; Source created with Parsic Version 3.x
; at              : 2010.01.13. 23:20:03
; Project File    : C:\DOCUME~1\ALLUSE~1\Asztal\ledvill.PIC
; Project Version : 1.0.0
; Created         : 2010.01.13. 23:12:00
; Last change     : 2010.01.13. 23:19:58
	PROCESSOR 16F628A
	INCLUDE P16F628A.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
TR1	= 32	; located in Bank 0
TR1_HI	= 33	; located in Bank 0
S0	= 34	; located in Bank 0
RAM	= 35	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000011'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 143
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111100'
	MOVWF TRISA
	MOVLW B'11111111'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 3	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 209
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 209
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S0,0
	GOTO LABEL_TR1_CLR
	BSF S0,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S0,0
LABEL_TR1_ENDE
; ODER - Gatter -> LG1
LABEL_LG1_1
	BTFSS S0,0
	GOTO LABEL_LG1_TRUE
LABEL_LG1_FALSE
	BSF PORTA,1
	GOTO LABEL_LG1_ENDE
LABEL_LG1_TRUE
	BCF PORTA,1
LABEL_LG1_ENDE
; ODER - Gatter -> LG2
LABEL_LG2_1
	BTFSC S0,0
	GOTO LABEL_LG2_TRUE
LABEL_LG2_FALSE
	BSF PORTA,0
	GOTO LABEL_LG2_ENDE
LABEL_LG2_TRUE
	BCF PORTA,0
LABEL_LG2_ENDE
	GOTO MAIN
	END
