Driver for Fujitsu Siemens Computers USB-Smartcard-Readers:
Operating System:
- MS Windows 98
- MS Windows 98SE
- MS Windows ME
- MS Windows 2000
- MS Windows XP
Driver-Version:
- 3.7.1.1
Changes made compared with version 3.6.0.2:
- Minimal binary changes to enable driver to handle larger certificates.
Supported Devices:
- S26381-D310-V1: 	SCR internal USB for FSC PC (same size like D109)
- S26381-K319-Lxxx: 	Keyboard KBPC-C2 (Smarcard righthand)
- S26381-K320-Lxxx: 	Keyboard KBPC-CID (Smartcard + Biometrics)
- S26381-D313-v1: 	SCR internal USB for FSC PC (small Version of D310)
- S26381-K322-V1:       SCR USB Solo: External USB Smartcardreader
Files:
- cmeu0wdm.cat		19.03.2002 04:57
- cmeu0wdm.inf		12.03.2002 11:00
- cmeu0wdm.sys		18.09.2001 20:12
- launchn.dll		24.08.2001 19:01
- scbase.exe		24.08.2001 19:01
- smclib.exe		24.08.2001 19:01
- readme.txt		this file
Driver Installation Guide:
General:
Drivers consist of a *.sys, *.vxd and a *.inf file. Drivers for Win98/Me/2000
have an additional *.cat file, which is the digital signature for the driver
package. If this is correctly signed, the Operation System Wizard forces the
installation, if not a warning-message occurs. You can ignore the message but
you should not.
Install:
Normaly the Operating System recognizes new hardware and starts the hardware
installation wizard. Follow the procedure. If you get asked for the driver
location choose the folder where you have stored them (mostly the driver-cd)
If you have problems with starting the wizard click on the new *.inf file using
the right (!) mouse button. Then choose option "Install".
Re-boot after installation.
Uninstall:
To uninstall the driver go to the Control Panel (under "Settings" on the Start
menu) and start the "Add/Remove Hardware" applet. The "Add/Remove Hardware
Wizard" will be started and will guide you through the uninstall procedure.
If you get asked for the device you want to uninstall, select "Fujitsu Siemens
 Serial Smart Card Reader" or any other Hardware-Device you want to remove
from the list of programs displayed in the scroll box.
Windows NT 4.0 Support:
For Projects, there is a Windows NT 4.0 driver available!
Please contact: security-solutions@fujitsu-siemens.com
Augsburg, 20.06.2002
