DST 210
3 az egyben oszcilloszkóp, multiméter, jelgenerátor.
2.8" TFT kijelző
3000mAh akku, USB C töltés
300g
Szkóp:
10MHz
Input Impedance: 1MΩ
1:1 Probe: 80Vpp (+40V), 10:1 Probe: 800Vpp (+400V)
500ns ~ 20s
Trigger Mode: Auto / Normal / Single
Trigger Type: Rising Edge & Falling Edge
Trigger Level: Adjustable with indicators
Waveform Freeze: Support (HOLD function)
Auto Measurement: Maximum, Minimum, Average, RMS, VPP, Frequency, Period, Duty Cycle
Multi:
DC Voltage: 1.9999V/19.999V/199.99V/1000V —— ±(0.5%+3)
AC Voltage: 1.9999V/19.999V/199.99V/750.0V —— ±(1%+3)
DC Current: 19.999mA/199.99mA/1.9999A/9.999A —— ±(1.2%+3)
AC Current: 19.999mA/199.99mA/1.9999A/9.999A —— ±(1.5%+3)
Resistance: 19.999MΩ/1.9999MΩ/199.99KΩ/19.999KΩ() —— ±(0.5%+3)
1.9999KΩ/199.99Ω —— ±(2.0%+3)
Capacitance: 999.9uF/99.99uF/9.999uF/ 999.9nF/99.99nF/9.999nF —— ±(2.0%+5)
9.999mF/99.99mF —— ±(5.0%+20)
Frequency: 9.999MHz/999.9KHz/99.99KHz/9.999KHz/ 999.99Hz/99.99Hz/9.999Hz —— ±(0.1%+2)
Jelg.:
Output Waveform: Support 13 types
Waveform Frequency: 0-10KHz
Square Duty Cycle: 0-100%, Square and Sawtooth are adjus
Legutóbb módosítva: 2026.06.08. 16:14 (történet)
