; last change 30.06.2007
; uses:
; IICOUNT, IITEMP as 8-Bit variable
; II2 Bus
; SDA and SCL have open-collector functions
; use external pull-up resistors
; Subroutines for setting SDA & SCL
; high-level = pin is input
; low-level  = pin is output and low
SCLHigh
	banksel trisa   ; bank 1
	bsf scl         ; input
	banksel porta
SCLHigh2
	btfss scl       ; wait until SCL is high
	goto SCLHigh2
	goto iidelay
SCLLow
	banksel porta
	bcf scl
	banksel trisa
	bcf scl         ; output
	goto iidelay
SDAHigh
	banksel trisa
	bsf sda         ; input
	goto iidelay
SDALow
	banksel porta
	bcf sda
	banksel trisa
	bcf sda         ; output
szenz
	movlw	0
	banksel	m0
	btfsc	m0,2
	movlw	1
	banksel	iislaveadr
	movwf	iislaveadr
;********** II2 Delay ***********
IIDelay
	clrwdt
	return
;********* II2 Start ************
IISTART
	call SDAHigh    ; SDA & SCL high
	call SCLHigh
	call SDALow     ; SDA Low = start
	call SCLLow     ; SCL Low
	call szenz	; szenzor valasztas	
	return
;******* II2 Stop ***************
IISTOP
	call SDALow     ; SDA low
	call SCLHigh    ; SCL high
	call SDAHigh    ; SDA high = stop
	return
;******* II2 NAK ****************
; send NAK
IINAK
	call SDAHigh    ; SDA high = input
	goto IIACK2
;******* II2 ACK ****************
; send ACK
IIACK
IIACK2
	call SCLLow     ; SCL low
	return
; IISend
; sends 1 byte in W-register over the bus and checks ACK
; Input  = W-Register
; Output = Carry, 0 = ACK, 1 = NAK
IISend
	banksel IITEMP    ; store w
	movwf IITEMP
	movlw 8         ; set loop counter
	banksel IICOUNT
	movwf IICOUNT
iis1
	banksel IITEMP
	rlf IITEMP,f      ; next bit
	btfss status,carry
	call SDALow
	btfsc status,carry
	call SDAHigh
	call SCLHigh    ; Clock High
	call SCLLow     ; Clock Low
	banksel IICOUNT
	decfsz IICOUNT,f    ; -1
	goto iis1
; read ACK
	call SDAHigh    ; High = input
	bcf status,carry ; ACK
	banksel porta
	btfsc sda        ; if not low 
	bsf status,carry ; NAK
	return
; IIRec
; reads 1 byte from bus into iidat
; Input  = none
; Output = W-Register and IITEMP
IIRec
	movlw 8          ; loop counter
	banksel IICOUNT
	movwf IICOUNT
	call SDAHigh     ; input
iir1
	bcf status,carry
	banksel porta
	btfsc sda
	bsf status,carry
	banksel IITEMP    ; shift into iidata
	rlf IITEMP,f
iir2
	banksel IICOUNT
	decfsz IICOUNT,f
	goto iir1
	banksel IITEMP   ; load data
	movfw IITEMP
	return
