This file documents changes in the firmware-only CDC driver for atmel's AVR
microcontrollers. New entries are always appended to the end of the file.
Scroll down to the bottom to see the most recent changes.
* Release 2006-06-28
  - Polling instead of using interrupt at UART processing (ATmega).
  - Adapted to higher baud rate setting (ATmega).
  - Reduced interrupt cycles in software UART (ATtiny).
  - Removed zero-sized receive block in usbFunctionWriteOut().
* Release 2006-07-18
  - Added Rx_interrupt version for high speed transfer (ATmega).
  - Changed maximum packet size to 6 for stable connection (ATmega).
  - Configured USI to transmit data (ATtiny).
  - Added test report.
* Release 2006-08-28
  - Adapted for new AVR-USB and WinAVR20070122.
  - Modified to use maximum BULK_IN packet size in main.c.
* Release 2007-04-07
  - Adapted for new AVR-USB and WinAVR20070525.
  - Shortened the polling interval of interrupt endpoint to 2mS.
  - Avoided duplicate response at SET_CONTROL_LINE_STATE request.
  - Sent zero sized packet on bulk-in endpoint after SETUP request.
  - Enforce data toggling to DATA0 on interrupt and bulk-in endpoints after
   usbInit().
* Release 2007-07-07
  - Released ATtiny2313 version.
* Release 2007-10-03
  - Fixed bug on ATtiny inverted version. (Thanks to Klaus Weglehner)
  - Updated to the newest AVR-USB.
* Release 2008-01-27
  - Updated to the newest AVR-USB and enabled other clocks.
  - Defined all configuration options into Makefile.
  - Extended the interrupt polling interval.
* Release 2008-08-25
  - Expanded the bulk-IN packet size to 8 bytes. (ATtiny2313)
  - Remade the data buffering to achieve the higher baudrates. (ATtiny2313)
  - Implemented three baudrates using port bits selection. (ATtiny2313)
* Release 2009-01-26
  - Corrected ATmega8 fuse bit(CKOPT=0). (Thanks to Rene Staffen)
  - Merged all AVR versions to one.
* Release 2009-07-20
