; Emulation of Olympus RM-1 IR remote control using PIC 12F629.
; The PIC GPIO 5 controls an IR-LED via one BC547 and a 2.7Ohm
; resistor in series.
; Olympus control codes are:
; Button GPIO Code
; Fire 0 0110 0001 1101 1100 1000 0000 0111 1111
; W 1 0110 0001 1101 1100 0100 0000 1011 1111
; T 2 0110 0001 1101 1100 1100 0000 0011 1111
; - 3 0110 0001 1101 1100 0010 0000 1101 1111
; + 4 0110 0001 1101 1100 1010 0000 0101 1111
; Modulation is 40 kHz symmetrical pulse modulation.
; Each command starts with 3.8 ms 40kHz pulse train followed by
; 4ms Low state on GP5 and finished off with 550us 40kHz pulse train.
; 1 = 1500us GP5 Low state followed by 500us 40kHz pulse train.
; 0 = 500us GP5 Low state followed by 500us 40kHz pulse train.
; After each button press there is a 500ms button repeat delay.
	title "Olyremote-1"
	include "P12F629.INC"
	__config _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _BODEN_OFF
	errorlevel -302 ; No bank selection messages
; REGISTER DEFINITION
DELAY_H equ 0x20
DELAY_L equ 0x21
IR_LENGTH equ 0x22
; CODE
	org 0x0000 ; RESET VECTOR
; Initialize PIC
initialize_pic
	bsf STATUS,RP0 ; Sel Bank 1
	call 0x3ff ; Get OSCAL value
	movwf OSCCAL ; write to OSCCAL register
	bcf OPTION_REG,7 ; Enable weak pullups
	movlw b'00010111' ; on GPIO 0-4
	movwf WPU
	movlw b'00001000' ; Enable port change interrupt
	movwf INTCON
	bcf STATUS,RP0 ; Select bank 0
	clrf GPIO ; Init GPIO
	movlw 0x07 ; set GP2 to digital
	movwf CMCON
	bsf STATUS,RP0
	movlw b'00011111'
	movwf TRISIO ; Set I/O 5 as outputs
	movlw 0x1f ; Enable port change IRQ on GPIO 0-4
	movwf IOC
	bcf GPIO,5 ; Set GPIO 5 Low
led_main_loop
	bcf INTCON,GPIF ; Clear interrupt flag
	sleep ; and go to sleep to save power
; Wake up from sleep
; Check which button generated wake-up
Test_W
	MOVF GPIO,W ; Read GPIO and test for W button
	ANDLW b'00000001' ; Mask for the W switch
	BTFSS STATUS,Z ; Check ZERO first
	goto Test_F
	call Exec_W
	goto led_main_loop
Test_F
	MOVF GPIO,W ; Read GPIO and test for Fire button
	ANDLW b'00000010' ; Mask for the Fire switch
	goto Test_T ; Not Z
	call Fire
	goto led_main_loop
Test_T
	ANDLW b'00000100' ; Mask for the Fire switch
	goto Test_M ; Not Z
	call Exec_T
	goto led_main_loop
Test_M
	ANDLW b'00001000' ; Mask for the Fire switch
	goto Test_P ; Not Z
	call Exec_M
	goto led_main_loop
Test_P
	ANDLW b'00010000' ; Mask for the Fire switch
	goto led_main_loop ; Not Z
	call Exec_P
	goto led_main_loop
; SUBROUTINES
; The FIRE button was pressed, execute control sequence
; Fire = 0110 0001 1101 1100 1000 0000 0111 1111
Fire
	call Send_Header
	call Send_One
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	movlw .250
	call DELAY_X_msec ; 250ms delay before return
	movlw .250
	return
; The W button was pressed, execute control sequence
; W = 0110 0001 1101 1100 0100 0000 1011 1111
Exec_W
	Call Send_Header
	Call Send_Null
	Call Send_One
	Call Send_Null
	Call Send_Null
	Call Send_Null
	Call Send_Null
	Call Send_Null
	Call Send_Null
	Call Send_One
	call Send_Null
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	movlw .250
	movlw .250
	return
; The T button was pressed, execute control sequence
; T = 0110 0001 1101 1100 1100 0000 0011 1111
Exec_T
	Call Send_Header
	Call Send_One
	Call Send_One
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	movlw .250
	movlw .250
	return
; The - button was pressed, execute control sequence
; - = 0110 0001 1101 1100 0010 0000 1101 1111
Exec_M
	Call Send_Header
	Call Send_Null
	Call Send_Null
	Call Send_One
	Call Send_Null
	Call Send_Null
	Call Send_Null
	Call Send_Null
	call Send_Null
	call Send_One
	call Send_One
	call Send_Null
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	movlw .250
	movlw .250
	return
; The + button was pressed, execute control sequence
; + = 0110 0001 1101 1100 1010 0000 0101 1111
Exec_P
	call Send_Header
	call Send_One
	call Send_Null
	call Send_One
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_One
	call Send_Null
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	call Send_One
	movlw .250
	movlw .250
	return
; Send_Header: Remote codes must starts with this sequence.
Send_Header
	movlw .120 ; Pulse 8ms
	call Send_IR_Pulse
	movlw .200
	call Send_IR_Pulse
	movlw .4 ; Space 4ms
	call DELAY_X_msec
	movlw .22 ; Pulse 550us
	call Send_IR_Pulse
	call Send_Null
	call Send_One
	call Send_One
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_Null
	call Send_One
	call Send_One
	call Send_One
	call Send_Null
	call Send_One
	call Send_One
	call Send_One
	call Send_Null
	call Send_Null
	return
; Send_One: Sends 1677us low signal followed by pulse
; modulated by 40kHz (25us) symetrical pulses sent
; for 559us. Corresponds to Olympus IR code "1"
Send_One
	Call Delay_1500us ; Space 1677us
	movlw .22
	call Send_IR_Pulse
	return
; Send_Null: Sends 559us low signal followed by pulse
; for 559us. Corresponds Olympus IR code "0"
Send_Null
	call Delay_500us ; Space 559us
	movlw .22 ; Pulse
	call Send_IR_Pulse
	return
; Send_IR_Pulse will send a 50% duty cycle pulse until
; IR_LENGTH is zero. Puls sent on GPIO 5
Send_IR_Pulse
	movwf IR_LENGTH ; Save number of IR cycles
IR_Pulse ; loop
	movlw .3 ; set this to 3 to get 40kHz modulation
	movwf DELAY_L
	bsf GPIO,5 ; Set GPIO 5 High
High_20
	decfsz DELAY_L,F ; This gives about 12 us High
	goto High_20
	nop ; set this two nops to get 40kHz modulation
	nop
	movlw .2 ; set this to 2 to get 40kHz modulation
	movwf DELAY_L
Low_20
	decfsz DELAY_L,F ; This gives about 12 us Low
	goto Low_20
	nop
	decfsz IR_LENGTH,F ; Decrement IR cycle counter
	goto IR_Pulse ; and loop if not zero
	nop
	return
; Delay routines for correct output pulse width
; This delay is used for output pulse width control
DELAY_X_msec ; Call here with W = X msec delay
	MOVWF DELAY_H
DELAY_1msec
	MOVLW .250 ; 1 msec delay loop counter
	MOVWF DELAY_L
DELAY_1ms ; 1 msec delay loop
	NOP
	DECFSZ DELAY_L, F
	GOTO DELAY_1ms
	DECFSZ DELAY_H, F ; Loop counter 1 msec delay loop
	GOTO DELAY_1msec ; until counter is zero
	RETLW 0
Delay_1500us
	call Delay_500us
	call Delay_500us
Delay_500us
	movlw .122
	MOVWF DELAY_L
	call DELAY_4us
	nop
	nop
	return
DELAY_4us ; 4usec delay loop.
	NOP
	DECFSZ DELAY_L, F
	GOTO DELAY_4us
	return
	end
