<AVRStudio><MANAGEMENT><ProjectName>16x2_LCD_GRAF</ProjectName><Created>19-Mar-2010 00:49:34</Created><LastEdit>21-Mar-2010 02:02:35</LastEdit><ICON>241</ICON><ProjectType>0</ProjectType><Created>19-Mar-2010 00:49:34</Created><Version>4</Version><Build>4, 17, 0, 655</Build><ProjectTypeName>AVR GCC</ProjectTypeName></MANAGEMENT><CODE_CREATION><ObjectFile>default\16x2_LCD_GRAF.elf</ObjectFile><EntryFile></EntryFile><SaveFolder>D:\AVR_STUDIO\</SaveFolder></CODE_CREATION><DEBUG_TARGET><CURRENT_TARGET>AVR Simulator</CURRENT_TARGET><CURRENT_PART>ATmega16.xml</CURRENT_PART><BREAKPOINTS></BREAKPOINTS><IO_EXPAND><HIDE>false</HIDE></IO_EXPAND><REGISTERNAMES><Register>R00</Register><Register>R01</Register><Register>R02</Register><Register>R03</Register><Register>R04</Register><Register>R05</Register><Register>R06</Register><Register>R07</Register><Register>R08</Register><Register>R09</Register><Register>R10</Register><Register>R11</Register><Register>R12</Register><Register>R13</Register><Register>R14</Register><Register>R15</Register><Register>R16</Register><Register>R17</Register><Register>R18</Register><Register>R19</Register><Register>R20</Register><Register>R21</Register><Register>R22</Register><Register>R23</Register><Register>R24</Register><Register>R25</Register><Register>R26</Register><Register>R27</Register><Register>R28</Register><Register>R29</Register><Register>R30</Register><Register>R31</Register></REGISTERNAMES><COM>Auto</COM><COMType>0</COMType><WATCHNUM>0</WATCHNUM><WATCHNAMES><Pane0></Pane0><Pane1></Pane1><Pane2></Pane2><Pane3></Pane3></WATCHNAMES><BreakOnTrcaeFull>0</BreakOnTrcaeFull></DEBUG_TARGET><Debugger><modules><module></module></modules><Triggers></Triggers></Debugger><AVRGCCPLUGIN><FILES><SOURCEFILE>16x2_LCD_GRAF.c</SOURCEFILE><OTHERFILE>default\16x2_LCD_GRAF.lss</OTHERFILE><OTHERFILE>default\16x2_LCD_GRAF.map</OTHERFILE></FILES><CONFIGS><CONFIG><NAME>default</NAME><USESEXTERNALMAKEFILE>NO</USESEXTERNALMAKEFILE><EXTERNALMAKEFILE></EXTERNALMAKEFILE><PART>atmega16</PART><HEX>1</HEX><LIST>1</LIST><MAP>1</MAP><OUTPUTFILENAME>16x2_LCD_GRAF.elf</OUTPUTFILENAME><OUTPUTDIR>default\</OUTPUTDIR><ISDIRTY>1</ISDIRTY><OPTIONS/><INCDIRS/><LIBDIRS/><LIBS/><LINKOBJECTS/><OPTIONSFORALL>-Wall -gdwarf-2 -Os -std=gnu99 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums</OPTIONSFORALL><LINKEROPTIONS></LINKEROPTIONS><SEGMENTS/></CONFIG></CONFIGS><LASTCONFIG>default</LASTCONFIG><USES_WINAVR>1</USES_WINAVR><GCC_LOC>C:\WinAVR-20090313\bin\avr-gcc.exe</GCC_LOC><MAKE_LOC>C:\WinAVR-20090313\utils\bin\make.exe</MAKE_LOC></AVRGCCPLUGIN><IOView><usergroups/><sort sorted="0" column="0" ordername="1" orderaddress="1" ordergroup="1"/></IOView><Files><File00000><FileId>00000</FileId><FileName>16x2_LCD_GRAF.c</FileName><Status>259</Status></File00000><File00001><FileId>00001</FileId><FileName>D:\-=Programozás_programok=-\-=AVR_C=-\lfutofeny_odavisza_kesleltetessel.c</FileName><Status>1</Status></File00001></Files><Events><Bookmarks></Bookmarks></Events><Trace><Filters></Filters></Trace></AVRStudio>
