; Source created with Parsic Version 3.x
; at              : 2009.12.21. 9:53:58
; Project File    : C:\Documents and Settings\All Users\Asztal\közlámp.PIC
; Project Version : 1.0.0
; Created         : 2009.12.17. 20:18:00
; Last change     : 2009.12.17. 22:09:00
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV1	= 32	; located in Bank 0
ZV1_FD	= 33	; located in Bank 0
S4	= 34	; located in Bank 0
S0	= 35	; located in Bank 0
S1	= 36	; located in Bank 0
TR1	= 37	; located in Bank 0
TR1_HI	= 38	; located in Bank 0
ZV2	= 39	; located in Bank 0
ZV2_FD	= 40	; located in Bank 0
S5	= 41	; located in Bank 0
S6	= 42	; located in Bank 0
S2	= 43	; located in Bank 0
S3	= 44	; located in Bank 0
S7	= 45	; located in Bank 0
OS1_FD	= 46	; located in Bank 0
ZV3	= 47	; located in Bank 0
ZV3_FD	= 48	; located in Bank 0
OS2_FD	= 49	; located in Bank 0
OS3_FD	= 50	; located in Bank 0
OS4_FD	= 51	; located in Bank 0
OS5_FD	= 52	; located in Bank 0
RAM	= 53	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 113	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 115	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 116	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111100'
	MOVWF TRISA
	MOVLW B'00000000'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW B'00010000'
	MOVWF S6
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
	BTFSS S4,4	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S7,4
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S5,4	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
; Output Q0
	BTFSS ZV1,0
	GOTO LABEL_ZV1_SETOUT0
	BSF S4,5
	GOTO LABEL_ZV1_SETOUT0_END
LABEL_ZV1_SETOUT0
	BCF S4,5
; Output Q1
	BTFSS ZV1,1
	GOTO LABEL_ZV1_SETOUT1
	BSF S4,6
	GOTO LABEL_ZV1_SETOUT1_END
LABEL_ZV1_SETOUT1
	BCF S4,6
; Output Q2
	BTFSS ZV1,2
	GOTO LABEL_ZV1_SETOUT2
	BSF S4,4
	GOTO LABEL_ZV1_SETOUT2_END
LABEL_ZV1_SETOUT2
	BCF S4,4
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S7,4
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Call subroutine TAB
	MOVLW LOW TAB
	MOVWF SYS_TMP1
	MOVLW HIGH TAB
	MOVWF SYS_TMP2
	MOVFW ZV1
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S0
	BSF INTCON,GIE
; Verteiler -> BV1
	BTFSC S0,0
	GOTO LABEL_BV1_0
	BCF PORTB,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTB,0
LABEL_BV1_0_END
	BTFSC S0,1
	GOTO LABEL_BV1_1
	BCF PORTB,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTB,1
LABEL_BV1_1_END
	BTFSC S0,2
	GOTO LABEL_BV1_2
	BCF PORTB,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTB,2
LABEL_BV1_2_END
; Verteiler -> BV2
	BTFSC S1,0
	GOTO LABEL_BV2_0
	BCF PORTB,3
	GOTO LABEL_BV2_0_END
LABEL_BV2_0
	BSF PORTB,3
LABEL_BV2_0_END
	BTFSC S1,1
	GOTO LABEL_BV2_1
	BCF S4,0
	GOTO LABEL_BV2_1_END
LABEL_BV2_1
	BSF S4,0
LABEL_BV2_1_END
	BTFSC S1,2
	GOTO LABEL_BV2_2
	BCF S4,1
	GOTO LABEL_BV2_2_END
LABEL_BV2_2
	BSF S4,1
LABEL_BV2_2_END
; Call subroutine TAB1
	MOVLW LOW TAB1
	MOVWF SYS_TMP1
	MOVLW HIGH TAB1
	MOVWF SYS_TMP2
	MOVFW ZV1
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S1
	BSF INTCON,GIE
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S4,1
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S4,3
LABEL_LG1_TRUE
	BSF S4,2
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S4,2
LABEL_LG1_ENDE
; ODER - Gatter -> LG2
LABEL_LG2_1
	BTFSC S4,0
	GOTO LABEL_LG2_TRUE
LABEL_LG2_2
	BTFSC S4,2
	GOTO LABEL_LG2_TRUE
LABEL_LG2_FALSE
	BCF PORTB,4
	GOTO LABEL_LG2_ENDE
LABEL_LG2_TRUE
	BSF PORTB,4
LABEL_LG2_ENDE
; Timer -> TR1
	MOVLW 3	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 209
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 209
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S4,3
	GOTO LABEL_TR1_CLR
	BSF S4,3
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S4,3
LABEL_TR1_ENDE
; Zähler -> ZV2
	BTFSS S5,2	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S7,2
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
; Output Q0
	BTFSS ZV2,0
	GOTO LABEL_ZV2_SETOUT0
	BSF S5,3
	GOTO LABEL_ZV2_SETOUT0_END
LABEL_ZV2_SETOUT0
	BCF S5,3
; Output Q1
	BTFSS ZV2,1
	GOTO LABEL_ZV2_SETOUT1
	BSF S6,7
	GOTO LABEL_ZV2_SETOUT1_END
LABEL_ZV2_SETOUT1
	BCF S6,7
; Output Q2
	BTFSS ZV2,2
	GOTO LABEL_ZV2_SETOUT2
	BSF S5,2
	GOTO LABEL_ZV2_SETOUT2_END
LABEL_ZV2_SETOUT2
	BCF S5,2
LABEL_ZV2_SETFD
	BTFSC S7,2
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Call subroutine TAB2
	MOVLW LOW TAB2
	MOVWF SYS_TMP1
	MOVLW HIGH TAB2
	MOVWF SYS_TMP2
	MOVFW ZV2
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S2
	BSF INTCON,GIE
; Verteiler -> BV3
	BTFSC S2,0
	GOTO LABEL_BV3_0
	BCF PORTB,5
	GOTO LABEL_BV3_0_END
LABEL_BV3_0
	BSF PORTB,5
LABEL_BV3_0_END
	BTFSC S2,1
	GOTO LABEL_BV3_1
	BCF PORTB,6
	GOTO LABEL_BV3_1_END
LABEL_BV3_1
	BSF PORTB,6
LABEL_BV3_1_END
	BTFSC S2,2
	GOTO LABEL_BV3_2
	BCF PORTB,7
	GOTO LABEL_BV3_2_END
LABEL_BV3_2
	BSF PORTB,7
LABEL_BV3_2_END
; Verteiler -> BV4
	BTFSC S3,0
	GOTO LABEL_BV4_0
	BCF PORTA,0
	GOTO LABEL_BV4_0_END
LABEL_BV4_0
	BSF PORTA,0
LABEL_BV4_0_END
	BTFSC S3,1
	GOTO LABEL_BV4_1
	BCF S4,7
	GOTO LABEL_BV4_1_END
LABEL_BV4_1
	BSF S4,7
LABEL_BV4_1_END
	BTFSC S3,2
	GOTO LABEL_BV4_2
	BCF S5,0
	GOTO LABEL_BV4_2_END
LABEL_BV4_2
	BSF S5,0
LABEL_BV4_2_END
; Call subroutine TAB3
	MOVLW LOW TAB3
	MOVWF SYS_TMP1
	MOVLW HIGH TAB3
	MOVWF SYS_TMP2
	MOVFW ZV2
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S3
	BSF INTCON,GIE
; UND - Gatter -> LG3
LABEL_LG3_1
	BTFSS S5,0
	GOTO LABEL_LG3_FALSE
LABEL_LG3_2
	BTFSS S4,3
LABEL_LG3_TRUE
	BSF S5,1
	GOTO LABEL_LG3_ENDE
LABEL_LG3_FALSE
	BCF S5,1
LABEL_LG3_ENDE
; ODER - Gatter -> LG4
LABEL_LG4_1
	BTFSC S4,7
	GOTO LABEL_LG4_TRUE
LABEL_LG4_2
	BTFSC S5,1
	GOTO LABEL_LG4_TRUE
LABEL_LG4_FALSE
	BCF PORTA,1
	GOTO LABEL_LG4_ENDE
LABEL_LG4_TRUE
	BSF PORTA,1
LABEL_LG4_ENDE
; GND
	BCF S5,4	; immer Low
; RS-FLIP-FLOP -> RS1
	BTFSC S4,4
	GOTO LABEL_RS1_RESET
	BTFSS S6,1
	GOTO LABEL_RS1_ENDE
	BSF S5,7	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S5,7	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; RS-FLIP-FLOP -> RS2
	BTFSC S5,2
	GOTO LABEL_RS2_RESET
	BTFSS S6,6
	GOTO LABEL_RS2_ENDE
	BSF S5,5	; Ausgang setzen
	GOTO LABEL_RS2_ENDE
LABEL_RS2_RESET
	BCF S5,5	; Ausgang zurücksetzen
LABEL_RS2_ENDE
; UND - Gatter -> LG5
LABEL_LG5_1
	BTFSS S5,7
	GOTO LABEL_LG5_FALSE
LABEL_LG5_2
	BTFSS S6,0
LABEL_LG5_TRUE
	BSF S7,5
	GOTO LABEL_LG5_ENDE
LABEL_LG5_FALSE
	BCF S7,5
LABEL_LG5_ENDE
; UND - Gatter -> LG6
LABEL_LG6_1
	BTFSS S6,0
	GOTO LABEL_LG6_FALSE
LABEL_LG6_2
	BTFSS S5,5
LABEL_LG6_TRUE
	BSF S5,6
	GOTO LABEL_LG6_ENDE
LABEL_LG6_FALSE
	BCF S5,6
LABEL_LG6_ENDE
; ODER - Gatter -> LG7
LABEL_LG7_1
	BTFSC S6,3
	GOTO LABEL_LG7_TRUE
LABEL_LG7_2
	BTFSC S6,2
	GOTO LABEL_LG7_TRUE
LABEL_LG7_FALSE
	BCF S6,1
	GOTO LABEL_LG7_ENDE
LABEL_LG7_TRUE
	BSF S6,1
LABEL_LG7_ENDE
; One Shot -> OS1
	BTFSS S6,4
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S6,3
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S6,3
	BTFSC S6,4
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; VCC
	BSF S6,4	; immer High
; UND - Gatter -> LG8
LABEL_LG8_1
	BTFSS S4,5
	GOTO LABEL_LG8_FALSE
LABEL_LG8_2
	BTFSS S4,6
LABEL_LG8_TRUE
	BSF S6,5
	GOTO LABEL_LG8_ENDE
LABEL_LG8_FALSE
	BCF S6,5
LABEL_LG8_ENDE
; UND - Gatter -> LG9
LABEL_LG9_1
	BTFSS S5,3
	GOTO LABEL_LG9_FALSE
LABEL_LG9_2
	BTFSS S6,7
LABEL_LG9_TRUE
	BSF S7,0
	GOTO LABEL_LG9_ENDE
LABEL_LG9_FALSE
	BCF S7,0
LABEL_LG9_ENDE
; Zähler -> ZV3
	BTFSS S6,0	; Reset ?
	GOTO LABEL_ZV3_COUNT
	CLRF ZV3
	GOTO LABEL_ZV3_SETOUT
LABEL_ZV3_COUNT
	BTFSS S4,3
	GOTO LABEL_ZV3_SETFD
	BTFSC ZV3_FD,0
	BSF ZV3_FD,0
	BTFSC S7,1	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV3_BACKWARD
	INCF ZV3,F
LABEL_ZV3_BACKWARD
	DECF ZV3,F
LABEL_ZV3_SETOUT
LABEL_ZV3_SETFD
	BTFSC S4,3
	GOTO LABEL_ZV3_EXIT
	BCF ZV3_FD,0
LABEL_ZV3_EXIT
; GND
	BCF S7,1	; immer Low
; Vergleich -> IF1
	MOVLW 30
	SUBWF ZV3,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S6,0
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S6,0
LABEL_IF1_EXIT
; ODER - Gatter -> LG10
LABEL_LG10_1
	BTFSC S5,6
	GOTO LABEL_LG10_TRUE
LABEL_LG10_2
	BTFSC S7,3
LABEL_LG10_FALSE
	BCF S7,2
	GOTO LABEL_LG10_ENDE
LABEL_LG10_TRUE
	BSF S7,2
LABEL_LG10_ENDE
; One Shot -> OS2
	BTFSS S6,5
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S6,6
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S6,6
	BTFSC S6,5
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; One Shot -> OS3
	BTFSS S5,5
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S7,3
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S7,3
	BTFSC S5,5
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; One Shot -> OS4
	BTFSS S7,0
	GOTO LABEL_OS4_1
	BTFSC OS4_FD,0
	GOTO LABEL_OS4_1
	BSF OS4_FD,0
	BSF S6,2
	GOTO LABEL_OS4_2
LABEL_OS4_1
	BCF S6,2
	BTFSC S7,0
	GOTO LABEL_OS4_2
	BCF OS4_FD,0
LABEL_OS4_2
; ODER - Gatter -> LG11
LABEL_LG11_1
	BTFSC S7,5
	GOTO LABEL_LG11_TRUE
LABEL_LG11_2
	BTFSC S7,6
LABEL_LG11_FALSE
	BCF S7,4
	GOTO LABEL_LG11_ENDE
LABEL_LG11_TRUE
	BSF S7,4
LABEL_LG11_ENDE
; One Shot -> OS5
	BTFSS S5,7
	GOTO LABEL_OS5_1
	BTFSC OS5_FD,0
	GOTO LABEL_OS5_1
	BSF OS5_FD,0
	BSF S7,6
	GOTO LABEL_OS5_2
LABEL_OS5_1
	BCF S7,6
	BTFSC S5,7
	GOTO LABEL_OS5_2
	BCF OS5_FD,0
LABEL_OS5_2
	GOTO MAIN
; Table -> TAB
TAB
	RETLW 1	; // INDEX 0
	RETLW 3	; // INDEX 1
	RETLW 4	; // INDEX 2
	RETLW 2	; // INDEX 3
	RETLW 1	; // INDEX 4
	RETLW 3	; // INDEX 5
	RETLW 4	; // INDEX 6
	RETLW 2	; // INDEX 7
; Table -> TAB1
TAB1
	RETLW 1	; // INDEX 1
	RETLW 2	; // INDEX 2
	RETLW 4	; // INDEX 3
	RETLW 4	; // INDEX 4
	RETLW 5	; // INDEX 5
	RETLW 6	; // INDEX 6
	RETLW 7	; // INDEX 7
; Table -> TAB2
TAB2
; Table -> TAB3
TAB3
	END
