Fórum » Propeller Clock
Ebbe a rajzba becsúszott egy kis hiba !!! Idézet: „Van egy kész működőképes ilyen panelem, a kapcsolási rajz is erről szól. Ezt ha kell neked adhatom.” Bocsi, sajnos nincs meg. Visszavonom ! A hozzászólás módosítva: Jan 2, 2021
Hello KKobra,
If the files of the 67 led clock are still available, can you share it? Thanks Rookie 1
Thank you very much for your quick reply,My request from you is which pcb can I use the attached hex codes?Can I bother you again where I don't understand.Is there a link I can follow the site in English?
I've been reading the subject one by one from the beginning. I'm now on page 164.
I'm not a professional like you. I am interested in electronics as a hobby. I would appreciate it if you could help.
Sorry, i am not the author, publisher of this version. The plan and the software was made forummate named Kly but he has left this forum some years before.
Please use "Válasz" (answare in englis) to react a post. With "Módosítás" (edit) You can edit Your post, with "Törlés" (delete) a post can be deleted. A hozzászólás módosítva: Jan 16, 2021
Hello Hp41C,
I read all the pages. I saw that Kly did not write for a long time. I decided to make a 16F group for a watch. I want to use the old hdd engine. Is wireless power necessary even if I use it? I will share the construction stages with you.
Hi,
You can find a lot of versions of propeller clocks based on 16F from 16F84 up to 16F886 even on this forum. 16F628 version by vicsys The wireless power gives a low of power for the 64-led version. The power stage in the linked article is a simple one witch can be used for 16F886 version with 24 leds as well.
Sziasztok. A Vicsys féle bázis rávehető hogy távi nélkül induljon a videofej tekercs bekötésének kikisérletezése végett?
Nem.
Ez viszont indul nyomógombra is.
Ez úgy van megírva, hogy a kapcsolási rajzon látható nyomógomb is bekapcsolja a forgató motort.
De itt van a forrás is. URC1 táv 552 kód.
De ez hasonlit Vicsys bázisára csak más alkatrészekkel nem?
Ez a kapcsolási rajz nemcsak hasonlít, hanem ugyanaz. (helyenként más alkatrészekkel, de ennek a működést tekintve nincs jelentősége).
Ha a Vicsys bázis van neked megépítve akkor csak a PIC 8-as lábról kell egy 2,2K felhúzó ellenállás az 5V-ra, és egy nyomógomb a GND-re. Idézet: „bázis rávehető hogy távi nélkül induljon” Természetesen az általam mellékelt Base-628-nvomógombos.hex legyen a PIC-be. Ezáltal a nyomógombra úgy működik a bázis, mintha a távirányítóval kapcsolnád BE/KI. A hozzászólás módosítva: Feb 11, 2021
Szia. A nyomógombos hex-nek megvan a forrása is?
Köszi. Próbálom újraforditani az Mplabbal de nem fordul le. Tudsz segíteni?
A keys.asm is kell hozzá.
MpLab 8.xx: Készíts egy projectet 16F628A -hoz. Csak a base628.asm -et add meg forrás állományként. Absolute kódot fordíts release módban. A hozzászólás módosítva: Feb 13, 2021
Most nem vagyok a gépnél de elküldöm milyen hibával áll meg a fordító.
Most nem igazán értem a problémádat.
Le se kell fordítani, mert fentebb feltettem a HEX-et is. De itt van mégegyszer. A hozzászólás módosítva: Feb 13, 2021
A kitöltések végett kellene csak mert ki kell totózni mi a jó a videofej tekercseinek.
Hello dear friends,
I have a propeller clock that (32 smd Leds) I bought in 2013, but it doesn't work anymore. The Pic18F24K20 chip is used. How can I read the software? With which program?(Icprog with usb to ttl?)Where should I look for the error? A video of his working time : https://www.youtube.com/watch?v=WSeiPK8n1hM Error video : https://www.youtube.com/watch?v=Yvf89ieErgc
Once you’ve decided what you want to build, find it.
I built 4 different watches successfully
You are right,rotation sensor and battery fault.I was change and everyting is ok.
Thank you.
Sziasztok. Vicsys bázisán hogy tudom megnézni a trafó primer oldalára mennyi feszültség jön ki a bázisból?
Köszi.
Voltmérővel persze ne digitálissal. De minek neked a feszültség? A kitöltési tényező számit.
A hozzászólás módosítva: Márc 5, 2021
Csak kiváncsiság miatt. Most egy izzó van rajta de épp csak világít. Majd rámérek a mutatóssal .
