;   This file is a basic code template for assembly code generation   *
;   on the PIC16F690. This file contains the basic code               *
;   building blocks to build upon.                                    *  
;   Refer to the MPASM User's Guide for additional information on     *
;   features of the assembler (Document DS33014).                     *
;   Refer to the respective PIC data sheet for additional             *
;   information on the instruction set.                               *
;    Filename:	    xxx.asm                                           *
;    Date:                                                            *
;    File Version:                                                    *
;    Author:                                                          *
;    Company:                                                         *
;    Files Required: P16F690.INC                                      *
;    Notes:                                                           *
	list		p=16f690		; list directive to define processor
	#include	<P16F690.inc>		; processor specific variable definitions
	__CONFIG    _CP_OFF & _CPD_OFF & _BOR_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _MCLRE_ON & _FCMEN_OFF & _IESO_OFF
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS
w_temp		EQU	0x7D			; variable used for context saving
status_temp	EQU	0x7E			; variable used for context saving
pclath_temp	EQU	0x7F			; variable used for context saving
	ORG		0x000			; processor reset vector
  	goto		main			; go to beginning of program
	ORG		0x004			; interrupt vector location
isr
	movwf		w_temp			; save off current W register contents
	movf		STATUS,w		; move status register into W register
	movwf		status_temp		; save off contents of STATUS register
	movf		PCLATH,w		; move pclath register into W register
	movwf		pclath_temp		; save off contents of PCLATH register
	banksel		INTCON
	btfsc		INTCON,T0IE
	btfss		INTCON,T0IF
	goto		isr_restore
T0_int
	movlw		0x10
	addwf		PORTB,f	
; isr code can go here or be located as a call subroutine elsewhere
isr_restore
	movf		pclath_temp,w		; retrieve copy of PCLATH register
	movwf		PCLATH			; restore pre-isr PCLATH register contents	
	movf		status_temp,w		; retrieve copy of STATUS register
	movwf		STATUS			; restore pre-isr STATUS register contents
	swapf		w_temp,f
	swapf		w_temp,w		; restore pre-isr W register contents
	retfie					; return from interrupt
main
; remaining code goes here
	banksel		ANSEL
	clrf		ANSEL
	clrf		ANSELH
	banksel		OPTION_REG
	bcf			OPTION_REG,T0CS
	clrf		TRISB
	banksel		INTCON
	bsf			INTCON,T0IE
	bsf			INTCON,GIE
	clrf		PORTB
mainloop
	goto		mainloop
	ORG	0x2100				; data EEPROM location
	DE	1,2,3,4				; define first four EEPROM locations as 1, 2, 3, and 4
	END                       ; directive 'end of program'
