Lehet, hogy hiba van a fordításban.
Legközelebb csak a fordító üzenetet fényképezd, nem/alig látni, mit ír.
Target folder: C:\Users\KONCSA~1\Desktop\DS18B2~1
Source name: C:\Users\Koncsar Iroda\Desktop\DS18B20homero\DS18B20.fcfx Title: Description: Device: PIC.18F.18F14K22 Generated by: Flowcode v8.0.0.6 Date: Friday, November 22, 2019 19:04:03 Users: 1 Registered to: License key: ***** http://www.matrixtsl.com Launching the compiler... C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat 18F14K22 "C:\Users\KONCSA~1\Desktop\DS18B2~1\" "DS18B20" C:\Users\KONCSA~1\Desktop\DS18B2~1>C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=18F14K22 "DS18B20.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32 Microchip MPLAB XC8 C Compiler (Free Mode) V1.45 Build date: Nov 15 2017 Part Support Version: 1.45 Copyright (C) 2017 Microchip Technology Inc. License type: Node Configuration DS18B20.c: FCD_0bbd1_One_Wire1__Get_Next_ID() 1006: break; ^ (345) unreachable code (warning) using updated 32-bit floating-point libraries; improved accuracy might increase code size . . . . . Memory Summary: Program space used 16FEh ( 5886) of 3E00h bytes ( 37.1%) Data space used 102h ( 258) of 1FFh bytes ( 50.5%) Configuration bits used 7h ( 7) of 7h words (100.0%) EEPROM space used 0h ( 0) of 100h bytes ( 0.0%) ID Location space used 0h ( 0) of 8h bytes ( 0.0%) Data stack space used 0h ( 0) of E6h bytes ( 0.0%) You have compiled in FREE mode. Using Omniscient Code Generation that is available in PRO mode, you could have produced up to 60% smaller and 400% faster code. See http://www.microchip.com/MPLABXCcompilers for more information. Compilation successful! Launching the linker/assembler... C:\Program Files (x86)\Flowcode v8\tools\DoNothing\DoNothing.exe FINISHED
Az LCD címzése rossz volt. 32 ről 39 re kellett tenni. Most már van 0.000000 kijelzésem. Hőfok nuku.
A hozzászólás módosítva: Nov 22, 2019
Sajnos még mindig bénázom. Nincs több ötlet, hogy miért nem ír ki hőfokot a drága?
Kevés embernek van Flowcode 8-as verziója, ezért megy a (nem) találgatás.
Flow6 ban is működnie kéne! Vagy nem?
Most már van kijelzés, csak az érték nem jó. 15.5 Hiába melegítem a szenzort nem változik semmi. A hozzászólás módosítva: Nov 22, 2019
Szia! Arduinóban a DS18B20 rendesen működik. Csak ebben a szegény progiban nem tudjuk életre kelteni. Hihetetlen.
Ha valakinek fent van a Flow8 próbaidős progija, legyen kedves ezt megnézni,hogy miért nem akarja az igazságot.
Segítséget kérek szépen. Az adott fájlban azt szeretném elérni, hogy ha a megszakítás 5 perce lefut, álljon meg a progi végleg és ne ismétlődjön. Ez megoldható lenne?
A hozzászólás módosítva: Nov 27, 2019
IF megsz = "érték"
true TMR2 disable
Köszi. Tegnap este, pedig már nagyon a közelében jártam. Így nem próbáltam.
Nem állt meg 5 perc után. Újraindult.
Akkor igy próbáld meg
A Disable Timer2 alól kivettem a megsz= 0 át. Így is jó.
Új gondom van. Az első elágazásnál azt szeretném, hogy a LED 3mp világítson 3mp szünet, a 2. elágazásnál pedig 1-1mp legyen a LED működési ideje.
Alapok nélkül csak gondok lesznek.
Amit feltettél progit, végül is működik, csak kérdés, hogy azt meg lehet vele csinálni, hogy világítva kezdjenek a LEDek?
Például, ha az alapértelmezett értékét felvennéd a lefutáshoz szükséges értékre és nem nulláról indulna a számolás?
A hozzászólás módosítva: Nov 28, 2019
Nem értem, amit írsz. Sajnos.
Minek az alapértelmezet értékét? stb... A hozzászólás módosítva: Nov 28, 2019
Gondolom van egy érték aminél vált a rendszer. pl almafa ha egyenlő 3-al akkor világít, na az almafa változó értékét kell alapból 3-ra állítani, és akkor egyből világít.
