; Source created with Parsic Version 3.x
; at              : 2010.01.06. 19:43:25
; Project File    : C:\DOCUME~1\ALLUSE~1\ASZTAL\45pvissz.PIC
; Project Version : 1.0.0
; Created         : 2010.01.06. 18:40:00
; Last change     : 2010.01.06. 19:43:20
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV1	= 32	; located in Bank 0
ZV1_FD	= 33	; located in Bank 0
TR1	= 34	; located in Bank 0
TR1_HI	= 35	; located in Bank 0
S6	= 36	; located in Bank 0
OS1_FD	= 37	; located in Bank 0
S0	= 38	; located in Bank 0
ZV2	= 39	; located in Bank 0
ZV2_FD	= 40	; located in Bank 0
S1	= 41	; located in Bank 0
S2	= 42	; located in Bank 0
S3	= 43	; located in Bank 0
S4	= 44	; located in Bank 0
S5	= 45	; located in Bank 0
TR2	= 46	; located in Bank 0
TR2_HI	= 47	; located in Bank 0
S7	= 48	; located in Bank 0
OS2_FD	= 49	; located in Bank 0
MF1	= 50	; located in Bank 0
MF1_HI	= 51	; located in Bank 0
MF1_FD	= 52	; located in Bank 0
MF2	= 53	; located in Bank 0
MF2_HI	= 54	; located in Bank 0
MF2_FD	= 55	; located in Bank 0
OS3_FD	= 56	; located in Bank 0
RAM	= 57	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 115	; located in Bank 0, 1, 2, 3
SYS_TMP3	= 116	; located in Bank 0, 1, 2, 3
SYS_TMP4	= 117	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 118	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
	INCFSZ TR2,F
	GOTO SYS_INT_LABEL_1
	INCF TR2_HI,F
SYS_INT_LABEL_1
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_2
	INCF MF1_HI,F
SYS_INT_LABEL_2
	INCFSZ MF2,F
	GOTO SYS_INT_LABEL_3
	INCF MF2_HI,F
SYS_INT_LABEL_3
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Multiplication 8 - Bit
SYSMUL8
	CLRF SYS_TMP3
	MOVLW 8
	MOVWF SYS_TMP4
SYSMUL8_1
	MOVFW SYS_TMP1
	RRF SYS_TMP2,F
	BTFSC STATUS,CARRY
	ADDWF SYS_TMP3,F
	RLF SYS_TMP1,F
	DECFSZ SYS_TMP4,F
	GOTO SYSMUL8_1
	RETURN
; Division 8 - Bit
SYSDIV8
	MOVF SYS_TMP2,F
	BTFSC STATUS,ZERO
	GOTO SYSDIV8_ERROR
	CLRF SYS_TMP3	; Ergebnis löschen
	MOVLW 1
	MOVWF SYS_TMP4
SYSDIV8_0
	BTFSC SYS_TMP2,7	; OP2 linksbündig
	GOTO SYSDIV8_1
	INCF SYS_TMP4,F
	BCF STATUS,CARRY
	RLF SYS_TMP2,F
	GOTO SYSDIV8_0
SYSDIV8_1
	MOVFW SYS_TMP2	; vergleichen
	SUBWF SYS_TMP1,F	; F-W -> W
	BTFSC STATUS,CARRY
	GOTO SYSDIV8_2
	ADDWF SYS_TMP1,F	; F+W -> F
	BCF STATUS,CARRY
SYSDIV8_2
	RLF SYS_TMP3,F
	RRF SYS_TMP2,F
	DECFSZ SYS_TMP4,F
	GOTO SYSDIV8_1
	RETURN
SYSDIV8_ERROR
	MOVLW 255
	MOVWF SYS_TMP3
	RETURN
; Subroutines
; Direct jump into a table
SYSTABJMP
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO SYSTABJMP
	MOVFW SYS_TMP2
	MOVWF PCLATH
	MOVFW SYS_TMP1
	MOVWF PCL
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'00100000'
	MOVWF TRISA
	MOVLW B'00000000'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Zähler -> ZV1
	BTFSS S6,4	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S6,5
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S6,0	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S6,5
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Timer -> TR1
	MOVLW 0	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 8
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 8
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S6,2
	GOTO LABEL_TR1_CLR
	BSF S6,2
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S6,2
LABEL_TR1_ENDE
; GND
	BCF S6,0	; immer Low
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S6,3
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S6,2
LABEL_LG1_TRUE
	BSF S6,1
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF S6,1
LABEL_LG1_ENDE
; RS-FLIP-FLOP -> RS1
	BTFSC S6,4
	GOTO LABEL_RS1_RESET
	BTFSS S6,6
	GOTO LABEL_RS1_ENDE
	BSF S6,3	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF S6,3	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; One Shot -> OS1
	BTFSS PORTA,5
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S6,6
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S6,6
	BTFSC PORTA,5
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
;AF1
	MOVFW ZV1
	SUBLW 45	; L - W -> W
	MOVWF S0
LABEL_AF1_EXIT
; Zähler -> ZV2
	BTFSS S7,5	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S6,1
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S6,1
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Vergleich -> IF1
	MOVLW 60
	SUBWF ZV2,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S6,5
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S6,5
LABEL_IF1_EXIT
; Vergleich -> IF2
	MOVLW 45
	SUBWF ZV1,W	; F - W -> W
LABEL_IF2_CHECK
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S6,4
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S6,4
LABEL_IF2_EXIT
;AF2
	MOVFW S0
	MOVWF SYS_TMP1
	MOVLW 10
	MOVWF SYS_TMP2
	CALL SYSDIV8
	MOVFW SYS_TMP3
	MOVWF S1
LABEL_AF2_EXIT
;AF3
	MOVFW S1
	MOVWF SYS_TMP1
	MOVLW 10
	MOVWF SYS_TMP2
	CALL SYSMUL8
	MOVFW SYS_TMP3
	MOVWF S2
LABEL_AF3_EXIT
;AF4
	MOVFW S2
	SUBWF S0,W	; F - W -> W
	MOVWF S3
LABEL_AF4_EXIT
; Call subroutine RBPORT
	MOVLW LOW RBPORT
	MOVWF SYS_TMP1
	MOVLW HIGH RBPORT
	MOVWF SYS_TMP2
	MOVFW S1
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S4
	BSF INTCON,GIE
; Verteiler -> BV1
	BTFSC S4,0
	GOTO LABEL_BV1_0
	BCF PORTB,0
	GOTO LABEL_BV1_0_END
LABEL_BV1_0
	BSF PORTB,0
LABEL_BV1_0_END
	BTFSC S4,1
	GOTO LABEL_BV1_1
	BCF PORTB,1
	GOTO LABEL_BV1_1_END
LABEL_BV1_1
	BSF PORTB,1
LABEL_BV1_1_END
	BTFSC S4,2
	GOTO LABEL_BV1_2
	BCF PORTB,2
	GOTO LABEL_BV1_2_END
LABEL_BV1_2
	BSF PORTB,2
LABEL_BV1_2_END
	BTFSC S4,3
	GOTO LABEL_BV1_3
	BCF PORTB,3
	GOTO LABEL_BV1_3_END
LABEL_BV1_3
	BSF PORTB,3
LABEL_BV1_3_END
	BTFSC S4,4
	GOTO LABEL_BV1_4
	BCF PORTB,4
	GOTO LABEL_BV1_4_END
LABEL_BV1_4
	BSF PORTB,4
LABEL_BV1_4_END
	BTFSC S4,5
	GOTO LABEL_BV1_5
	BCF PORTB,5
	GOTO LABEL_BV1_5_END
LABEL_BV1_5
	BSF PORTB,5
LABEL_BV1_5_END
	BTFSC S4,6
	GOTO LABEL_BV1_6
	BCF PORTB,6
	GOTO LABEL_BV1_6_END
LABEL_BV1_6
	BSF PORTB,6
LABEL_BV1_6_END
; Call subroutine RAPORT
	MOVLW LOW RAPORT
	MOVWF SYS_TMP1
	MOVLW HIGH RAPORT
	MOVWF SYS_TMP2
	MOVFW S3
	ADDWF SYS_TMP1,F
	BTFSC STATUS,CARRY
	INCF SYS_TMP2,F
	CALL SYSTABJMP
	MOVWF S5
	BSF INTCON,GIE
; Verteiler -> BV2
	BTFSC S5,0
	GOTO LABEL_BV2_0
	BCF PORTA,0
	GOTO LABEL_BV2_0_END
LABEL_BV2_0
	BSF PORTA,0
LABEL_BV2_0_END
	BTFSC S5,1
	GOTO LABEL_BV2_1
	BCF PORTA,1
	GOTO LABEL_BV2_1_END
LABEL_BV2_1
	BSF PORTA,1
LABEL_BV2_1_END
	BTFSC S5,2
	GOTO LABEL_BV2_2
	BCF PORTA,2
	GOTO LABEL_BV2_2_END
LABEL_BV2_2
	BSF PORTA,2
LABEL_BV2_2_END
	BTFSC S5,3
	GOTO LABEL_BV2_3
	BCF PORTA,3
	GOTO LABEL_BV2_3_END
LABEL_BV2_3
	BSF PORTA,3
LABEL_BV2_3_END
	BTFSC S5,4
	GOTO LABEL_BV2_4
	BCF PORTA,4
	GOTO LABEL_BV2_4_END
LABEL_BV2_4
	BSF PORTA,4
LABEL_BV2_4_END
	BTFSC S5,5
	GOTO LABEL_BV2_5
	BCF PORTA,6
	GOTO LABEL_BV2_5_END
LABEL_BV2_5
	BSF PORTA,6
LABEL_BV2_5_END
	BTFSC S5,6
	GOTO LABEL_BV2_6
	BCF PORTA,7
	GOTO LABEL_BV2_6_END
LABEL_BV2_6
	BSF PORTA,7
LABEL_BV2_6_END
; UND - Gatter -> LG2
LABEL_LG2_1
	BTFSS S7,4
	GOTO LABEL_LG2_FALSE
LABEL_LG2_2
	BTFSS S6,7
LABEL_LG2_TRUE
	BSF PORTB,7
	GOTO LABEL_LG2_ENDE
LABEL_LG2_FALSE
	BCF PORTB,7
LABEL_LG2_ENDE
; Timer -> TR2
	SUBWF TR2_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR2_CHECK
	MOVLW 8
	SUBWF TR2,W	;F-W -> W
LABEL_TR2_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR2_ENDE
LABEL_TR2_RESET
	SUBWF TR2_HI,F	;F-W -> F
	MOVLW 8
	SUBWF TR2,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR2_HI,F
LABEL_TR2_SET	; toggel output
	BTFSC S6,7
	GOTO LABEL_TR2_CLR
	BSF S6,7
	GOTO LABEL_TR2_ENDE
LABEL_TR2_CLR
	BCF S6,7
LABEL_TR2_ENDE
; One Shot -> OS2
	BTFSC S6,3
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S7,0
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S7,0
	BTFSS S6,3
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; Mono-Flop -> MF1
; Läuft der Impuls ?
	BTFSC MF1_FD,1
	GOTO LABEL_MF1_CHKTIME
	BTFSC MF1_FD,0
	GOTO LABEL_MF1_SETFD
	BTFSS S7,0
LABEL_MF1_RESET
	CLRF MF1
	CLRF MF1_HI
	BSF MF1_FD,1
	BSF S7,1
LABEL_MF1_CHKTIME
	MOVLW 244
	SUBWF MF1_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF1_CHECK
	MOVLW 36
	SUBWF MF1,W
LABEL_MF1_CHECK
	BTFSS STATUS,CARRY
LABEL_MF1_TO
	BCF MF1_FD,1
	BCF S7,1
LABEL_MF1_SETFD
	BTFSS S7,0
	GOTO LABEL_MF1_CLR
	BSF MF1_FD,0
	GOTO LABEL_MF1_ENDE
LABEL_MF1_CLR
	BCF MF1_FD,0
LABEL_MF1_ENDE
; ODER - Gatter -> LG3
LABEL_LG3_1
	BTFSC S7,1
	GOTO LABEL_LG3_TRUE
LABEL_LG3_2
	BTFSC S7,2
	GOTO LABEL_LG3_TRUE
LABEL_LG3_FALSE
	BCF S7,4
	GOTO LABEL_LG3_ENDE
LABEL_LG3_TRUE
	BSF S7,4
LABEL_LG3_ENDE
; Mono-Flop -> MF2
	BTFSC MF2_FD,1
	GOTO LABEL_MF2_CHKTIME
	BTFSC MF2_FD,0
	GOTO LABEL_MF2_SETFD
	BTFSS S7,3
LABEL_MF2_RESET
	CLRF MF2
	CLRF MF2_HI
	BSF MF2_FD,1
	BSF S7,2
LABEL_MF2_CHKTIME
	MOVLW 244
	SUBWF MF2_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF2_CHECK
	MOVLW 36
	SUBWF MF2,W
LABEL_MF2_CHECK
	BTFSS STATUS,CARRY
LABEL_MF2_TO
	BCF MF2_FD,1
	BCF S7,2
LABEL_MF2_SETFD
	BTFSS S7,3
	GOTO LABEL_MF2_CLR
	BSF MF2_FD,0
	GOTO LABEL_MF2_ENDE
LABEL_MF2_CLR
	BCF MF2_FD,0
LABEL_MF2_ENDE
; One Shot -> OS3
	BTFSC S7,1
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S7,3
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S7,3
	BTFSS S7,1
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; ODER - Gatter -> LG4
LABEL_LG4_1
	BTFSC S6,4
	GOTO LABEL_LG4_TRUE
LABEL_LG4_2
	BTFSC S6,5
	GOTO LABEL_LG4_TRUE
LABEL_LG4_FALSE
	BCF S7,5
	GOTO LABEL_LG4_ENDE
LABEL_LG4_TRUE
	BSF S7,5
LABEL_LG4_ENDE
	GOTO MAIN
; Table -> RBPORT
RBPORT
	RETLW 63	; // INDEX 0
	RETLW 6	; // INDEX 1
	RETLW 91	; // INDEX 2
	RETLW 79	; // INDEX 3
	RETLW 102	; // INDEX 4
	RETLW 109	; // INDEX 5
	RETLW 125	; // INDEX 6
	RETLW 7	; // INDEX 7
	RETLW 127	; // INDEX 8
	RETLW 111	; // INDEX 9
	RETLW 63	; // INDEX 10
; Table -> RAPORT
RAPORT
	END
