP9,F
	MOVWF SYS_TMP1
	BTFSS STATUS,ZERO
	BSF SYS_TMP10,0
	MOVLW 48
	BTFSC SYS_TMP10,0
	ADDWF SYS_TMP1,f
	MOVLW 32
	BTFSS SYS_TMP10,0
	ADDWF SYS_TMP1,F
	MOVFW SYS_TMP1
; 00DD
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11000000'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
; Init LCD -> LB1
	CALL LCD_LB1_INIT
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 7	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 161
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 161
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S3,0
	GOTO LABEL_TR1_CLR
	BSF S3,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S3,0
LABEL_TR1_ENDE
; Zähler -> ZV1
	BTFSS S4,2	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S3,0
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S3,1	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S3,0
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Verteiler -> BV1
	BTFSC S0,0
	GOTO LABEL_BV1_0
	BCF S3,2
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF S3,2
LABEL_BV1_0_END
	BTFSC S0,1
	GOTO LABEL_BV1_1
	BCF S3,3
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF S3,3
LABEL_BV1_1_END
	BTFSC S0,2
	GOTO LABEL_BV1_2
	BCF S3,4
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF S3,4
LABEL_BV1_2_END
	BTFSC S0,3
	GOTO LABEL_BV1_3
	BCF S3,5
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF S3,5
LABEL_BV1_3_END
	BTFSC S0,4
	GOTO LABEL_BV1_4
	BCF S3,6
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BSF S3,6
LABEL_BV1_4_END
	BTFSC S0,5
	GOTO LABEL_BV1_5
	BCF S3,7
	GOTO LABEL_BV1_5_END
LABEL_BV1_5
	BSF S3,7
LABEL_BV1_5_END
	BTFSC S0,6
	GOTO LABEL_BV1_6
	BCF S4,0
	GOTO LABEL_BV1_6_END
LABEL_BV1_6
	BSF S4,0
LABEL_BV1_6_END
	BTFSC S0,7
	GOTO LABEL_BV1_7
	BCF S4,1
	GOTO LABEL_BV1_7_END
LABEL_BV1_7
	BSF S4,1
LABEL_BV1_7_END
; Call subroutine TAB
	MOVLW LOW TAB
	MOVWF SYS_TMP1
	MOVLW HIGH TAB
	MOVWF SYS_TMP2
	MOVFW ZV1
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	MOVLW HIGH SYSTABJMP	; set page
	MOVWF PCLATH
	CALL SYSTABJMP
	MOVWF S2
	BSF INTCON,GIE
	BCF PCLATH,3	; Page 0
	BCF PCLATH,4	; Page 0
; Vergleich -> IF1
	MOVLW 9
	SUBWF ZV1,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S4,2
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S4,2
LABEL_IF1_EXIT
; Multiplexer -> MX1
	CLRF SYS_TMP1
	MOVFW ZV2
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL1
	MOVFW S2
	MOVWF S0
	GOTO LABEL_MX1_END
	INCF SYS_TMP1,F
	MOVFW ZV2
	SUBWF SYS_TMP1,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MX1_CHECKCONTROL2
	MOVFW S2
	MOVWF S1
	GOTO LABEL_MX1_END
LABEL_MX1_END
; Verteiler -> BV2
	BTFSC S1,0
	GOTO LABEL_BV2_0
	BCF S4,4
	GOTO LABEL_BV2_0_END
LABEL_BV2_0
	BSF S4,4
LABEL_BV2_0_END
	BTFSC S1,1
	GOTO LABEL_BV2_1
	BCF S4,5
	GOTO LABEL_BV2_1_END
LABEL_BV2_1
	BSF S4,5
LABEL_BV2_1_END
	BTFSC S1,2
	GOTO LABEL_BV2_2
	BCF S4,6
	GOTO LABEL_BV2_2_END
LABEL_BV2_2
	BSF S4,6
LABEL_BV2_2_END
	BTFSC S1,3
	GOTO LABEL_BV2_3
	BCF S4,7
	GOTO LABEL_BV2_3_END
LABEL_BV2_3
	BSF S4,7
LABEL_BV2_3_END
	BTFSC S1,4
	GOTO LABEL_BV2_4
	BCF S5,0
	GOTO LABEL_BV2_4_END
LABEL_BV2_4
	BSF S5,0
LABEL_BV2_4_END
	BTFSC S1,5
	GOTO LABEL_BV2_5
	BCF S5,1
	GOTO LABEL_BV2_5_END
LABEL_BV2_5
	BSF S5,1
LABEL_BV2_5_END
	BTFSC S1,6
	GOTO LABEL_BV2_6
	BCF S5,2
	GOTO LABEL_BV2_6_END
LABEL_BV2_6
	BSF S5,2
LABEL_BV2_6_END
	BTFSC S1,7
	GOTO LABEL_BV2_7
	BCF S5,3
	GOTO LABEL_BV2_7_END
LABEL_BV2_7
	BSF S5,3
LABEL_BV2_7_END
; Zähler -> ZV2
	BTFSS S4,3	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S4,2
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S4,2
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Schmitt-Trigger 8-Bit -> ST1
	BTFSC S4,3	; Ausgang gesetzt ?
	GOTO LABEL_ST1_MH	; dann mit Hysterese ?
	MOVLW 2
	GOTO LABEL_ST1_TEST
LABEL_ST1_MH
	MOVLW 2
LABEL_ST1_TEST
	SUBWF ZV2,W
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
	BSF S4,3	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S4,3	; if less
LABEL_ST1_ENDE
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S3,2
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S3,0
LABEL_LG1_TRUE
	BSF S5,4
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S5,4
LABEL_LG1_ENDE
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S3,3
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSS S3,0
LABEL_LG2_TRUE
	BSF S5,5
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF S5,5
LABEL_LG2_ENDE
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S3,4
	GOTO LABEL_LG3_FALSE
LABEL_LG3_2
	BTFSS S3,0
LABEL_LG3_TRUE
	BSF S5,6
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF S5,6
LABEL_LG3_ENDE
; UND - Gatter -> LG4
LABEL_LG4_1
	BTFSS S3,5
	GOTO LABEL_LG4_FALSE
LABEL_LG4_2
	BTFSS S3,0
LABEL_LG4_TRUE
	BSF S5,7
	GOTO LABEL_LG4_ENDE
LABEL_LG4_FALSE
	BCF S5,7
LABEL_LG4_ENDE
; UND - Gatter -> LG5
LABEL_LG5_1
	BTFSS S3,6
	GOTO LABEL_LG5_FALSE
LABEL_LG5_2
	BTFSS S3,0
LABEL_LG5_TRUE
	BSF S6,0
	GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
	BCF S6,0
LABEL_LG5_ENDE
; UND - Gatter -> LG6
LABEL_LG6_1
	BTFSS S3,7
	GOTO LABEL_LG6_FALSE
LABEL_LG6_2
	BTFSS S3,0
LABEL_LG6_TRUE
	BSF S6,1
	GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
	BCF S6,1
LABEL_LG6_ENDE
; UND - Gatter -> LG7
LABEL_LG7_1
	BTFSS S4,0
	GOTO LABEL_LG7_FALSE
LABEL_LG7_2
	BTFSS S3,0
LABEL_LG7_TRUE
	BSF S6,2
	GOTO LABEL_LG7_ENDE
LABEL_LG7_FALSE
	BCF S6,2
LABEL_LG7_ENDE
; UND - Gatter -> LG8
LABEL_LG8_1
	BTFSS S4,1
	GOTO LABEL_LG8_FALSE
LABEL_LG8_2
	BTFSS S3,0
LABEL_LG8_TRUE
	BSF S6,3
	GOTO LABEL_LG8_ENDE
LABEL_LG8_FALSE
	BCF S6,3
LABEL_LG8_ENDE
; UND - Gatter -> LG9
LABEL_LG9_1
	BTFSS S4,4
	GOTO LABEL_LG9_FALSE
LABEL_LG9_2
	BTFSS S3,0
LABEL_LG9_TRUE
	BSF S6,4
	GOTO LABEL_LG9_ENDE
LABEL_LG9_FALSE
	BCF S6,4
LABEL_LG9_ENDE
; UND - Gatter -> LG10
LABEL_LG10_1
	BTFSS S4,5
	GOTO LABEL_LG10_FALSE
LABEL_LG10_2
	BTFSS S3,0
LABEL_LG10_TRUE
	BSF S6,5
	GOTO LABEL_LG10_ENDE
LABEL_LG10_FALSE
	BCF S6,5
LABEL_LG10_ENDE
; UND - Gatter -> LG11
LABEL_LG11_1
	BTFSS S4,6
	GOTO LABEL_LG11_FALSE
LABEL_LG11_2
	BTFSS S3,0
LABEL_LG11_TRUE
	BSF S6,6
	GOTO LABEL_LG11_ENDE
LABEL_LG11_FALSE
	BCF S6,6
LABEL_LG11_ENDE
; UND - Gatter -> LG12
LABEL_LG12_1
	BTFSS S4,7
	GOTO LABEL_LG12_FALSE
LABEL_LG12_2
	BTFSS S3,0
LABEL_LG12_TRUE
	BSF S6,7
	GOTO LABEL_LG12_ENDE
LABEL_LG12_FALSE
	BCF S6,7
LABEL_LG12_ENDE
; UND - Gatter -> LG13
LABEL_LG13_1
	BTFSS S5,0
	GOTO LABEL_LG13_FALSE
LABEL_LG13_2
	BTFSS S3,0
LABEL_LG13_TRUE
	BSF S7,0
	GOTO LABEL_LG13_ENDE
LABEL_LG13_FALSE
	BCF S7,0
LABEL_LG13_ENDE
; UND - Gatter -> LG14
LABEL_LG14_1
	BTFSS S5,1
	GOTO LABEL_LG14_FALSE
LABEL_LG14_2
	BTFSS S3,0
LABEL_LG14_TRUE
	BSF S7,1
	GOTO LABEL_LG14_ENDE
LABEL_LG14_FALSE
	BCF S7,1
LABEL_LG14_ENDE
; UND - Gatter -> LG15
LABEL_LG15_1
	BTFSS S5,2
	GOTO LABEL_LG15_FALSE
LABEL_LG15_2
	BTFSS S3,0
LABEL_LG15_TRUE
	BSF S7,2
	GOTO LABEL_LG15_ENDE
LABEL_LG15_FALSE
	BCF S7,2
LABEL_LG15_ENDE
; UND - Gatter -> LG16
LABEL_LG16_1
	BTFSS S5,3
	GOTO LABEL_LG16_FALSE
LABEL_LG16_2
	BTFSS S3,0
LABEL_LG16_TRUE
	BSF S7,3
	GOTO LABEL_LG16_ENDE
LABEL_LG16_FALSE
	BCF S7,3
LABEL_LG16_ENDE
; LCD -> LT1
; test of positiv edge
	BTFSC LT1_FD,0
	GOTO LABEL_LT1_SETFD
	BTFSS S5,4
	MOVLW 22
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVLW HIGH LCD_LB1_GOTOXY	; set page
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT1
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT1
	MOVWF SYS_TMP5
	MOVLW HIGH LCD_LB1_WRITESTR	; set page
	MOVWF PCLATH
	CALL LCD_LB1_WRITESTR
LABEL_LT1_SETFD
	BTFSS S5,4
	GOTO LABEL_LT1_SETFD2
	BSF LT1_FD,0
	GOTO LABEL_LT1_END
LABEL_LT1_SETFD2
	BCF LT1_FD,0
LABEL_LT1_END
; LCD -> LT2
	BTFSC LT2_FD,0
	GOTO LABEL_LT2_SETFD
	BTFSS S5,5
	MOVLW 21
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT2
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT2
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT2_SETFD
	BTFSS S5,5
	GOTO LABEL_LT2_SETFD2
	BSF LT2_FD,0
	GOTO LABEL_LT2_END
LABEL_LT2_SETFD2
	BCF LT2_FD,0
LABEL_LT2_END
; LCD -> LT3
	BTFSC LT3_FD,0
	GOTO LABEL_LT3_SETFD
	BTFSS S5,6
	MOVLW 20
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT3
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT3
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT3_SETFD
	BTFSS S5,6
	GOTO LABEL_LT3_SETFD2
	BSF LT3_FD,0
	GOTO LABEL_LT3_END
LABEL_LT3_SETFD2
	BCF LT3_FD,0
LABEL_LT3_END
; LCD -> LT4
	BTFSC LT4_FD,0
	GOTO LABEL_LT4_SETFD
	BTFSS S5,7
	MOVLW 19
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT4
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT4
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT4_SETFD
	BTFSS S5,7
	GOTO LABEL_LT4_SETFD2
	BSF LT4_FD,0
	GOTO LABEL_LT4_END
LABEL_LT4_SETFD2
	BCF LT4_FD,0
LABEL_LT4_END
; LCD -> LT5
	BTFSC LT5_FD,0
	GOTO LABEL_LT5_SETFD
	BTFSS S6,0
	MOVLW 18
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT5
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT5
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT5_SETFD
	BTFSS S6,0
	GOTO LABEL_LT5_SETFD2
	BSF LT5_FD,0
	GOTO LABEL_LT5_END
LABEL_LT5_SETFD2
	BCF LT5_FD,0
LABEL_LT5_END
; LCD -> LT6
	BTFSC LT6_FD,0
	GOTO LABEL_LT6_SETFD
	BTFSS S6,1
	MOVLW 17
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT6
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT6
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT6_SETFD
	BTFSS S6,1
	GOTO LABEL_LT6_SETFD2
	BSF LT6_FD,0
	GOTO LABEL_LT6_END
LABEL_LT6_SETFD2
	BCF LT6_FD,0
LABEL_LT6_END
; LCD -> LT7
	BTFSC LT7_FD,0
	GOTO LABEL_LT7_SETFD
	BTFSS S6,2
	MOVLW 16
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT7
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT7
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT7_SETFD
	BTFSS S6,2
	GOTO LABEL_LT7_SETFD2
	BSF LT7_FD,0
	GOTO LABEL_LT7_END
LABEL_LT7_SETFD2
	BCF LT7_FD,0
LABEL_LT7_END
; LCD -> LT8
	BTFSC LT8_FD,0
	GOTO LABEL_LT8_SETFD
	BTFSS S6,3
	MOVLW 15
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT8
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT8
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT8_SETFD
	BTFSS S6,3
	GOTO LABEL_LT8_SETFD2
	BSF LT8_FD,0
	GOTO LABEL_LT8_END
LABEL_LT8_SETFD2
	BCF LT8_FD,0
LABEL_LT8_END
; LCD -> LT9
	BTFSC LT9_FD,0
	GOTO LABEL_LT9_SETFD
	BTFSS S6,4
	MOVLW 14
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT9
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT9
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT9_SETFD
	BTFSS S6,4
	GOTO LABEL_LT9_SETFD2
	BSF LT9_FD,0
	GOTO LABEL_LT9_END
LABEL_LT9_SETFD2
	BCF LT9_FD,0
LABEL_LT9_END
; LCD -> LT10
	BTFSC LT10_FD,0
	GOTO LABEL_LT10_SETFD
	BTFSS S6,5
	MOVLW 13
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT10
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT10
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT10_SETFD
	BTFSS S6,5
	GOTO LABEL_LT10_SETFD2
	BSF LT10_FD,0
	GOTO LABEL_LT10_END
LABEL_LT10_SETFD2
	BCF LT10_FD,0
LABEL_LT10_END
; LCD -> LT11
	BTFSC LT11_FD,0
	GOTO LABEL_LT11_SETFD
	BTFSS S6,6
	MOVLW 12
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT11
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT11
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT11_SETFD
	BTFSS S6,6
	GOTO LABEL_LT11_SETFD2
	BSF LT11_FD,0
	GOTO LABEL_LT11_END
LABEL_LT11_SETFD2
	BCF LT11_FD,0
LABEL_LT11_END
; LCD -> LT12
	BTFSC LT12_FD,0
	GOTO LABEL_LT12_SETFD
	BTFSS S6,7
	MOVLW 11
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT12
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT12
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT12_SETFD
	BTFSS S6,7
	GOTO LABEL_LT12_SETFD2
	BSF LT12_FD,0
	GOTO LABEL_LT12_END
LABEL_LT12_SETFD2
	BCF LT12_FD,0
LABEL_LT12_END
; LCD -> LT13
	BTFSC LT13_FD,0
	GOTO LABEL_LT13_SETFD
	BTFSS S7,0
	MOVLW 10
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT13
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT13
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT13_SETFD
	BTFSS S7,0
	GOTO LABEL_LT13_SETFD2
	BSF LT13_FD,0
	GOTO LABEL_LT13_END
LABEL_LT13_SETFD2
	BCF LT13_FD,0
LABEL_LT13_END
; LCD -> LT14
	BTFSC LT14_FD,0
	GOTO LABEL_LT14_SETFD
	BTFSS S7,1
	MOVLW 9
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT14
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT14
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT14_SETFD
	BTFSS S7,1
	GOTO LABEL_LT14_SETFD2
	BSF LT14_FD,0
	GOTO LABEL_LT14_END
LABEL_LT14_SETFD2
	BCF LT14_FD,0
LABEL_LT14_END
; LCD -> LT15
	BTFSC LT15_FD,0
	GOTO LABEL_LT15_SETFD
	BTFSS S7,2
	MOVLW 8
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT15
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT15
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT15_SETFD
	BTFSS S7,2
	GOTO LABEL_LT15_SETFD2
	BSF LT15_FD,0
	GOTO LABEL_LT15_END
LABEL_LT15_SETFD2
	BCF LT15_FD,0
LABEL_LT15_END
; LCD -> LT16
	BTFSC LT16_FD,0
	GOTO LABEL_LT16_SETFD
	BTFSS S7,3
	MOVLW 7
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT16
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT16
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT16_SETFD
	BTFSS S7,3
	GOTO LABEL_LT16_SETFD2
	BSF LT16_FD,0
	GOTO LABEL_LT16_END
LABEL_LT16_SETFD2
	BCF LT16_FD,0
LABEL_LT16_END
; LCD -> LT17
	BTFSC LT17_FD,0
	GOTO LABEL_LT17_SETFD
	BTFSS S3,0
	MOVLW 0
	MOVWF SYS_TMP1
	MOVLW 1
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT17
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT17
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT17_SETFD
	BTFSS S3,0
	GOTO LABEL_LT17_SETFD2
	BSF LT17_FD,0
	GOTO LABEL_LT17_END
LABEL_LT17_SETFD2
	BCF LT17_FD,0
LABEL_LT17_END
; LCD -> LT18
	BTFSC LT18_FD,0
	GOTO LABEL_LT18_SETFD
	BTFSS S3,0
	MOVLW 0
	MOVWF SYS_TMP1
	MOVLW 0
	MOVWF SYS_TMP2
	MOVWF PCLATH
	CALL LCD_LB1_GOTOXY
	MOVLW LOW TAB_LT18
	MOVWF SYS_TMP4
	MOVLW HIGH TAB_LT18
	MOVWF SYS_TMP5
	MOVWF PCLATH
LABEL_LT18_SETFD
	BTFSS S3,0
	GOTO LABEL_LT18_SETFD2
	BSF LT18_FD,0
	GOTO LABEL_LT18_END
LABEL_LT18_SETFD2
	BCF LT18_FD,0
LABEL_LT18_END
	GOTO MAIN
; Table -> TAB
TAB
	RETLW 0	; // INDEX 0
	RETLW 1	; // INDEX 1
	RETLW 2	; // INDEX 2
	RETLW 4	; // INDEX 3
	RETLW 8	; // INDEX 4
	RETLW 16	; // INDEX 5
	RETLW 32	; // INDEX 6
	RETLW 64	; // INDEX 7
	RETLW 128	; // INDEX 8
	RETLW 0	; // INDEX 9
TAB_LT1
	RETLW 107	; k
	RETLW 0	; end
TAB_LT2
	RETLW 107	; k
	RETLW 97	; a
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT3
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT4
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT5
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT6
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT7
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT8
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT9
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT10
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT11
	RETLW 107	; k
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT12
	RETLW 46	; .
	RETLW 97	; a
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT13
	RETLW 46	; .
	RETLW 46	; .
	RETLW 113	; q
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT14
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 107	; k
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT15
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 107	; k
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT16
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 46	; .
	RETLW 0	; end
TAB_LT17
	RETLW 108	; l
	RETLW 99	; c
	RETLW 100	; d
	RETLW 45	; -
	RETLW 116	; t
	RETLW 101	; e
	RETLW 115	; s
	RETLW 122	; z
	RETLW 116	; t
	RETLW 101	; e
	RETLW 114	; r
	RETLW 32	;  
	RETLW 112	; p
	RETLW 105	; i
	RETLW 99	; c
	RETLW 32	;  
	RETLW 49	; 1
	RETLW 54	; 6
	RETLW 102	; f
	RETLW 56	; 8
	RETLW 55	; 7
	RETLW 54	; 6
	RETLW 0	; end
TAB_LT18
	RETLW 50	; 2
	RETLW 48	; 0
	RETLW 48	; 0
	RETLW 57	; 9
	RETLW 32	;  
	RETLW 48	; 0
	RETLW 51	; 3
	RETLW 46	; .
	RETLW 48	; 0
	RETLW 56	; 8
	RETLW 0	; end
	END
