;	iic lcd driver: PCF2103
;	standard crystal 4.194 MHz XT
     LIST P=16F628;f=inhx8m
        #include "P16F628.INC"
	__CONFIG	_PWRTE_ON  & _WDT_OFF & _XT_OSC & _BODEN_OFF & _LVP_OFF & _CP_OFF & _MCLRE_ON
	cblock 0x20
	 count1,count2,count3
	 dig1,dig2,dig3
	 transo,ratb,semn
	endc
#DEFINE sclk	PORTA,0
#DEFINE sdta	PORTA,1
#DEFINE osc	PORTA,2
#DEFINE grad	PORTA,3
;      cpu init
 	org	0x00
	goto	init
	org	0x04
	goto	init
init	call	usaex
	call	usbex
	movlw	7
	movwf	CMCON
	movlw	0x00
	movwf	PORTA
	movwf	PORTB	
	clrf	semn
;* Lcd init commands                               *
lcd_ini
	call	iict	; i2c start
	movlw	0x74	; device write address (75h for read)
	call	act	; i2c send subroutine
	movlw	0x00	; Co,RS=0, set instruction register for multiple next command bytes  
	call	act
	movlw	0x31	; extended instruction set
	call	act
	movlw	0x02	; set screen configuration left to right 
	call	act
	movlw	0x05	; set display configuration 
	call	act
	movlw	0x08	; set icon mode, full mode, icon blink disable
	call	act
	movlw	0x30	; normal instruction set
	call	act
	movlw	0x0C	; set display on
	call	act
	movlw	0x06	; set cursor move direction
	call	act
	movlw	0x02	; set DDRAM address 0 in address counter
	call	act
	call	iicp	; i2c stop 
;* Lcd icon sets off                               *
	call	iict
	movlw	0x74
	call	act
	movlw	0x80	; Co=1, RS=0 just one next command byte
	call	act
	movlw	0x4C	; set CGRAM for icons
	call	act
	movlw	0x40	; Co=0, RS=1, set instruction register for multiple next data bytes  
	call	act
	movlw	0x00	; erase icons sequence
	call	act
	movlw	0x18
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x00
	call	act
	movlw	0x0F
	call	act
	movlw	0x10
	call	act
;* Lcd cursor subroutine                           *
	call	iict
	movlw	0x74
	call	act
	movlw	0x00
	call	act
	movlw	0x30
	call	act
	movlw	0x01	; clears entire display and sets DDRAM address to 0 in address counter
	call	act
	movlw	0x0C	; display on, cursor off, cursor blink off
	call	act
	call	iicp
;* Lcd data subroutine                             *
nou	call	iict
	movlw	0x74
	call	act
	call	act
	movlw	0x8C	; set CGRAM for characters
	call	act
	call	act
	movlw	0xD4	; T
	call	act
	movlw	0xE5	; e
	call	act
	movlw	0xED	; m
	call	act
	movlw	0xF0	; p
	call	act
	movlw	0xBA	; :
	call	act
	movlw	0xAB	;
	btfsc	semn,0
	addlw	0x02  
	call	act
scrie	call	rset
	movlw	0xCC	;skip rom
	call	schtx
	movlw	0x44	;convert
	call	schtx
	call	halta
	call	rset
	call	schtx
	movlw	0xBE	;read scratchpad
	call	schtx
	call	schrx
	call	mux
	movf	dig2,0
	addlw	0xB0
	call	act
	movf	dig1,0
	addlw	0xB0
	call	act
	movlw	0xAC
	call	act
	movf	dig3,0
	addlw	0xB0
	call	act
	movlw	0x20	;  
	call	act
	movlw	0xC3	;  
	call	act
	call	iicp
	goto	nou
rset	bcf	grad
	call	halte	; 510 us
	bsf	grad
	call	usain
	call	haltd	; 61 us
	btfsc	grad	
	bsf	PORTB,0
	btfss	grad
	bcf	PORTB,0
	call	halte	; 510us
	call	usaex
	retlw	00
schtx	movwf	ratb	; 
	movlw	0x08
	movwf	count3
gbit	btfsc	ratb,0	; data reverse flow	
	call	unu
	btfss	ratb,0
	call	nul
	rrf	ratb,F
	decfsz	count3,F
	goto	gbit
	retlw	00
schrx	movlw	0x08
	movwf	count3
samp	rrf	ratb,F
	bcf	grad
	call	usain
	call	haltcc	; 11us
	btfsc	grad	; data reverse flow	
	bsf	ratb,7
	btfss	grad
	bcf	ratb,7
	call	haltd	; 61 us
	call	usaex
	decfsz	count3,F
	goto	samp
	bcf	grad
	call	usain
	call	haltc	; 11us
	btfsc	grad	; data bit flow	
	bsf	semn,0
	btfss	grad
	bcf	semn,0
	call	haltd	; 61 us
	call	usaex
	btfsc	semn,0
	call	negativ
	movlw	0x00
	btfsc	ratb,0
	addlw	0x05
	movwf	dig3
	rrf	ratb,0
	andlw	0x7F
	movwf	ratb	
	return
negativ	movf	ratb,0
	xorlw	0xFF
	addlw	0x01
	movwf	ratb
	return
unu	bcf	grad
	call	haltc	; 11 us
	bsf	grad
	call	haltd	; 65 us
 	retlw	00
nul	bcf	grad
	call	haltc	; 11 us
	call	haltd	; 65 us
	bsf	grad
 	retlw	00
act	movwf	transo	; iic data transmission 
	movlw	0x08
	movwf	count3
vbit	bcf	sclk
	call	haltb
	btfsc	transo,7	
	bsf	sdta
	btfss	transo,7
	bcf	sdta
	call	haltb
	bsf	sclk
	call	haltb
	bcf	sclk
	call	haltb
	rlf	transo,F
	decfsz	count3,F
	goto	vbit
	call	ackp
	retlw	00
iicp	bcf	sdta	; stop condition module
	call	haltb
	bsf	sclk
	call	haltb
	bsf	sdta	; stop command
	call	haltb
	bcf	sclk
	call	haltb
	retlw	00
iict	bsf	sdta	; start condition module 
	bsf	sclk
	call	haltb
	bcf	sdta	; start command
	call	haltb
	bcf	sclk
	call	haltb
	retlw	00
ackp	bsf	sclk	; one clock step for acknowledge (not read)
	call	haltb
	bcf	sclk
	call	haltb
	retlw	00
halta	movlw	0x90	; cca. 800ms delay
	movwf	count3
r3	movlw	0xFF	
	movwf	count2
r2	call	pwmm
	decfsz	count2,F    
	goto 	r2   
	decfsz	count3,F    
	goto 	r3          
	retlw	00
haltb	movlw	0x10	
	movwf	count2
d1	call	pwmm
	decfsz	count2,F	
	goto 	d1		
 	retlw	00
haltc	movlw	0x02	;	11us	
	movwf	count1
w1	decfsz	count1,F	
	goto 	w1
	retlw	00
haltcc
	movlw	0x01	;	9us	
	movwf	count1
ww1	decfsz	count1,F	
	goto 	ww1
	nop
	retlw	00
haltd	call	pwmm
	call	pwmm
	call	haltc
	retlw	00
halte	movlw	0x14	;	510 us
	movwf	count2
w3	call	pwmm
	decfsz	count2,F	
	goto 	w3
	retlw	00
pwmm	bsf	osc
	call	haltc
	bcf	osc
	call	haltc
	retlw	00
usaex	bcf	STATUS,6
	bsf	STATUS,5  ;switch to bank 1
	clrf	TRISA	    ; PORTA set to outputs
	bcf	STATUS,5  ;switch back to bank 0
	return
usain	bsf	STATUS,5  ;switch to bank 1
	movlw	0x08	; PORTB set to out/inputs
	movwf	TRISA	;
	return
usbex	bsf	STATUS,5  ;switch to bank 1
	movlw	0x00	; PORTB set to out
	movwf	TRISB
	return
mux	clrf	dig1
	clrf	dig2
	movf	ratb,F ; zero bit test if dig=dig=0
	btfss	STATUS,2
	goto	calc
	goto	gatam
calc	call	digi
	decfsz	ratb,F
	goto	calc
gatam	return
digi	incf	dig1,F
	movlw	0x0A
	subwf	dig1,W
	btfss	STATUS,2 ;test zero bit
	goto	gatas
	clrf	dig1
	incf	dig2,F
	movlw	0x0A
	subwf	dig2,W
	goto	gatas
	clrf	dig2
gatas	retlw	00	
	end
