; Source created with Parsic Version 3.x
; at              : 2010.01.23. 8:38:35
; Project File    : C:\Krisztián bigyói\PIC\Parsic\Parsic_3.4.3.w.CR\1500.PIC
; Project Version : 1.0.2
; Created         : 2010.01.16. 21:01:00
; Last change     : 2010.01.23. 7:58:00
	PROCESSOR 12F675
	INCLUDE P12F675.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
TR1	= 32	; located in Bank 0
TR1_HI	= 33	; located in Bank 0
GP	= 34	; located in Bank 0
ZV1	= 35	; located in Bank 0
ZV1_FD	= 36	; located in Bank 0
S0	= 37	; located in Bank 0
ZV2	= 38	; located in Bank 0
ZV2_FD	= 39	; located in Bank 0
MF1	= 40	; located in Bank 0
MF1_HI	= 41	; located in Bank 0
MF1_FD	= 42	; located in Bank 0
RAM	= 43	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1
SYS_SSAV	= 113	; located in Bank 0, 1
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	GOTO SYS_INIT
	NOP
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_1
	INCF MF1_HI,F
SYS_INT_LABEL_1
EXITINT
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	BSF STATUS,RP0	; Bank 1
	CALL 1023
	MOVWF OSCCAL
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF GPIO
	MOVLW 15
	MOVWF OPTION_REG
	MOVLW 7	; all digital
	MOVWF CMCON
; Richtung setzen
	MOVLW B'11111001'
	MOVWF TRISIO
; init vars
; Clear RAM
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'C0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 7	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 161
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 161
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC GPIO,1
	GOTO LABEL_TR1_CLR
	BSF GPIO,1
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF GPIO,1
LABEL_TR1_ENDE
; Zähler -> ZV1
	BTFSS S0,0	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS GPIO,1
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S0,2	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCF ZV1,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC GPIO,1
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; Vergleich -> IF1
	MOVLW 60
	SUBWF ZV1,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S0,0
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S0,0
LABEL_IF1_EXIT
; Zähler -> ZV2
	BTFSS S0,1	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S0,0
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	GOTO LABEL_ZV2_BACKWARD
	INCF ZV2,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S0,0
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; Vergleich -> IF2
	MOVLW 1460
	SUBWF ZV2,W	; F - W -> W
LABEL_IF2_CHECK
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S0,1
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S0,1
LABEL_IF2_EXIT
; GND
	BCF S0,2	; immer Low
; Mono-Flop -> MF1
	BTFSC MF1_FD,0
	GOTO LABEL_MF1_CHKTIME
	BTFSS S0,1
LABEL_MF1_RESET
	CLRF MF1
	CLRF MF1_HI
	BSF MF1_FD,1
	BSF GPIO,2
LABEL_MF1_CHKTIME
; Läuft der Impuls ?
	BTFSS MF1_FD,1
	GOTO LABEL_MF1_SETFD
	MOVLW 152
	SUBWF MF1_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF1_CHECK
	MOVLW 150
	SUBWF MF1,W
LABEL_MF1_CHECK
	BTFSS STATUS,CARRY
LABEL_MF1_TO
	BCF MF1_FD,1
	BCF GPIO,2
LABEL_MF1_SETFD
	BTFSS S0,1
	GOTO LABEL_MF1_CLR
	BSF MF1_FD,0
	GOTO LABEL_MF1_ENDE
LABEL_MF1_CLR
	BCF MF1_FD,0
LABEL_MF1_ENDE
	GOTO MAIN
	ORG 1023
	RETLW H'00'	; OSCCAL
	END
