	LIST P=12F629
	#INCLUDE <P12F629.INC>
	__CONFIG _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_ON & _INTRC_OSC_NOCLKOUT
	errorlevel -302
BANK0 MACRO
	BCF STATUS,RP0
	ENDM
BANK1 MACRO
	BSF STATUS,RP0
	ENDM
#DEFINE M0L LAT,0
#DEFINE M0R LAT,2
#DEFINE M1L LAT,4
#DEFINE M1R LAT,5
#DEFINE IRIN GPIO,3
#DEFINE LED GPIO,1
	CBLOCK	0x20
	STATUS_SAVE
	W_SAVE
	MSTIMER
	TIMERTEMP0
	TIMERTEMP1
	MOTOR0_PWM
	MOTOR1_PWM
	MOTOR_DIR
	PWM_TEMP
	Bit_Cntr
	TEMP1
	LAT
	SERIALDATA_MOTOR0
	SERIALDATA_MOTOR1
	SERIALDATA_CHECKSUM
	ENDC
	ORG 0
	GOTO BOOT
;-------------------------------------INT-------------------------------
	ORG 4
INTERRUPT
	MOVWF W_SAVE
	SWAPF STATUS, W
	MOVWF STATUS_SAVE
	BANK0
	BTFSC PIR1,CMIF
	GOTO COMPARATOR_INT
TIMERINT
	BCF INTCON, T0IF
	MOVLW D'128'
	MOVWF TMR0
	CLRF LAT ; MOTOROK KI
	INCF PWM_TEMP,F
	INCF PWM_TEMP,F
;RAM0 > RAM1
	MOVFW MOTOR0_PWM ;RAM0
	SUBWF PWM_TEMP,W ;RAM1
	BTFSS STATUS,C
	GOTO MOT0ON ; IGAZ
	MOVFW MOTOR1_PWM ;RAM0
	BTFSS STATUS,C
	GOTO MOT1ON ; IGAZ
	MOVFW LAT
	MOVWF GPIO
INTERRUPT_END
	SWAPF STATUS_SAVE, W
	MOVWF STATUS
	SWAPF W_SAVE, 1
	SWAPF W_SAVE, 0
	RETFIE
MOT0ON
	BTFSS MOTOR_DIR,0
	BSF M0L
	BTFSC MOTOR_DIR,0
	BSF M0R
	BTFSS STATUS,C
	GOTO MOT1ON ; IGAZ
	MOVFW LAT
	MOVWF GPIO
	MOVWF STATUS
	SWAPF W_SAVE, 1
	SWAPF W_SAVE, 0
	RETFIE
MOT1ON
	BTFSS MOTOR_DIR,1
	BSF M1L
	BTFSC MOTOR_DIR,1
	BSF M1R
	MOVFW LAT
	MOVWF GPIO
	MOVWF STATUS
	SWAPF W_SAVE, 1
	SWAPF W_SAVE, 0
	RETFIE
COMPARATOR_INT
	BTFSS CMCON,COUT
	GOTO LOWVOLT
COMPINT_END
	BCF PIR1,CMIF
	BTFSC INTCON,T0IF
	GOTO TIMERINT
	MOVWF STATUS
	SWAPF W_SAVE, 1
	SWAPF W_SAVE, 0
	RETFIE
LOWVOLT
;	CLRF GPIO
;	NOP
;	NOP
;	NOP
;	NOP
;	NOP
;	NOP
;	NOP
;	NOP
;	BTFSC CMCON,COUT
;	GOTO COMPINT_END
LEMERULT_CONFIG
	MOVLW D'7'
	MOVWF CMCON
	BANK1
	CLRF VRCON
	MOVLW B'11001000'
	MOVWF TRISIO
	BANK0
	BCF T1CON, TMR1ON
LEMERULT
	CLRWDT
	MOVLW B'00000010'
	MOVWF GPIO
	CALL DELAY50MS
	CALL DELAY50MS
	CLRF GPIO
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	CALL DELAY50MS
	GOTO LEMERULT
DELAY50MS ;KÖZEL 50MS
	MOVLW D'10'
	MOVWF MSTIMER
	GOTO DELAY1MS_1
DELAY1MS_1 ;1 MS*5
	MOVLW D'100'
	MOVWF TIMERTEMP0
DELAY1MS_2 ;10uS*5
	NOP
	MOVLW D'15'
	MOVWF TIMERTEMP1
DELAY1MS_3
	DECFSZ TIMERTEMP1,F
	GOTO $-1
	NOP
	NOP
	DECFSZ TIMERTEMP0, F
	GOTO DELAY1MS_2
	DECFSZ MSTIMER
	GOTO DELAY1MS_1
	RETURN
;----------------------------------INT------------------------------------
BOOT
	BANK1
    call      3ffh               ;get the calibration value
    movwf  OSCCAL       ;calibrate
	BANK0
	CLRF GPIO
	BANK1
	MOVLW B'11001010'
	MOVWF TRISIO
	MOVLW B'10001110'
	MOVWF OPTION_REG
	MOVLW B'01100000'
	MOVWF INTCON
	BANK0
	CLRF GPIO
	MOVLW B'00000100'
	MOVWF CMCON
	BANK1
	MOVLW B'10100111'
	MOVWF VRCON
	CLRF PIE1
	BSF PIE1,CMIE
	BANK0
	CLRF T1CON
	CLRF MOTOR1_PWM
	CLRF MOTOR0_PWM
	CLRF LAT
	CLRF PWM_TEMP
	CLRF TEMP1
	CLRF MOTOR_DIR
	CALL DELAY50MS
	BTFSS CMCON,COUT
	GOTO LEMERULT_CONFIG
	BSF INTCON,GIE
	CLRWDT
MAIN
	CALL RS232_Rx
	MOVFW TEMP1
	CLRF TEMP1
	XORLW 0xAA
	BTFSS STATUS, Z
	GOTO MAIN ; CSOMAGKEZDET DETEKTÁLÁSA
PACKAGESTARTRECIVED
	CALL RS232_Rx
	MOVFW TEMP1
	CLRF TEMP1
	MOVWF SERIALDATA_MOTOR0
	CALL RS232_Rx
	MOVFW TEMP1
	CLRF TEMP1
	MOVWF SERIALDATA_MOTOR1
	CALL RS232_Rx
	MOVFW TEMP1
	CLRF TEMP1
	MOVWF SERIALDATA_CHECKSUM
CHECK_PACKAGE
	MOVFW SERIALDATA_MOTOR0
	ADDWF SERIALDATA_MOTOR1,W
	ADDLW D'1'
	XORWF SERIALDATA_CHECKSUM , W
	BTFSS STATUS,Z
	GOTO MAIN ; VISSZA AMíG NEM JÖN EGY "ÉP" CSOMAG
RECOVEOK
	CLRWDT
	BCF INTCON,GIE
	CLRF MOTOR_DIR
	BTFSC SERIALDATA_MOTOR0,7
	BSF MOTOR_DIR,0
	BTFSC SERIALDATA_MOTOR1,7
	BSF MOTOR_DIR,1
	ANDLW B'01111111'
	MOVWF MOTOR0_PWM
	BCF STATUS,C
	RLF MOTOR0_PWM,F
	MOVFW SERIALDATA_MOTOR1
	ANDLW B'01111111'
	MOVWF MOTOR1_PWM
	BCF STATUS,C
	RLF MOTOR1_PWM,F
	BSF INTCON,GIE
	GOTO MAIN
; Egy RS-232 bájt vétele
RS232_Rx
	btfsc   IRIN    ; start bit detektálás (log0 szintű)
	goto    RS232_Rx	; nincs start jel, várakozik tovább
	call    Start_Delay     ; fél bitidőnyi késleltetés
	movlw   d'8'		; bitek száma
	movwf   Bit_Cntr
Rmit
	call    Bit_Delay       ; teljes bitidőnyi késleltetés
 	btfss   IRIN	; RxD bemenet másolása C bitbe
	bcf     STATUS,C
	btfsc   IRIN
	bsf     STATUS,C
	rrf     TEMP1,1		; Carry beléptetése Temp1-be
	decfsz	Bit_Cntr,1	; összes bit vétele megtörtént?
	goto	Rmit		; még nem
	call    Bit_Delay       ; Stop bit késleltetés
	return			; vétel kész, vett adat Temp1-ben
; RS232 startbit késleltetés
; 416 us / 1200 Baud
;Timer1 et használom mert egy sima ciklusnál "közbejöhet" az interrupt és elrontja az egészet...
; T1 be betöltöm az időt és nézem az interrupt flag et
Start_Delay 
	MOVLW D'254'
	MOVWF TMR1H
	MOVLW D'96' ; 54
	MOVWF TMR1L
	BSF T1CON, TMR1ON
CHECK_STARTD
	BTFSS PIR1, TMR1IF
	GOTO CHECK_STARTD
	BCF T1CON, TMR1ON
	BCF PIR1, TMR1IF
	RETURN
; RS232 bit idő beállitás
; 833 us / 1200 Baud
Bit_Delay
	MOVLW D'252'
	MOVWF TMR1H
	MOVLW D'191' ; 109
	MOVWF TMR1L
	BSF T1CON, TMR1ON
CHECK_Bit_Delay
	BTFSS PIR1, TMR1IF
	GOTO CHECK_Bit_Delay
	BCF T1CON, TMR1ON
	BCF PIR1, TMR1IF
	RETURN
	END
