//#include <16F884.h>
#include <16F887.h>
#device adc=8
#FUSES NOWDT                      //Watch Dog Timer
#FUSES XT                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOCPD                    //No EE protection
#FUSES NOBROWNOUT               //No brownout reset
#FUSES IESO                     //Internal External Switch Over mode enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOWRT                    //Program memory not write protected
#FUSES BORV40                   //Brownout reset at 4.0V
#use delay(clock=4000000)
#define NIRQ   PIN_C0
#define NSEL   PIN_C1
#define SCK   PIN_C3
#define SDO   PIN_C5
#define SDI   PIN_C4
//#use spi(DI=PIN_B1, DO=PIN_B0, CLK=PIN_B2, ENABLE=PIN_B4, BITS=16)
//#use spi(MASTER,BAUD=9600,DI=SDI, DO=SDO, CLK=SCK,  BITS=16)
