This is a demo website that is being served by a simple HTTP server part of the Microchip TCP/IP Stack running on an 8 or 16-bit Microchip microcontroller.
The Microchip TCP/IP Stack supports different configurations and ethernet controllers such as the Microchip ENC28J60, the Realtek RTL8019 and the new PIC18F97J60 family of 8-bit microcontrollers with integrated ethernet interface.
The Links page includes several links to additional information and reference designs using the Microchip TCP/IP Stack.
The right section of this page demonstrates the ability to handle real-time control functions and how to generate pages with dynamic contents. The Status section refreshes with board information periodically using JavaScript showing the current status of several variables, and the Actions section sends commands like changing the status of particular I/O ports.
If available you can push the on-board switch(es) or change the voltage on the analog inputs and see the new data updated on this page. You can also click on one of the two LED command buttons to toggle the on-board LEDs.
If your browser does not support AJAX, you can check a static version of this page here.
For more information about how to put together a simple hardware design to run the Microchip TCP/IP Stack and for products and tools available for developing applications like this one, visit the LJCV Electronics Projects Page.
Version: Unknown Build date: Unknown
