// Flex_LCD420.c
// These pins are for my Microchip PicDem2-Plus board,
// which I used to test this driver.
// An external 20x4 LCD is connected to these pins.
// Change these pins to match your own board's connections.
#define LCD_DB4   PIN_D4
#define LCD_DB5   PIN_D5
#define LCD_DB6   PIN_D6
#define LCD_DB7   PIN_D7
#define LCD_RS    PIN_E0
#define LCD_RW    PIN_E1
#define LCD_E     PIN_E2
// To prove that the driver can be used with random
// pins, I also tested it with these pins:
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_C5
#define LCD_DB7   PIN_B5
#define LCD_RS    PIN_E2
#define LCD_RW    PIN_B2
#define LCD_E     PIN_D6
// If you want only a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.  Doing so will save one PIC
// pin, but at the cost of losing the ability to read from
// the LCD.  It also makes the write time a little longer
// because a static delay must be used, instead of polling
// the LCD's busy bit.  Normally a 6-pin interface is only
// used if you are running out of PIC pins, and you need
// to use as few as possible for the LCD.
#define USE_RW_PIN   1     
// These are the line addresses for most 4x20 LCDs.
#define LCD_LINE_1_ADDRESS 0x00
#define LCD_LINE_2_ADDRESS 0x40
#define LCD_LINE_3_ADDRESS 0x14
#define LCD_LINE_4_ADDRESS 0x54
// These are the line addresses for LCD's which use
// the Hitachi HD66712U controller chip.
#define LCD_LINE_2_ADDRESS 0x20
#define LCD_LINE_3_ADDRESS 0x40
#define LCD_LINE_4_ADDRESS 0x60
#define lcd_type 2   // 0=5x7, 1=5x10, 2=2 lines(or more)
int8 lcd_line;
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2),  // Set mode: 4-bit, 2+ lines, 5x8 dots
 0xc,                     // Display on
 1,                       // Clear display
 6                        // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2)); 
 output_bit(LCD_DB6, !!(nibble & 4));   
 output_bit(LCD_DB7, !!(nibble & 8));   
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.     
#ifdef USE_RW_PIN
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_us(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
delay_us(1);
return(retval);   
#endif
// Read a byte from the LCD and return it.
#ifdef USE_RW_PIN
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_RW_PIN
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60); 
#endif
if(address)
   output_high(LCD_RS);
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_RW_PIN
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
lcd_line = 1;
output_low(LCD_RS);
#ifdef USE_RW_PIN
output_low(LCD_RW);
#endif
output_low(LCD_E);
// Some LCDs require 15 ms minimum delay after
// power-up.  Others require 30 ms.  I'm going
// to set it to 35 ms, so it should work with
// all of them.
delay_ms(35);         
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 50 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_RW_PIN
    delay_ms(5);
    #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
switch(y)
   case 1:
     address = LCD_LINE_1_ADDRESS;
     break;
   case 2:
     address = LCD_LINE_2_ADDRESS;
     break;
   case 3:
     address = LCD_LINE_3_ADDRESS;
     break;
   case 4:
     address = LCD_LINE_4_ADDRESS;
     break;
   default:
     break;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      lcd_line = 1;
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1, ++lcd_line);
       break;
    case '\b':
       lcd_send_byte(0,0x10);
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_RW_PIN
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7)); 
value = lcd_read_byte();
output_low(LCD_RS);
return(value);
#endif
