HotKeyManager is a component that allows you to add system-wide hotkeys to your application.
A hotkey in Windows is a key combination which invokes a specific action. You can often use Ctrl+S from an application to save a file. However, a system-wide hotkey allows you to invoke a custom action from anywhere. Your application doesn't have to be in the foreground or even visible to receive the hotkey events.
In Windows 2000 and later it is even possible to use the extended keys found on modern keyboards (those that start your internet browser, your e-mail program, adjust your sound volume, etc).
| AddHotKey | function AddHotKey(HotKey: Cardinal): Word; Registers a hotkey with a specific key combination. NOTE: A return value of 0 means the operation failed - perhaps because the specified key combination is already in use. |
Returns an index or 0 if error |
| ChangeHotKey | function ChangeHotKey(Index: Word; NewHotKey: Cardinal): Word; Changes a hotkey to a new key combination. Provide the index received from AddHotKey as parameter. NOTE: This method returns a new index. The old index is no longer valid. |
| RemoveHotKey | function RemoveHotKey(HotKey: Cardinal): Boolean; Unregisters a hotkey by its key combination. |
Returns true or false |
| RemoveHotKeyByIndex | function RemoveHotKeyByIndex(Index: Word): Boolean; Unregisters a hotkey by the index previously received from AddHotKey or ChangeHotKey. |
| ClearHotKeys | procedure ClearHotKeys; Unregisters all registered hotkeys. |
| OnHotKeyPressed | type TOnHotKeyPressed = procedure(HotKey: Cardinal; Index: Word) of object; Fired when then user presses one of the registered hotkeys. The event method provides the key combination that was pressed and the index the hotkey is registered under (the index is previously received from AddHotKey or ChangeHotKey). |
| HotKeyAvailable | function HotKeyAvailable(HotKey: Cardinal): Boolean; Tests if the specified key combination is available for registration by your app. (or any other app.). |
| GetHotKey | function GetHotKey(Modifiers, Key: Word): Cardinal; Returns the key combination resulting from the specified modifiers (a combination of Shift, Ctrl, Alt, Win, or none of them) and the key (A, for instance). USAGE: The modifiers can be a combination of MOD_SHIFT, MOD_ALT, MOD_CONTROL, and MOD_WIN. The key is a virtual keycode. For alphanumeric chars you can get their virtual keycode by using the Ord method on the capitalized char - eg. Ord('G') corresponds to the virtual keycode for the letter 'G'. For any other chars, you should use the appropriate ASCII code or VK_xxx constant (found in windows.pas). Alternatively, use the TextToHotKey method. EXAMPLE 1: hk := GetHotKey(MOD_CONTROL + MOD_SHIFT, Ord('G'));EXAMPLE 2: hk := GetHotKey(MOD_ALT + MOD_SHIFT, VK_HOME); |
Returns 0 if error |
| SeparateHotKey | procedure SeparateHotKey(HotKey: Cardinal; var Modifiers, Key: Word); Splits a key combination into a key (A, for instance) and its modifiers (shift, ctrl, alt, win) and returns them. |
| HotKeyToText | function HotKeyToText(HotKey: Cardinal; Localized: Boolean): String; Returns the specified key combination in a string. USAGE: If Localized is true the result is a string in the user's currently active language, otherwise the result is in US English. Unless you have a good reason you should always present key combinations in the local language (Localized=True), as this is less confusing for the user (who otherwise may have difficulties identifying the correct keys). If the active language is US English there is no difference between the localized and the non-localized result. NOTE: An extended key may not have a name in Windows. If not, a name defined internally in HotKeyManager is used. This name is always in US English, regardless of the value of Localized. |
Returns an empty string if error |
| TextToHotKey | function TextToHotKey(Text: String; Localized: Boolean): Cardinal; Returns a key combination from the specified string. USAGE: If Localized is true it means Text is in the user's currently active language, otherwise Text is in US English. You must use '+' as separator. You can use extra spaces if you like. The method is case insensitive. The order of the modifiers doesn't matter. NOTE: An extended key may not have a name in Windows. If not, a name defined internally in HotKeyManager is used. This name is always in US English, regardless of the value of Localized. EXAMPLE 1: hk := TextToHotKey('Ctrl+Alt+Num 3', True);EXAMPLE 2: hk := TextToHotKey('alt + ctrl + num 3', True); // The same |
| IsExtendedKey | function IsExtendedKey(Key: Word): Boolean; Returns whether the specified key is an extended key (used for internet browser, e-mail, etc). USAGE: Be aware that Key is not a hotkey. It is the key you get after a call to SeparateHotKey (ie. a hotkey without the modifiers). |
SeparateHotKey(HotKey, Modifiers, Key); // Split HotKey into Modifiers and Key CtrlFound := (Modifiers and MOD_CONTROL) <> 0; AltFound := (Modifiers and MOD_ALT) <> 0; ShiftFound := (Modifiers and MOD_SHIFT) <> 0; WinFound := (Modifiers and MOD_WIN) <> 0; // Special Windows modifier key
Get the latest version from http://subsimple.com/delphi.asp.
Troels Jakobsen
troels.jakobsen@gmail.com
