# Name: Makefile
# Project: PowerSwitch
# Author: Christian Starkjohann
# Creation Date: 2004-12-29
# Tabsize: 4
# Copyright: (c) 2005 by OBJECTIVE DEVELOPMENT Software GmbH
# License: GNU GPL v2 (see License.txt) or proprietary (CommercialLicense.txt)
# This Revision: $Id: Makefile 277 2007-03-20 10:53:33Z cs $
DEVICE = atmega8
#at90s2313
AVRDUDE = avrdude -c stk500v2 -P avrdoper -p $(DEVICE)
# Choose your favorite programmer and interface above.
COMPILE = avr-gcc -Wall -Os -Iusbdrv -I. -mmcu=$(DEVICE) #-DDEBUG_LEVEL=2
# NEVER compile the final product with debugging! Any debug output will
# distort timing so that the specs can't be met.
OBJECTS = usbdrv/usbdrv.o usbdrv/usbdrvasm.o usbdrv/oddebug.o main.o
# symbolic targets:
all:	main.hex
.c.o:
	$(COMPILE) -c $< -o $@
.S.o:
	$(COMPILE) -x assembler-with-cpp -c $< -o $@
# "-x assembler-with-cpp" should not be necessary since this is the default
# file type for the .S (with capital S) extension. However, upper case
# characters are not always preserved on Windows. To ensure WinAVR
# compatibility define the file type manually.
.c.s:
	$(COMPILE) -S $< -o $@
flash:	all
	$(AVRDUDE) -U flash:w:main.hex:i
# Fuse low byte:
# 0xef = 1 1 1 0   1 1 1 1
#        | |  |       +------- CKSEL 3..0 (clock selection -> crystal @ 12 MHz)
#        | |  +--------------- SUT 1..0 (BOD enabled, fast rising power)
#        | +------------------ CKOUT (clock output on CKOUT pin -> disabled)
#        +-------------------- CKDIV8 (divide clock by 8 -> don't divide)
# Fuse high byte:
# 0xdb = 1 1 0 1   1 0 1 1
#        | | | |     |   +---- RSTDISBL (disable external reset -> enabled)
#        | | | |     +-------- BODLEVEL 2..0 (brownout trigger level -> 2.7V)
#        | | | +-------------- WDTON (watchdog timer always on -> disable)
#        | | +---------------- SPIEN (enable serial programming -> enabled)
#        | +------------------ EESAVE (preserve EEPROM on Chip Erase -> not preserved)
#        +-------------------- DWEN (debug wire enable)
fuse_tiny2313:	# only needed for attiny2313
	$(AVRDUDE) -U hfuse:w:0xdb:m -U lfuse:w:0xef:m
clean:
	rm -f main.hex main.lst main.obj main.cof main.list main.map main.eep.hex main.bin *.o usbdrv/*.o main.s usbdrv/oddebug.s usbdrv/usbdrv.s
# file targets:
main.bin:	$(OBJECTS)
	$(COMPILE) -o main.bin $(OBJECTS)
main.hex:	main.bin
	rm -f main.hex main.eep.hex
	avr-objcopy -j .text -j .data -O ihex main.bin main.hex
	./checksize main.bin
# do the checksize script as our last action to allow successful compilation
# on Windows with WinAVR where the Unix commands will fail.
disasm:	main.bin
	avr-objdump -d main.bin
cpp:
	$(COMPILE) -E main.c
