PCB Developer's Individual Assistant V2.2       Copyright  by Andreas Waldherr 1994-1998
Hardware Requirements
 80386 or better
 4 MB RAM
 10 MB disk space
 WIN 3.1 or later
Installation (Win 3.1):
 Activate the Program Manager
 Select Run from the File menu
 Enter A:SETUP.EXE        (if the files are on floppy drive A: )
 Press Return
Installation (Win 95):
 Select Run from the Start menu
 Press Return
KNOWN PROBLEMS
Problem: The setup program is not able to create the directory sometimes. This happens if your
	path contains more than one new sub-directory (e.g. the path Program\PCB\V22 will work
	if Program\PCB already extists, but it will not work if only Program\ exists).
Solution: Create the directory manually.
