32 bits by 16 by Peter Hemsley
divide movlw 32      ; 32-bit divide by 16-bit
       movwf bitcnt
       clrf remdrH   ; Clear remainder
       clrf remdrL
dvloop clrc          ; Set quotient bit to 0
                     ; Shift left dividend and quotient
       rlf divid0    ; lsb
       rlf divid1
       rlf divid2
       rlf divid3    ; lsb into carry
       rlf remdrL    ; and then into partial remainder
       rlf remdrH
       skpnc         ; Check for overflow
       goto subd
       movfw divisH  ; Compare partial remainder and divisor
       subwf remdrH,w
       skpz 
       goto testgt   ; Not equal so test if remdrH is greater
       movfw divisL  ; High bytes are equal, compare low bytes
       subwf remdrL,w
testgt skpc          ; Carry set if remdr >= divis
       goto remrlt
subd   movfw divisL  ; Subtract divisor from partial remainder
       subwf remdrL
       skpc          ; Test for borrow
       decf remdrH   ; Subtract borrow
       movfw divisH
       subwf remdrH
       bsf divid0,0  ; Set quotient bit to 1
                     ; Quotient replaces dividend which is lost
remrlt decfsz bitcnt
       goto dvloop
       return
